Snowys to Perth
Submitted: Monday, Mar 17, 2003 at 18:03
ThreadID: 3897 Views:1484 Replies:2 FollowUps:3
G'day there. I'll be driving from the snowy mountains to Perth after the snow season ends, and i'm trying to estimate how much fuel and supplies i'm going to use. So does anyone know around about how many klm's that would be? I plan on going prety much straight from A to B unless i find out some interesting places in SA before then. Thanks, Andrew..
Reply By: Andrew - Monday, Mar 17, 2003 at 23:54
Have a look under this sites home page at 'Smart trip'
You can put in your 'from and to' location around Australia and it will give you the distance pretty much spot on. You should be able to work out you fuel usage and costs from there if you know your vehicles consumption.
regards
Andy
AnswerID: 15448
Reply By: Andrew - Tuesday, Mar 18, 2003 at 00:15
Sorry Andrew...
That should have said look up 'travelmate.com.au'
AnswerID: 15451
Follow Up By: Andrew - Tuesday, Mar 18, 2003 at 19:52
Thanks mate, I did try and use the drop down menus but couldnt find anything. Cheers.
FollowupID: 9420
Follow Up By: Andrew - Tuesday, Mar 18, 2003 at 23:42
Tray again Andrew, sometime it does that, but usually only once.
FollowupID: 9441
Follow Up By: Andrew - Wednesday, Mar 19, 2003 at 17:42
All is good now. The answer is 3980 klms from Jindabyne to Perth. Just in case you wanted to know! Thats a pretty handy site, thanks for the lead. Andrew.
FollowupID: 9479
