Site Search
Section Image
nissan gq diesel rough when starts
Submitted: Wednesday, Nov 01, 2006 at 18:58
Miss'n Nissan
Anyone got any ideas why my trusty nissan '92 GQ diesel, sometimes starts really roughly.I rev her up and clear the smoke and it seems to run fine then. She runs beautifully except for the start ups, and that doesnt happen all the time either. But it is becoming more regular. Its a bit like it is starving for or blocked for fuel. Don't think it is the injectors, she runs too well when driving. Cheers
Advertisement
ThreadID: 39044 Replies: 8
Views: 584 FollowUps: 8
AnswerID: 202351   Submitted: Wednesday, Nov 01, 2006 at 19:07
Member - Shane D (QLD) replied:
glow plugs
Northern rivers sunrise (NSW)
Click Image to Enlarge
um. . . . um. . . . no. . . I got nothing
Reply 1 of 8
AnswerID: 202357   Submitted: Wednesday, Nov 01, 2006 at 19:39
Peter 2 replied:
If the glowplugs check out ok you may have a very minute airleak in the fuel system which is allowing a tiny bit of air in when left standing. Does it depend on how long the motor has been off?
Madigan Line 07
1988 M1026 Humvee
Reply 2 of 8
FollowupID: 461927   Submitted: Wednesday, Nov 01, 2006 at 22:40
Miss'n Nissan posted:
thanks Peter, it seems to do it when left overnight. I have replaced the fuel filter, just waiting till the morning now to see what happens. I think may have over tightened the last one and the rubber seel wrinkled and let in air. Hope it was as simple as that. Will get back and let you all know the out come. thanks to all for the input.
FollowUp 1 of 4
FollowupID: 462379   Submitted: Friday, Nov 03, 2006 at 11:53
Well, I have put a new fuel filter in, tightened it ever so gently so as not too squash or wrinkle the rubber seal, waited overnight, started her up... NO PROBS SO FAR.
she started no worries.I've got my fingers crossed that she will continue that way.I think that may have been it.(TOUCH WOOD). I will get back to you if there is any change. Thanks All
FollowUp 2 of 4
FollowupID: 462571   Submitted: Saturday, Nov 04, 2006 at 09:11
STARTED NO WORRIES AGAIN, I think that was the problem. **phew** thanks again for all the suggestions.
FollowUp 3 of 4
FollowupID: 465365   Submitted: Thursday, Nov 16, 2006 at 21:06
THAT WAS THE PROBLEM, been 12 days now, starts and runs like she used too. That damn over tightened fuel filter ! won't do that again.
FollowUp 4 of 4
AnswerID: 202358   Submitted: Wednesday, Nov 01, 2006 at 19:46
666toy replied:
g day
you might be having probs with the glow plug timer . this seems reasonably common with the beautiful td4.2 (i love dinosaure donks give me push rods any day) try glowing the donk 3 times before starting when cold . if the timer is at fault you can get buy doing this for quite some time with no after effects . (i think the timers a very expencive however not really sure ) A WORD OF WARNING do not replace with a second hand unit. change glow plugs first then if no improvement try the timer . I think its hidden behind the glove box. hope this helps................................................................................. 666toy
Reply 3 of 8
AnswerID: 202364   Submitted: Wednesday, Nov 01, 2006 at 19:58
Member - Jiarna (NT) replied:
I'm not sure if the GQ is the same, but my MQ used to be the same. Turned out that the servo motor on the injector pump that selects off-start-run fuel settings was sluggish. I replaced it and it went back to being easy and smooth to start.
Crossing the Palmer River on Cape York
Those who say something cannot be done should not interrupt the person doing it.
Reply 4 of 8
Activities Index
Full Day Fly Fishing Tuition - Judbury, TAS Full Day Fly Fishing Tuition - Judbury, TAS
Hobart - TAS
Our introductory Fly Fishing classes offer comprehensive instruction in essential fly fishing skills
The Sydney City Tour (231) The Sydney City Tour (231)
Sydney - NSW
This tour is the quintessential introduction to Sydney, making its way around the city (with a stop
Poker Tournament Poker Tournament
Melbourne - VIC
For an event with style and excitement, why not host your own poker party or poker tournament.
Competent Crew - 5 Sailing Lessons Competent Crew - 5 Sailing Lessons
Sydney - NSW
This course is designed to meet the needs of people with some sailing experience who want to improve
Book Now - Things To Do
AnswerID: 202393   Submitted: Wednesday, Nov 01, 2006 at 21:20
barney rubble replied:
Gday miss n nissan good chance it could be your injectors leaking into the engine when the engines off as they still have to hold pressure the excess smoke on start up also points to this Good luck & keep cruisin
Reply 5 of 8
AnswerID: 202412   Submitted: Wednesday, Nov 01, 2006 at 22:38
Truckster (Vic) replied:
I'd say air leak.. when I changed my fuel filters and didnt prime it properly, this exact same thing happened..
Reply 6 of 8
FollowupID: 461928   Submitted: Wednesday, Nov 01, 2006 at 22:42
That could be it too, thanks will let you know.
AnswerID: 202416   Submitted: Wednesday, Nov 01, 2006 at 22:47
Darrin replied:
My HZJ75 does something similar every so often, particularly if it hasn't been started for a few weeks.
I,ve been lead to believe its due to a small air leak-been doin it on and off for about 5 years.
Darrin
Reply 7 of 8
AnswerID: 202425   Submitted: Wednesday, Nov 01, 2006 at 23:56
Bilbo replied:
I'd say glow plugs first. Small air leaks are damn hard to track down. My TD42 used to be rough starting when I was in a hurry or forgot to wait fer the glow plug light to go out.
If you find that the glow plug timer has failed. Don't buy a new one - they aren't cheap. Just disconnect the wiring from the timer and replace it with a simple push button. This push button should be wired into the LOW amp side of the glow plug relay. The other cables that go to the glow plugs themselves are HEAVY DUTY wire. They carry a lot of current.
Just hold the push button in for say 10 seconds and then hit the starter.
Bilbo
Remember - "Tomorrow is todays best labour saving device!"
Reply 8 of 8
FollowupID: 461972   Submitted: Thursday, Nov 02, 2006 at 07:14
traveller2 posted:
Don't try 10 secs with your Chev Bilbo, the glowplugs are toast after 6-8, BTDT.
FollowUp 1 of 3
FollowupID: 462613   Submitted: Saturday, Nov 04, 2006 at 16:51
Bilbo posted:
What does "BTDT" stand for?
"Before Top Dead Threepence"?
"Behind That Dead Tree"?
"Bust The Door Through"?
"Big Tanned Dangly Teats"?
What??
Bilbo
FollowUp 2 of 3
FollowupID: 462878   Submitted: Monday, Nov 06, 2006 at 07:52
traveller2 posted:
Bilbo, you got a few good ideas for BTDT but is usually means " Been There Done That"
FollowUp 3 of 3
 Page Sponsors
Phone: 1800 21 21 21
ExplorOz ExplorOz
Phone: (08) 9403 3737
More info | Website
