cb wire check
Submitted: Tuesday, Oct 24, 2006 at 22:43
ThreadID: 38795 Views:1890 Replies:5 FollowUps:0
hi all , can some1 help please, i traced the power from my cb from batt to a 40 amp circuitbreaker to the cb radio im not sure if this is right, previous owner done wiring. great forum im hooked been on for hours.
Reply By: raunchy - Tuesday, Oct 24, 2006 at 22:55
Hi 4wdnut,
Sound like it should work, does it?? 40 amp ccb is a bit of overkill for a CB, not gonna hurt it though. If you get a short it will trip so OK, the only problem would be if you hook the radio up to the power backwards, the ccb may not trip before the CB is baked.
Regard Ray
AnswerID: 200787
Reply By: Tony Middleditch - Wednesday, Oct 25, 2006 at 06:44
The 40 amp circuit breaker will only be OK if the cable connected to it is rated at 40 amps or greater. The radio should have its own protective fuse(s). Check to see if the circuit breaker is actually a DC type and not an AC type. Although an AC type will work on DC - the tripping characteristics are not necessarily correct.
Cheers, Tony - registered electrical contractor.
AnswerID: 200806
Reply By: 4wdnut - Wednesday, Oct 25, 2006 at 17:05
thanks for replies, looks like 4mm wire ,dc breaker,would it be betteer,and alright to run it of fuse box on15 amp fuse and ditch the circuitbraker. thanks.
AnswerID: 200888
Reply By: Tony Middleditch - Wednesday, Oct 25, 2006 at 17:42
If the wire is 4mm squared then the maximum circuit breaker size should be 32 amps. The circuit breaker should provide better (quicker) protection than a fuse.
The circuit breaker is there to protect the cable and not the radio. A smaller fuse (about 5 amps) is required at the radio.
Note that there is much confusion in regard to the size / ratings of electrical cables and automotive cabling.
See ABR information on the Exploreoz site.
Tony.
AnswerID: 200900
Reply By: 4wdnut - Thursday, Oct 26, 2006 at 18:24
thanks for the advice everyone.
AnswerID: 201080
