Simple wiring advice.
Submitted: Sunday, Sep 24, 2006 at 21:52
Jayk
I want to install a strip of LED lights that I bought from Jaycar into the kitchen side of my traytop camper to replace a pretty useless fluoro that we've been using.
I thought that I would put a switch between the light strip and the power source. As the power source, I was simply going to tap into the wiring that feeds a permanent, not very
bright, but useful in a hurry, bulb type light that is attached to the wall of the camper's kitchen.
Pretty simple I thought, forgetting my fairly low tech electrical understanding. When I checked out the wiring into the permanent light I discovered that it only had one wire going into it. This wire is brown, so I'm assuming that it's +ve. It seems that the circuit is completed by a short wire, inside the light cover, that's attached, at one end, to the steel wall of the camper with a rivet, and to the light switch, at the other end.
Now, the brown wire, which I assume to be +ve, is connected to another brown wire via a standard connector/
junction fitting. This connector/
junction, also has a white wire going into it, which I assume connects to the steel of the camper somewhere to provide the circuit.
Can I assume that this wire is the -ve and that I could wire my -ve wire from the LED into it, or would I be better off running a new lot of wiring that I know to be +ve and -ve.
I do have a plan B which is to connect the LED strip up to a cigarette lighter plug and use the plughole fitting in the camper. I don't want to do this if possible as the plughole is useful, and the solution isn't that neat.
The LED strip, btw, should be a cracker when I get it up and going. Very unobtrusive, and very
bright.
Many thanks,
Jeff
Reply By: crfan - Sunday, Sep 24, 2006 at 22:13
Hi Jeff buy a test light they are cheap then you can find out whats what.
led test lights are dearer but will also give you pos and neg .
P
196309
Reply By: Member - Doug T (W.A) - Monday, Sep 25, 2006 at 22:21
Going by your post it seems the brown wire would be the one your looking for and it should run the LEDs quite OK as they need voltage from 3.5v to 36v and you won't need very thick wire, the thinnest you can find in an auto
shop 6amp or 8amp if you can find it will be sufficient
196536
Reply By: _gmd_pps - Monday, Sep 25, 2006 at 23:02
I assume the white wire is separate from the brown !
If you do not have a multimeter or anything you can use your led lights as a test...
use one lead from the led against the brown and one against chassis ground .. they should light up ..
now one lead against the brown again .. and the other one against the white ..
if they light up you have a ground connection .. if not you have a switched positive (likely) .. if the white is positive also nothing will happen ..
you can install the led with the same technique .. brown wire to single switch and to led lights .. the other wire from the led lights to a good ground point ... thats in line with the sloppy installation you have described ... I always would wire the neagtive also but many cheap lights only provide ground via chassis and don't have a separate wire.
If the brown wire and white wire are together (not cleart in your description)
use the brown wire as positive and find a chassis connection for the other one. put the switch in the positive wire (a small fuse doesn't hurt either).
good luck
gmd
196552
Reply By: Jayk - Tuesday, Sep 26, 2006 at 00:57
P, Doug and GMD,
Many thanks. You have given me enough to go on to work it out. It looks as though it should be simple, even for a stumblebum like me.
Thanks again, and have a good one,
Jeff
196563
