TX3200 fitment
Submitted: Tuesday, Mar 18, 2003 at 12:07
Does any one have ideas where to install a TX 3200 radio in a 100 series l/cruiser standard model, type of console or other please.
Thank You Peter
Reply By: Member - Lex - Tuesday, Mar 18, 2003 at 12:34
Check the Outback overhead console. Beautifully made /fits well/minimal number of holes to drill. Will accommodate a couple of radios plus other bits and pieces plus has reading lamps installed
15483
Reply By: Cashy - Tuesday, Mar 18, 2003 at 12:59
My TX4400 fits really
well in a Dept of the Interior roof console along with the HF unit head. Looks like a factoy fitting and the map lights are great.
Cashy
15485
Follow Up By: Peter - Tuesday, Mar 18, 2003 at 13:38
Thanks cashy and lex, any idea where these might be available in
Adelaide? TJM, ARB or other.
Thanks again Peter
9412
Reply By: KiwiAngler - Tuesday, Mar 18, 2003 at 15:01
I have a TX3200 in my Holden
sedan and a TX4200 in my 100 series. Rememeber the TX3200 is different to the 4000 series in as much as it has its controls 'remote' from the actual radio. I have mounted the unit under my
seat in the Holden with the unit in the little space directly in front of the gearshift. I have just looked at the 4x and I reckon you could do the same there. Unit under drivers
seat, remote control in the small recess in front of the main stickshift.ou would only need 2 small holes for the bracket if you chose that option (plus the holes under
seat for main unit)
having said that I also have the Outback overhead console in the 100series with the TX4200 mounted in it...and the other guys are dead right the map lights, storage area and location of the radio in the console are great.
I guess I would say...if you can afford the overhead console that would be the best option, if not try the under
seat option. If you like I can send you a pic of my 4x setup and my
Sedan setup?
Rubberside down...shiny side up
15487
Follow Up By: Darryn - Tuesday, Mar 18, 2003 at 17:12
Kiwi, your thinking of the TX3400 with the remote head, the TX3200 is the small "slimline" base model GME.
Regd's Darryn
9415
Reply By: Cruiser - Tuesday, Mar 18, 2003 at 15:06
I have a TX3200 fitted to my 100 Series Std Cruiser. You can buy a facia plate for the TX3200 (about $20) that enables the TX3200 to be installed into a DIN sized socket.
Remove the little tray from under the factory radio and install the TX3200 in there.
Can send you pics of my install if you like.
15488
Follow Up By: Peter - Wednesday, Mar 19, 2003 at 03:17
Cruiser,
Thanks, that would be appreciated if you could send me a picture of your install. My email is lezandpete@ozemail.com.au
Cheers Peter
9444
Reply By: Kev. - Tuesday, Mar 18, 2003 at 22:12
Can't you just mount it under the dash using the mounting bracket supplyed ?
The 3200 is quite small so it shouldnt be that bad.
15526
