Seat for 79 series ute
Submitted: Tuesday, Mar 18, 2003 at 17:49
Roger
Folks, I want to replace the 3/4 bench
seat with a bucket
seat. Short of paying an arm and a leg for an aftermarket one, do any other model seats fit with a min. of effort? If so, which wreckers would be likely to carry one, I'm in North Queensland. I realize that the compliance plate must be modified.
Reply By: Truckster - Tuesday, Mar 18, 2003 at 20:59
Probably out of a 75 or 80 series... look at a few at wreckers and the mounts..
there was a good one on Ebay a while back, for a 75...
15512
Reply By: fatboy - Sunday, Mar 23, 2003 at 16:11
Hi Roger , have gone through the same dramas changing the 3/4
seat in my hilux , found that you can use any
seat in there that fits . But you must use the original slides , mount points etc , you just adapt the new seats to your slides with two pieces of 50 * 5 mm flat bar drilled and bolted to your slides and drilled and bolted to your new
seat . Hope this helps
15909
Follow Up By: Roger - Monday, Mar 24, 2003 at 13:18
Fatboy,
Sounds great, thanks alot.
Roger
9757
