Radio comms
Submitted: Tuesday, Mar 18, 2003 at 00:08
ThreadID: 3905 Views:2269 Replies:8 FollowUps:17
When it come to radios..I'm iliterate.
Doing the round Aus thing later and want to be able to communicate with others. The norm is a CB (UHF)?? am I right???
WHY??
What's the difference between this and HF for safety/reception/price???
Please reply like I'm the dumbest bloke you've ever spoken to. It'll help me work throught the maze. I would like to know a bit about what i'm talking about when I buy one..
Thanks in advance .
Reply By: Truckster - Tuesday, Mar 18, 2003 at 00:24
HF will get further than UHF.
Its also what you use to call for dire need help, like the Flying Dr's. HF you need a license unless your on http://www.vks737.on.net/
You also get weather reports and stuff on HF from what Ive been told.
HF is something you will have to be trained to use, or at least shown, against UHF is just press and talk.
UHF you use as Car to Car. It also gets respectable distance, but HF is a must in the ourback.
HF is bleep in expensive, look in the trader section... also look in Links section of 737 site for more info.
AnswerID: 15453
Follow Up By: Andrew - Tuesday, Mar 18, 2003 at 00:51
Thanks truckster...understood.
FollowupID: 9390
Reply By: GaryInOz - Tuesday, Mar 18, 2003 at 00:56
UHF pros: short antennas (477 MHz) 0.6 metres and up
good car-car communication
slowly increasing number of radio repeaters
UHF cons: not good for isolated area communications
more expensive than 27 MHz "CB" radios ($300-500)
27 MHZ pros: relatively cheap ($100-300)
good distance possible, especially on SSB
27MHz cons: need long antenna to be effective (PITA in underground
carparks) typically 1.2-1.8 metres
HF pros: Good australia wide range
Essential services available directly
HF cons: Heavy large antenna base 150mm diameter x 300-350mm high
Expensive +++
license as noted above (but its not really worth having a radio if
you aren't allowed to use it, is it?)
Antenna (as per 27 MHz)
Also be sure to get insurance cover on all comms equipment. (theft/damage, especially water damage)
Carry a spare antenna for each of the radios. (theft/breakage)
Carry two radios.
AnswerID: 15457
Follow Up By: Andrew - Tuesday, Mar 18, 2003 at 01:14
Gary
OK, you confused me a bit on the 27meg Vs CB Vs UHF
I thought UHF and CB were the same???
I guess your saying that a CB is a 27meg and UHF is different?
Anyway, looks like I can forget the HF......so cutting to the chase....what's best all round option for travelling this great country if I'm not going to the never never?????
Andy
FollowupID: 9391
Follow Up By: Member - Motley - Tuesday, Mar 18, 2003 at 08:26
Gary,
Regarding your comment on insurance. I am fitting an HF Radio. Is it separately insured, and if so, who offers this sort of insurance, or is it an extra on the vehicle policy?
FollowupID: 9401
Follow Up By: Truckster - Tuesday, Mar 18, 2003 at 10:01
Nope.
27 meg and CB are the Same.
UHF is a different thing all together.
www.gme.net.au
FollowupID: 9405
Follow Up By: GaryInOz - Thursday, Mar 20, 2003 at 17:34
Motley, Im not sure, but if you contact your vehicle insurer they may be able to point you in the right direction. Some agreed value type of policies can be extended to cover accessories etc (most reputable 4WD type policies such as that offered through your state 4WD association), most replacement value policies may not cover you eg. AAMI as it is viewed as a "modification".
FollowupID: 9560
Reply By: GaryInOz - Tuesday, Mar 18, 2003 at 01:38
Sorry for the confusion. Originally Australia started with 27 MHz "CB" radios similar to what the Americans had. Then the Government in their infinite wisdom wanted everyone to migrate to 477MHz "CB" radios that almost no-one else in the world uses. People didn't move voluntarily as both systems have their good and bad points depending on how and where they are being used. Thus we now have two "CB" radio systems coexisting.....and then we have the HF radios which, as you have noted, are a different kettle of fish entirely!
AnswerID: 15460
Follow Up By: Andrew - Tuesday, Mar 18, 2003 at 01:42
So which "CB" is the one to get Gary??? 27 or 477
FollowupID: 9392
Follow Up By: GaryInOz - Tuesday, Mar 18, 2003 at 01:50
Re-read your Q. If you are not going to go too far off the beaten track then one 27 MHz preferably with "SSB" (another discussion!) and one UHF. This will also allow you to act as a "repeater/translator" for other people in trouble.. If you do intend to venture off the beaten track then the sound advice would be to have a HF radio and one or both CB radios. Yes, it is expensive, but you can be dead in a matter of hours after a relatively minor accident in the outback with a disabled vehicle....who would know 250 km from anywhere?
FollowupID: 9393
Follow Up By: Andrew - Tuesday, Mar 18, 2003 at 01:53
Thanks Gary, you have been a big help.
You too Truckster.
FollowupID: 9394
Follow Up By: Andrew - Tuesday, Mar 18, 2003 at 01:57
Sorry Gary..One other thing..
Can 27meg cb communicate with a UHF within reasonable distances or is it "specific coms to specific coms"??????
FollowupID: 9395
Reply By: GaryInOz - Tuesday, Mar 18, 2003 at 02:01
Reason for two radios is safety. If one or other of the radios dies you at least communicate. Likewise if you should break an antenna (and your spare antenna, you will carry one wont you?) you should still be able to communicate using the other radio.
It's a bit of a PITA but its worth spending the money to get it right, you're only talhing about $400-800 total.
AnswerID: 15461
Follow Up By: GaryInOz - Tuesday, Mar 18, 2003 at 02:02
27-27 and 477-477 only thats why you have one of each.
FollowupID: 9396
Follow Up By: Andrew - Tuesday, Mar 18, 2003 at 02:06
Told you I was 'radio dumb' didn't I.
FollowupID: 9397
Follow Up By: GaryInOz - Tuesday, Mar 18, 2003 at 02:15
"There is no such thing as a dumb question, Just dumb people that ask them", ABSOLUTELY NO OFFENCE INTENDED!!! (I dunno where I heard that but I've been itching to us it somewhere!)
Cheers Andrew and best of luck with the trip.
FollowupID: 9398
Follow Up By: Member - Mal - Tuesday, Mar 18, 2003 at 10:33
Gary in OZ,
It's..............................................just dumb people that DON'T ask them.
Mal T.
FollowupID: 9406
Reply By: Truckster - Tuesday, Mar 18, 2003 at 10:05
To confuse you more :)
you can get radios that have UHF and 27 meg in one, but wouldnt recommend them.
They only can talk/listen to 1 freq at a time.
If I was travelling outback style, Id hire a HF, and I already have UHF and 27meg in the truck. But if I didnt I would only carry UHF (our club std radio here...)
HTH..
Oh and as the other bloke says no such thing as a dumb question, the only dumb question is one not asked.
AnswerID: 15469
Reply By: Member - Mal - Tuesday, Mar 18, 2003 at 11:09
Andrew,
If you are travelling mainly around the popular parts of Australia all you need is an Ultra High Frequency (UHF) Citizen Band (CB) radio.You will be able to talk to trucks, most 4WDs, some cars, most Homesteads and most Service Stations. The most popular Channel is Ch 40.
If you decide to cross the Simpson Desert, do the Canning Stock Route etc you need either a High Frequency (HF) radio or probably better in your case a Satellite Phone (which is still a radio) which you can buy for about $1,000 and will communicate from everywhere. You can even hire them in some remote areas such as the Birdsville Police and you return it to the Oodnadatta Police for a crossing of the Simpson. The other thing you should carry is an Emergency Position Indicator Radio Beacon (EPIRB) which you use as a last resort in a real emergency. When you activate an EPIRB it sends out a signal via satellites and aircrafts that allow the Authorities to loate you hopefully in a couple of hours. They cost about $300.
Personally, I love my HF radio.
Have a great trip.
Mal T.
AnswerID: 15474
Reply By: Member - Peter- Tuesday, Mar 18, 2003 at 11:39
HF dosnot have to be expensive , I have just installed an older unit from a person that does them up it cost me $600.00 I have contact with the 4wd network and flying doctors now its just another thing to set my mind at rest in the outback.(if you want a contact in W>A for good second hand phone me W.A 96411600 Peter York 4x4
AnswerID: 15479
Reply By: Member - Cocka - Tuesday, Mar 18, 2003 at 22:16
This forum is fantastic. The quality of the questions and the integrity of the answers supplied is supberb, more power to you fellas for the help you give and three cheers to David and Michelle for the work they put into the site. If I ever get the chance to cross tracks with you in the outback I'd love to shout you a lemonade.
And Andy, never worry about asking questions. I used to tell my kids that no body was born knowing everything they know today, it was all learnt over time by questions and listening.
Look at Truckster, he was born a dumb baby but his mother still loved him, now look at him, a veritable font of knowledge and wisdom. There is hope for everyone.
AnswerID: 15527
Follow Up By: Andrew - Tuesday, Mar 18, 2003 at 23:40
Never a truer work spoken about Truckster there Cocka!!
I agree with you about the forum, just fantastic. As a result of my question, I've gained a good grasp on what I want and need.
Excellent help from everyone who replied to this question, except some sarcasm from truckster, but he can't help himself.!!!
Cheers everyone for their help....
Andy
FollowupID: 9440
Follow Up By: Truckster - Wednesday, Mar 19, 2003 at 10:00
Can you point out the sarcasm to me, Im missing it.....
FollowupID: 9453
Follow Up By: GaryInOz - Thursday, Mar 20, 2003 at 17:24
Andrew, I think you will find the sarcasm came from me.
With implied apologies to truckster for "carrying the can".
FollowupID: 9557
Follow Up By: Andrew - Friday, Mar 21, 2003 at 01:52
Sorry Truckster, no offence intended to who ever it was anyway.
Everyone is great help
Thanks again
Andy
FollowupID: 9596
