12HT cooling problem
Submitted: Monday, Mar 17, 2003 at 16:30
Lyndon
Guys, quick question regarding my 12HT cruiser cooling. When the ambient air temperature is below 20 degrees C, my cruiser will run into the red on the temp gauge then fall back to mid scale where it normally sits. It does this, every time I drive it early in the morning. I have replaced the thermostat with a genuine Toyota part, and found the aftermarket thermostat was placed upside down in its housing. But this morning it again ran into the red briefly and fell back to normal. The LC is in excellent condition still has its original radiator core. The ambient air temp can be 40 degrees plus with both air con units running and the temp needle wont move from mid scale.
Do I have a very sensitive temp gauge, as I'm at a loss as to what it could be. It's not very pleasant seeing the temp gauge run so high, even if it is for only a brief time. Thanks in advance.
Reply By: crfan - Monday, Mar 17, 2003 at 17:27
If you have done all the normal checks I would stat to look at the gauge
sender and wiring.(maybe colder air temp may not help wiring ie moist air)
15381
Reply By: GaryInOz - Monday, Mar 17, 2003 at 18:01
Might be a blocked heater core? Test by seeing if heater outlet temp is warm (fan on low) periodically for the first few minutes after start-up. If the outlet air is cool, then "short-circuiting" the
water to the heater core would be the definitive proof by removing the restrictive core. It should then warm up normally. If it doesnt then the problem is elsewhere.
15385
Reply By: Member - Peter- Monday, Mar 17, 2003 at 22:16
The same sympton can be caused by either a blocked or restricted radiator or a faulty fan clutch.
What happens when the radiator is either blocked externally by mud /
debris or internally by corrosion/
debris is that the thermostat will sense the increased
water temp (your heat spike) and open and because the
water isn't as cool as it should be from the radiator it stays wide open to maintain engine temp.
When the cooling system is in good condition the thermostat will 'cycle' opening and closing to varying degrees in response to coolant temperature changes but when the cooling system is partially blocked it has to stay wide open to allow enough coolant through.
In your case as it seems to only happen on first startup I would suspect the radiator/cooling system if there is nothing wrong electrically with the gauge.
Going to the trouble of removing the radiator and having it mechanically cleaned by a radiator place would be far cheaper than an engine rebuild.
15420
Reply By: Truckster - Monday, Mar 17, 2003 at 22:44
WHEN ITS 20 BELOW C!!!!!!!! WHERE DO YOU LIVE!!!!!
What model car is it in?
Sounds like a dodgey temp guage or sender to me.
My GQ did the same with the temp sender was dead... $40 for a new one (ouch), and its good to go.
Maybe get the radiator checked for blockages, and physically remove the rad and hose it out, turn it upside down and hose from the bottom of the rad so it comes out the filler cap..
Lots of thigns you can spend $100's on this, I know I did :(
15425
Follow Up By: GaryInOz - Tuesday, Mar 18, 2003 at 02:18
Ummmmm, below 20, not 20 below!
9399
Reply By: Phil G - Wednesday, Mar 19, 2003 at 22:35
Lyndon,
I went through all that drama with my old 12H-T. I am 99% sure that your problem is the same as
mine.
The voltage regulator which supplies power to the dashboard temp guage is a primitive bimetallic thing, that gets sticky contacts. Now the trick is that this voltage regulator is located within the fuel gauge and supplies power to both fuel guage and the temp guage (check your wiring diagrams).
Two options - remove the fuel guage from the dash and clean up the regulator contacts (a little tricky) or buy a new fuel guage (which contains the regulator).
I replaced the fuel guage and never had a problem since!
15640
Follow Up By: Lyndon - Thursday, Mar 20, 2003 at 07:04
Thanks Phil, will look at the fuel gauge.
Lyndon
9519
Reply By: Mark from Getaway Portable Refrigerator Hire - Thursday, Mar 20, 2003 at 13:44
Lyndon, Agree with Phil. Had the same problem but it occured as I was driving along which was a bit nerve racking as I had to stop each time to make sure that it was that problem and not a blown hose. Auto electrican replaced fuel gauge (or voltage thing) and problem solved.
15677
