Simpson Break down
Submitted: Tuesday, Oct 17, 2006 at 05:49
ThreadID: 38575 Views:5218 Replies:7 FollowUps:24
To All Simpson desert Travellers Myself & 5 other 4wd went through the desert last April from Birdsville via the French Line Had a Great Trip, days very Slow due to big sand drifts,one day only travelling 89 Klm, On the 4day 370 Klms in just short of the Rig road turn of Mt Dare Side, I broke down with a blocked Diesel fuel line ,virus in tank, put spare diesel on roof ,but me could not stop the leak @ the Fuel pump. Due to the heat & the wind we left it there to be towed back to Birdsville arrange on my sat Phone,from hear it hurts, Towing by Shell Centre,Birdsville $68 per Klm & $68 Per Hour Tow cost $4200 ,Screwed big time for blocked Fuel line. From now I am a passager,& we went on to Dalhousie Springs,Mt Dare, Finke,Old Ghan Railway,Chambers Pillars,Ayes Rock,The Olgas, Curtin Springs,Kings Canyon,Alice Springs.Flew back to Birdsville to pick up Truck & Pay Bill , now up to $5000 as I asked them to fix the blocked Line, We that's Live , but be prepared.
Note full story in Treks 10/10/2006 Simpson Desert French Line
Have a Great Day
Reply By: Robin - Tuesday, Oct 17, 2006 at 06:07
Seriously bad luck CLC50 , guess you made the best descision
you could at the time.
The problem you refer to "Fuel Virus" is more common than
is recognized, particularly in boats, and tends to get worse
when conditions get bad.
The issues of diesel as a fuel , in that they are generally
suseptable to water , bugs, and rely on massive internal pressures
,fine tolerances and most use turbochargers these days are all not
good points for heading outback.
There are other views on this but personally I stick with relativily low tech petrol which solves most problems with an all in one up front payment.
(30% extra fuel use)
Robin Miller
AnswerID: 199513
Follow Up By: GUPatrol - Tuesday, Oct 17, 2006 at 09:15
You know what Robin, I am starting to agree with you... After so much research on the subject, all the pluses of diesel have dissapeared now with modern technology diesels.
In the past diesels had the torque low in the rev range, they were simple (no electronics no sensors) and economical because petrols suffered from Carby problems, high tension lead problems in water crossings etc etc...
These days however, diesels are complex, suffer from waxing in winter, water and bugs, ECU problems just like petrols and electronics suffer in water crossings, while petrols have gained because they no longer use carbys, they no longer have high tension leads (direct coil on each spark plug), and the ECU's have become more reliable...
If you look at some of the testing and fuel usage, with closed loop petrols, the gap has closed too, ie: Prado 4.0L uses 13.5L per 100kms (real figures from three members of our club), Prado 3.0L diesel 11L/100kms (power difference is amazing though), while my TD42 patrol uses 13.5L per 100kms (same as a prado petrol), while I have to put up with noise, smell and lack of power, the prado V6 powers along nice and smooth, no noice, no smell, no smoke and plenty of get up and go!!
My findings after 10 years of owning older petrols and 7 years of owning a Turbodiesel. In my research for a new vehicle now, I am leaning more and more towards petrol again...
Will
FollowupID: 458408
Follow Up By: Robin - Tuesday, Oct 17, 2006 at 11:30
Hi Will
Bit like you, just waiting for a better big wagon to come out.
Reading my latest 4wd monthly, I note best 2006 4wd test in
which all main big wagons are lined up against each other.
As usual it was Landcruiser just ahead of 4.2 GU with usual
"lack of go" comments despite GU better chassis etc and coming up
last was the new discovery TD.
It looked really good and performed mostly ahead of the rest
up until its computer failed and the car had to be left behind
in Cape York.
There wasn't even a chance to fix or jury rig it, and the sad thing
is that last year in the same test the discovery failed also.
Robin Miller
FollowupID: 458423
Follow Up By: Blaze - Tuesday, Oct 17, 2006 at 23:30
Hi Will and Robin,
I did exactly what you guys have mentioned, I had a turbo diesel up till about 18 mths ago. Did the Simpson and the GRR in the time I owned the new model Turbo Diesel and at the end of it all, I sat down and worked out milages including services, (extra costs for diesel, filters, oil (larger volume) etc etc.) and it came out that in a 15,000k trip the petrol that I now own would have cost about $120 more. This isn't the best petro; you can buy either for economy. Add to that, I now have it with LPG also, over the same 15,000k's even taking into account the restrictions and cost of LPG in the outback, I am ahead $245.00 and most vehicles of the same model etc fitted with LPG cost about the same as a diesel. Other main advantage, I can now drive through sandy country just above idle admiring the scenery and the quiet and if a hill appears around a corner, hit the noise pedal and get going without having to wait till the turbo cuts in.
The only benifit I see diesels still having is for carrying fuel in the vehicle, mind you the new unleaded stuff needs a fair old spark to get it to ignite.
FollowupID: 458549
Reply By: stevesub - Tuesday, Oct 17, 2006 at 06:43
Bugger about the tow and repair. A couple of years ago, we were supposed to do the SImpson in the Troopy but we pulled out at the last minute due to medical reasons. At around the mileage we would have been in the middle of the Simpson, we had a gearbox/transfger case probelm which meant no drive. Are we glad we did not do the trip that time with these sorts of recovery costs.
As for which is cheapest to run, petrol or diesel, we have a 2000 Troopy (4.2 diesel non turbo) and a 2000 4.6l V8 Rangie. The Troopy does around 12l/100km and the Rangie 14.5l/100km under similar driving conditions.
With petrol being cheaper than diesel, which is cheaper to run and has lower maintenance costs? The Rangie.
But would I use the Rangie in the Simpson, no way, the Troopy eats it with fuel capacity (nearly double the Rangie capacity) and overall range and I am also a bit suspect about high tech full of electronics vehicles in harsh conditions, not to mention the hard to get in the outback and very expensive tyres on the Rangie, etc, etc.
Stevesub
AnswerID: 199515
Reply By: Member - Oldplodder (QLD) - Tuesday, Oct 17, 2006 at 07:52
Sorry to hear about your troubles.
I have met Theo in better circimstances to yours and always found him a helpful guy. I find it hard to to believe the tyre pressures he runs, reckons he runs about 10 psi on that trailer.
I have had bad fuel problems on most trips, but usually it is a lot of sand, dirt, rust and once hair (looked like cattle hair) blocking filters. Just seems to be my luck. Others often report no problems with fuel. Touch wood, I don't have similar problems with tyres.
I use a fuel additive on a regular basis for the bug. I had a friend with a sailing boat that got put in a very dangerous situation when his fuel was contaminated. He didn't find out until he was crossing the Tweed bar and the engine cut out. Luckily it was not a very rough day, and an easterly was blowing, and he sailed in, but otherwise it could have been a deadly combination. Scary enough at the time trying to control the boat in the following seas and trying to stop the boat broaching until he got all sail up.
So I have installed another filter just after the tank to catch those little problems in the fuel. And it is easy to get to and change tucked up next to the chassis. I still have the main filter as a back up.
Glad to hear you got out of the situation with out any physical injury, just (!!!) a seriously wounded back pocket.
AnswerID: 199522
Reply By: Member - Andrew W (SA) - Tuesday, Oct 17, 2006 at 08:07
In some senses you got out of it lightly CLC.
According to Dave Cox, a recent tow back to Birdsville for an F250 was an $8,000 job, and an Oka that was intending to be in our group and had a 310km tow to Birdsville after dropping the gearbox was down $5,000 (mind you he needed two troopies and a navigator vehicle in front to manage it).
It makes a good overhaul and service look very cheap.
Andrew.
AnswerID: 199525
Reply By: Willem - Tuesday, Oct 17, 2006 at 08:30
Yep, I heard of your problems as we were a few days behind you heading east and then north. One of the participants in our trek came out from Birdsville to meet us at Erabena Junction with the French line and told us of your misfortune.
Any rescue is the Simpson is fraught with costs. Some 15 years ago, long before the incumbent Rescue Mechanics of Birdsville, a bloke had a major mishap out beyond Poeppel Corner, and it cost him $3800 to be rescued. No doubt some of the costs are justified but then again it could be construed as profiteering at someone elses expense. Still there are risks involved for the rescuers.
I suppose that those of us who venture into these remote parts take the risk of mechanical or component failure in our vehicles and there is only so much that you can check before leaving home.
I had a Radius Arm retaining nut loosen and fall off 65km north of the French Line. By some miracle I had packed a nut with a similar thread into my toolbox and was able to remedy the situation. It could have been a worse, but it wasn't.
AnswerID: 199530
Reply By: Truckster (Vic) - Tuesday, Oct 17, 2006 at 09:35
Was that in the MQ? I would have taken all my gear off it and put the money towards a new truck, and left it with them.
AnswerID: 199541
Follow Up By: CLC50 - Tuesday, Oct 17, 2006 at 10:19
That idea was great but ,I have over $10,000 worth of extras,7 we had no where to fit it.
Have a look @ my rig & you will see my, if it was only the truck I would off
FollowupID: 458414
Follow Up By: stano - Wednesday, Oct 18, 2006 at 21:36
"Was that in the MQ? I would have taken all my gear off it and put the money towards a new truck, and left it with them."
Kewl.
FollowupID: 458720
Reply By: Kiwi Kia - Tuesday, Oct 17, 2006 at 13:23
If I read your story correctly you were closer to Mt Dare then Birdsville.
What repairs are available at Mt Dare and would it have been better to tow to Mt dare instead of Birdsville?
AnswerID: 199551
Follow Up By: Longreach - Tuesday, Oct 17, 2006 at 16:15
I thought that first and then re-reading, perhaps much closer to Birdsville. If $68 per km and $68 per hour, and the total was $4200, thats about 55 km and 7 hours or some similar variation isn't it ?
FollowupID: 458465
Follow Up By: Kiwi Kia - Tuesday, Oct 17, 2006 at 18:17
Well spotted Longreach.
I would still be interested in peoples opinion as to at what location in the Simpson would a recovery be best made from Mt Dare rather then Birdsville?
FollowupID: 458483
Follow Up By: Member - Phil G (SA) - Tuesday, Oct 17, 2006 at 22:14
Oodnadatta do vehicle recovery too.
On the Birdsville side, once you get on the K1 Line, either at Poeppels Cnr or the Rig Road you can head south to the Birdsville track and out of the desert easily. But getting to the K1 Line can be hard, as the dunes have had caps this year.
FollowupID: 458537
Follow Up By: Member - Andrew W (SA) - Tuesday, Oct 17, 2006 at 23:34
Whoever is at Mt Dare, Oodnadatta or Birdsville at the time will tell you.
I don't hear any of those blokes jumping out of their skins to do this, and the Birdsville guys clearly have more resources than the others.
Further, if you're heading South or East, your eventual (or revised ;-) destination may make a difference too.
Ciao for now
Andrew.
FollowupID: 458551
Follow Up By: Kiwi Kia - Wednesday, Oct 18, 2006 at 05:25
Phil G. & Andrew W., Thanks for your reply.
Perhaps this kind of information would be beneficial on trip notes eg. where the nearest assistance is located if you have trouble and the telephone numbers.
FollowupID: 458567
Follow Up By: CLC50 - Wednesday, Oct 18, 2006 at 14:30
The main trouble to get it tow to Mr Dare was picking the truck up as advise by Racq as they would tow the truck home if required from Birdsville not Mt Dare ,& I made the decisions to go with the others & enjoy the trip as a passenger & get a plane back from Alice Springs to Birdsville & not miss any of the trip we had planed ,but this did not work either, No direct flight to Birdsville except mail plane twice a week & all flights where booked for a week, I had to fly From Alice Springs to Darwin & then back to Brisbane then back to Birdsville But RACQ paid for these flights as I am in Ultra Care, & I was covered for $3000 per year
Note .RACQ does not cover National Parks roads
FollowupID: 458664
Follow Up By: Kiwi Kia - Wednesday, Oct 18, 2006 at 15:45
Thanks CLC50, I will be traveling that way next year and was interested to know what encouraged you to make your descision to go to Birdsville.
FollowupID: 458670
Follow Up By: Member - Brian H (QLD) - Thursday, Oct 19, 2006 at 15:20
CLC50 So RACQ does not cover you on National Park Rds ................. GEEEEEEEEEEZZZZZZZ it seems it depends on who you speck to, I was told I am covered on any road so long as I'm not competing in any competition.
Best I read the dreaded booklet and get the correct story ........ So you would not be covered in the Simpson as its a National Park .........bugger.
Brian
FollowupID: 458841
Follow Up By: Member - Andrew W (SA) - Thursday, Oct 19, 2006 at 15:31
To make matters more complicated the Witjira National Park covering most of the Simpson is in SA ... so presumably RAA cover for RACQ ...
nothing's simple.
FollowupID: 458845
Follow Up By: CLC50 - Thursday, Oct 19, 2006 at 16:18
Well when I first call the Racq,there statement was .They only cover gazetted roads in the hole of Australia,Not in a National Park (TRACK ) & as theo at Birdsville Shell is a RACQ Agent, they said the would tow my truck back to Sunshine Coast from Birdsville if required ,& they would flew me home to Brisbane from Alice Springs, as after I left the Truck I was then with others as a Passager to Alice Springs , then I went to the RACQ office Sun Shine Coast ,After the meeting with the manager ,there was a phone call to Head Office & after a long conversation they agreed to fly me back to Birdsville or bring the truck home. Well next part of Story which i have left out as goes on & on But if you are all Interested He it is,
As on the Monday,1st May, Morning I flew back to Birdsville with one of my sons to bring Truck Home , to check all the gear was still there , cleaned the Fuel tank & replace the fuel line. Well that was the Plan. RACQ said they would pay for my flight to pick up truck, or transport on a truck home.
As the service station said they wanted to replace the Injection system at a cost of $4500 , no way as I had just had them service before I left for the Trip,my diesel mech also said no way also .
Arrived in birdsville 2 o'clock ,Towed truck into caravan park & set up camp.
Next morning work started Tuesday, Wednesday work completed Started Truck running perfect . Then that noise Knock,knock---S-------- Hell shut it down was the quick statement.
Straight to the pub , Wednesday night to Thursday night, & every one new my troubles, Arranged for RACQ to bring truck Home as soon as possible.
Caught a plane to Quilpie on Friday morning & had to stay in Quilpie on Friday night, flew home Saturday,Cost for the trip $1200 ( well what's money) + drinks ???????
Well the truck did not arrive home till the mid June , 1 flood ,3 truck moves, Birdsville -Quilpie,Quilpie - Brisbane ,Brisbane-Sunshine Coast.Which RACQ Paid,
Now to fix the Knock ,New motor, short motor,new injector pump ,or new car these where the questions to be asked.
Well none of these thank goodness.
All required change oil & clean sump, Althrough I changed oil & filters before the trip, The sand dunes , the rough tow trip & a old truck the oil cleaned out the motor of all the internal grim & the oil was like tar & it had no oil pressure.
Well test drive time ,hell its vibrating like hell ,back to the drawing board. Bent tail shaft due to fork lift drivers lifting on to trucks ,of to tail shaft repairs Kunda park $127 .
Well 6th July test drive to Brisbane & back .PASSED.
THE OLD GIRL IS ON THE ROAD
Note: I have open the CLC50 FIRST NATION BANK for all my Trips, donations & Share Holders required
FollowupID: 458856
Follow Up By: Member - Andrew W (SA) - Thursday, Oct 19, 2006 at 16:31
That is one helluva story CLC. I guess RACQ paying to fix the bent tail shaft.
Perhaps we should approach Bendigo Bank for a 4WD'ers Community Bank?
FollowupID: 458858
Follow Up By: CLC50 - Friday, Oct 20, 2006 at 07:10
Hi Andrew
No did not bother I was just glad to get it on the road, & up Noosa North Shore Camping & fishing again, as @ 69 years young ,this is my home away from home.
FollowupID: 458937
Follow Up By: Mike Harding - Friday, Oct 20, 2006 at 07:43
Hmmmmm....
$5000 for a recovery, $4500 quote for a repair... it would seem Birdsville is not a good place near which to breakdown.
I'm glad your problems are over and thanks for the information.
Mike Harding
FollowupID: 458943
Follow Up By: Member - Andrew W (SA) - Friday, Oct 20, 2006 at 07:59
Hey Mike,
Let us know how you organise to choose where you have a breakdown ;-)
Recovery is an expensive business in anyone's language and the more remote, and the more difficult the terrain, and the more expensive the fuel and living costs, the higher you can expect the price.
What annoys me more, is the limited services and obscene prices on the Nullabor ... Birdsville, I can understand. The Nullabor is gouging by the monopolistic tendencies of the management of most of the businesses out there.
Andrew.
FollowupID: 458949
Follow Up By: LineB - Monday, Oct 30, 2006 at 22:01
Geez, you blokes got it tough. I remember our Cessnas coming in with a new transfer case when we needed it, landing just a half-dozen swales away after a waggle of wings to show us which direction they were taking, and the mechanics would get to and hook it all up and get the truck on its way and that was in 1963. Of course, we did things differently then. No tows needed for mechanical breakdowns, only if you couldn't make the crest of a dune. Mechanics on hand as well as dozers, so we had it pretty comfortably really. Pilots used the claypans safely. One trip through in recent years I heard the bloke at William Creek (Trevor someone) asking if our party would run up and down a few claypans in the Simpson to test out his chances of landing in the desert. Pshaw! CGG pilots were up and down every day after an exploratory wheeltouch and a lookback. Never did they want anyone to run up and down and break the crust. Tough? One of CGGs drivers, just one, looked at his odometer and told me he did 12000 miles on the French Line while we were working on it. That was just to Poeppels and back to Pedirka and Oodna. Yes, petrol driven AB160 Inter. Myself, I drove one of the five Chev Blitzwagons. We took three months, if you didn't know the history of the French Line.
FollowupID: 461340
Follow Up By: CLC50 - Monday, Oct 30, 2006 at 22:43
Hi Line B
I have ready a lot of true stories about the history of the French Line & have enjoyed them all.& I have always want to go there & I will be back, I have seen a lot of pictures of the old Blitz with large shed on with D9 pulling them out & cutting road though some hills to get through,
I also red the book about the first women to cross the desert Griselda Sprigg & Husband & later with family .The Book is called DUNE is a four - letter word
Great read.
As this my first time through the French Line , it was a eye opener to me ,and gave a lot of respect for you early guys who worked this area. Born in the bush around Lithgow, became a city boy age 12 returned to the bush later around the 1958 Tamworth area & it will always be in my blood,retuned city 1962 .I was born1937 Hell.
FollowupID: 461372
Follow Up By: LineB - Tuesday, Oct 31, 2006 at 15:53
G'day CLC
Good book, I agree. Reg had a plane and backup vehicles, dumps all prepared and ready as he went through and they rendezvoue'd at arranged points. CGG had an extensive backup on our go on the Simpson through the middle 10mths after Reg & Griselda but for both parties, having different objectives and time schedules, it still represented exposure and going in to the unknown with motor vehicles, Reg with 4WD and CGG with trucks and trailers.
I do regard Reg's feat as the greatest because he crossed without a track and had to stay mobile, going forward so he could meet his deadlines and not have people frantically looking for him. Also, he had his young son & daughter Doug & Marg along, making it a family disaster in the making if he put a foot wrong.
CGG on the other hand were a large party ambling through over 3mths over our own road made as we went along, never likely to get into serious trouble except for individual evacuations, but having an adventure all the same. While we put up with privations and minor irritations like barcoo rot and spinifex bites and sundry cuts, breaks and burns and went thirsty and smelly for a while, we were playing with very heavy and expensive plant and equipment that somebody else was paying for!
I suppose you could say French Petroleum were our RACQ on the French Line. The survey (getting us in and out) cost them 4m pounds - about $40m in today's money. You can understand why no one is going to try that again in the Simpson. Your trip though, was one nightmare after another. Top marks for hanging in there, CLC.
Kevin M
French Line
FollowupID: 461550
Follow Up By: CLC50 - Wednesday, Nov 01, 2006 at 07:05
Hi Line B
For your Interest
One of my sons works for Hunt Energy Drilling SA .as a chef, gee no more cooks out there these days. Site at the moment is some where near Moomba , Just moved the rig from outside Windorah to Moomba.
Also has worked for Century Drilling as a Chef.
Works 2 weeks on 2 weeks off, full pay for all weeks, works 14 days straight 10-12 hour days. The campies do all his cleaning / washing/& make the beds/All dodgers Air Condition,
20 trucks move Camps, with Auto Loaders, with some trucks 40 Wheelers,
Gee things have changed since the old Days
FollowupID: 461698
Follow Up By: LineB - Wednesday, Nov 01, 2006 at 13:38
All the same, he's earning his money CLC
Kevin M
FollowupID: 461756
