2 part epoxy
Submitted: Tuesday, Mar 18, 2003 at 13:51
Voxson
Apart from araldite,, the other 2 part epoxy i use and have used is called "knead it"....by selleys........
Sold at most hardware shops... It is your typical dough style epoxy which you cut off as you need it but it comes in various types...
(marine, steel, general purpose etc etc.)...
Just in case anyone wanted to know......
Regards......._____________________________________________
Countin the days till July 5th. *
Cape York Trip*
Reply By: Suzuki Viagra - Tuesday, Mar 18, 2003 at 19:52
Tried it to patch my fuel
tank but it didn't hold long term - but a handy emergency solution. Anyone else got any ideas on what to use to stop the
tank leaking now?????
15501
Follow Up By: rojac - Tuesday, Mar 18, 2003 at 22:50
Cracked a
tank on a hq on the gulf track between boroloola and
roper bar.
Fix
1. drain whatever is left in
tank
2. get beer can, drink contents, cut in into a square to cover crack in
tank.
3.sacrifice hanky, not important if not clean.
4.mix two part epoxy, in our case it was for concrete repair.
5. press beer can square onto base of expoxy smeared on
tank, then place hanky on sqaure and build up as in fiberglassing.
6.messy as hell but after it set it lasted kakadau then
tank replaced in
Darwin.
I reckon it could have lasted the trip home.
Rob
9439
Reply By: sensei - Wednesday, Mar 19, 2003 at 00:33
grab a bar of soap, make some flakes from the soap, add spit or a drop of
water with a little bit of fine sand or dust and nead it into a doe. Then poke it in the hole...If that falls then chewing gum works
well and if you have teenager kids as I do then gum is not a problem..haha
15548
Reply By: Matt M - Wednesday, Mar 19, 2003 at 17:56
Have used a knead it type
putty made by chem search I think it is called liquid metal! Very easy to cut and then knead till it starts to warm and then apply, ready to drill, cut, file etc in a minute or two. I used it to seal an inch hole left in my exhaust manifold till I could make a cover plate! I made the cover plate months ago, but the
putty is still there, havent got around to changing it yet!!
Tough stuff and nearly as good as metal!
Matt.
15599
Reply By: Yonnee - Thursday, Mar 20, 2003 at 22:16
Loctite do a two-part
putty that's actually called "Radiator and Petrol
tank repair
putty". Designed specifically for the use of fixing cracks and holes in steel radiators and fuel tanks. Retails for less than $20 at most auto shops.
Cheers, Yonnee.
15739
