diffs and fuel
Submitted: Thursday, Mar 13, 2003 at 11:18
jeremy
G`day travellers,3.0lt patrol fuel filters seem to block on bad fuel and bring on a warning light.Can anyone please tell me the procedure to change the filter ,drain the filter,bleed the system when i`m by myself on a trip.Are special
tools required?If its easy i`ll buy a spare to carry with me.Also while your here does anyone recommed where to buy spare radiator hoses/fanbelts for 3.0lt TD at good prices?And finally has anyone tried a Lockrite front diff in a patrol and if so what do ya reckon?
Reply By: Will - Thursday, Mar 13, 2003 at 11:49
Jeremy,
I tried the lockright on a GU, it was OK but in the end I replaced it with an ARB air locker, it is horses for courses and this may start a war, I believe the lockrite is more proactive as it is always engaged and it only disingages around corners but, it was a pain with the auto hubs and put too much pressure on CV joints and steering.
Since the replacement to the ARB the diff is open as original but can be locked whenever I want...
Will
15059
Follow Up By: jeremy - Thursday, Mar 13, 2003 at 14:00
Thanks Will, can you feel the lockrite thru the steering offroad in low/4 and high/4 and i`ve wondered does it unlock when doing a slow turn in low range,say abend in the track while crawling up a slipperly climb.I would have an air locker anyday but might blow budget....lockrite much cheaper.....horses for courses???could you elaborate Will...
9137
Follow Up By: Will - Friday, Mar 14, 2003 at 12:01
Jeremy,
I did the same, cheaper... in the end it cost me more money.
Just save up and get what you want.
Horses for corses, you get what you pai for, yes it abends, it pulls carries on and I did not like that pressure on CV joints.
IT does unlock but it takes some mighty pressure before it does.
I used it on two trips before I was convinced to take it off.
Will
9223
Follow Up By: Coops - Saturday, Mar 15, 2003 at 09:43
Will
I have Lock Right on my Cruiser but feel that it's less stress on CV joints as I rarely use 4WD now as opposed to pre lockers. I'm not criticising or arguing (lets call it a healthy debate) but just trying to give my 2 bob's worth to Jeremy. I have free wheeling hubs though and perhaps this is the difference. Would be interested to hear someones opinion on that.
My lock rights have seen 3 years use in
Pilbara &
Kimberley and to date have caused me no problems at all. I would prefer air locker in rear though but not unless lockers give way.
I managed to get a set of front and rear Lock Rights for under $700 so the savings have paid for a heap of other goodies.Coops
9278
Follow Up By: Will - Sunday, Mar 16, 2003 at 12:43
Coops,
Off course if you don't use 4wd the thing does nothing...!!
I use 4wd often and as such posted my experiences. That is why I said, horses for courses.
At the end of the day it is your decision.
A friend of
mine has the lockrite in his GQ and he reckons is fine and he uses 4wd as much as I do.
Just opinions and preferences.
Will
9311
Follow Up By: Coops - Sunday, Mar 16, 2003 at 13:36
I still go off road - just don't use 4WD as much (unless stuck) as lockers help quite a deal.
I will admit to being influenced by cost factor but thought it was worth a try. So far I'm happy enough.
Beauty of this site is no-one is scared to offer their opinions and preferences and it allows us all to make educated guesses when purchasing that new bit for our fourby's.
Happy
Camping
9314
Reply By: Marty and Sam - Thursday, Mar 13, 2003 at 13:24
I chased around for hoses and belts and could only get them from Nissan. I rang repco and they said that the vehicle was to new and nobody had made aftermarket hoses and belts for it yet.
The prices are as follows:
Top hose $70.98 plus GST.
Bottom hose $52.86 plus GST.
Serpent belt $84.27 plus GST
Shop around i got different prices from different dealers.
15072
Follow Up By: jeremy - Thursday, Mar 13, 2003 at 14:06
Thanks Marty and Sam,wow $200 bucks just for that...tempting to leave home without them.I`m pretty sure i`ve seen top and bottom hoses in packs (aftermarket) somewhere i wonder wether Don Kyatt in Nth Melb has them,i`ll give`em a call.
9139
Reply By: just - Thursday, Mar 13, 2003 at 15:12
Jeremy,
Fuel filters a breeze to replace (in theory) no special tools, just drain the filter then unscrew it from bracket. Then unscrew drain tap, screw it on to new filter, screw filter on to bracket and then prime/ evacuate air via pump on top of bracket. Simple! However, when doing
mine I had to resort to removing the bracket (with the filter attached) which meant ondoing the in and out fuel lines, in order to get enough leverage on the filter by placing the bracket in a vice. Not too difficult just a bit messier than the thoery! I would difinitely carry spare fuel and air filters for a decent trip away.
As for a lockrite I've had one on my GU, and previously GQ, since 1991 and they're excellent. Someone else asked the same question a month ago - suggest you do a
forum search for lockrite for other comments. Happy travels!
15081
Follow Up By: just - Thursday, Mar 13, 2003 at 15:32
Sorry Jeremy, bum steer, the previous question I refer to was No.3439 of 19/2/03 "Suzuki Viagra asked about Fitting Lokka/Lock Right diffs at home"
9147
Follow Up By: Member - Kevin - Thursday, Mar 13, 2003 at 16:45
I had to do the same thing on my 4.2TD - take the whole thing into the shed and put it into a vice to unscrew the filter, hope this is not normal practice 'cos I don't carry a vice in the bush.Kevin - sitting here, thinking of there
2002 GU Patrol ST 4.2TD
2000 15' Supreme Getaway
9152
Follow Up By: jeremy - Thursday, Mar 13, 2003 at 20:41
thanks for the info Just
9171
Follow Up By: jeremy - Thursday, Mar 13, 2003 at 20:43
thanks Kevin and Truckster
9172
Reply By: Truckster - Thursday, Mar 13, 2003 at 17:12
Remember it may also take more than 1 filter change to clean the system..
mate at the cape they got a bad batch of fuel, stopping every 1 hour to clean them!
6-8 filters later, and having phoned ahead to order another 12, they were going.... They ended up dumping the complete load of fuel, jerrys and full tanks the lot.
15101
Reply By: Eric - Thursday, Mar 13, 2003 at 23:13
Jeremy.
Just a suggestion, if you are concerned about bad fuel you could do what I have done on several vehicles and put an electric pump and a cav filter [ $5 replacment element] between the the 2 tanks so that as you drive you can filter the fuel by pumping it back and forwards between tanks. the factory filter lasts a very long time [270k and still going] so the cost of the pump and filter [$35 pump $60 fiter asembly] is covered by the savings on factory filters. Eric.
15158
Follow Up By: Coops - Friday, Mar 14, 2003 at 17:36
What a great idea.
Can you by chance tell me what micron the Lucas filters to ?
Coops
9241
Follow Up By: Eric - Friday, Mar 14, 2003 at 22:01
Coops.
Sorry I can't remember the filter speck and its not on the carton but it was better than the factory unit. The cav filters are supplied in a range of microns, the housing and the $5 units are the ones used on fergy tractors, Eric.
9255
Follow Up By: Coops - Saturday, Mar 15, 2003 at 09:33
I already use the CAV filter setup but as you say no specs available. I was hoping you might know to answer another question.
I may try the system you described earlier as my LR tank can sometimes have fuel sitting in it for a couple of weeks before it's used.
thanksCoops
9277
Follow Up By: jeremy - Sunday, Mar 16, 2003 at 22:05
Smart cookie you are Eric,,,,,,i may just put a filter in the transfer line from the sub tank and this would also help a bit when i transfer to the main tank,Anyhow a top idea of yours ,got any more?
9339
Reply By: Ronnie - Friday, Mar 14, 2003 at 22:50
jeremy,
Replaced my standard filter with the Berimah Diesel adapter and Lucas filter.
Regards Ronnie
15229
Follow Up By: jeremy - Saturday, Mar 15, 2003 at 22:04
Ronnie,,just a little worry on that (lucas filter).....a lot of info i`ve found out from other people on this site is that after market filters on the 3.0lt td may affect your fuel pump life....ie..the aftermarket filters have a higher restriction to flow and i am told the 3.0lt pump is lubricated and cooled by the diesel supply itself.Several guys strongly advise sticking with the factory unit....look back atprevious posts but feel free to correct me if i`m wrong...also consider warranty cover as the pumps are worth 3-5 grand
9293
Reply By: Bob Y. - Sunday, Mar 16, 2003 at 12:46
Jeremy, Interesting thread, so thought I'd comment. A neighbour has a 2002 3L Nissan, and he was strongly advised to fit a CAV filter as a primary filter, to reduce the fuel pump problems, that were appearing in earlier models. Don't think he would have done over 20K yet, but no dramas. The advise came from his nephew, who throws spanners around for a central coastal Qld dealership.
Advise from a diesel engineer? was when changing filters, preferably do it
well before you need the the vehicle, say overnight, or half a day. he suggested that the filter element has time to swell, to become more effective. As mentioned previously, dirty fuel often needs tanks drained, and flushed out. Fuel from 44 gal drums is notorious for contamination.
Hooroo...
15306
Follow Up By: jeremy - Sunday, Mar 16, 2003 at 21:59
G`day BoB ,,interesting info you have there .Can you clarify if the CAV filter was fitted in line before the original filter and the advise from the nephew .....is he at Nissan dealer or a diesel mechanic by trade.I wonder what Berrima deisel would advise on this matter ,they seem reputable.Whats the diesel engineer reckon about the Nissan f/pumps and filters?
9338
