air filter
Submitted: Thursday, Mar 13, 2003 at 20:19
ThreadID: 3837 Views:1564 Replies:5 FollowUps:0
any reason why i carnt fit the air filter assembly from a 1992
surf to an 1989 4 runner i need the space 4 a second battery
Reply By: jason - Thursday, Mar 13, 2003 at 20:29
darren you are probably having trouble because the surf would be a turbo and i think the assembly's are different
regards
jason
AnswerID: 15125
Reply By: Mick n Sal - Thursday, Mar 13, 2003 at 21:07
Darren,
I'm not familiar with the arrangement on the series one 4runners, but i'm in the process of doing it on my 90 model. On the 3L engine the size of the inlet manifold is larger than on the Surf, so it requires a little creative tubework. Just take your time to get the placement of the assembly correct. hope this helps.
AnswerID: 15133
Reply By: Steve - Friday, Mar 14, 2003 at 07:35
I have looked at doing the same to my 1989 Hilux Dual Cab (with after market turbo).
I sourced an aircleaner assembly from East Coast 4WD out of a 2LT Surf. I got it to the point that I believe it would work fine mounted up on the wheel arch near the power steering resevoir.
Had to modify (cut) the original air cleaner hose down but it would have done the job OR I could have purchased a suitable length of hose to fit.
Ended up not fitting it. Decided for my situation I'd be happier with the 2nd battery in the ute next to the fridge.
There is another option for non turbos where the original air cleaner is modified and turned around inside the engine bay.
I found a bloke in WA who'd done this. He sent me the pics and it looked great. Unfortunately for me the turbo meant it wouldn't suit my needs.
I have some pics of his set up if you'd like them.
Steve
AnswerID: 15165
Reply By: darren - Friday, Mar 14, 2003 at 17:22
thanks guys/gals steve any pics would help
im hoping it will work mick n sal would love
to see some pics off your set up
cheers darren
AnswerID: 15201
Reply By: Steve - Thursday, Mar 20, 2003 at 08:18
Darren,
Email me on
stephen.roe@dewr.gov.au
and I'll send you what I have.
Steve
AnswerID: 15655
