Site Search
Section Image
Electric toaster and kettle
Submitted: Friday, Nov 03, 2006 at 08:05
Cammo
Morning all
I have just got back from 6 week stouring the east coast with the family. We stayed in caravan parks with powered sites. As a result we were using a electric toaster and kettle. this made breakfast time for the kids very easy.
I am now going away this long weekend, but am bush camping. I was wondering would an pure or modified sine wave inverter help be to be able to continue use my toaster and kettle. Given the kettle proabably uses about 2000watts and the toaster about 1000 watts is this even possibe ?
Sounds a bit soft, I know, but any help in this regard would be appreciated.
Cammo
Advertisement
ThreadID: 39115 Replies: 6
Views: 1246 FollowUps: 12
AnswerID: 202769   Submitted: Friday, Nov 03, 2006 at 08:49
ZUKSCOOTERX90(QLD-MEMBER) replied:
Cammo,depends on what your inverter is rated at,also how big the battery capacity is.If all seems relevent try before you go.
Cheer's Bob.
Click Image to Enlarge
BlueOval F250 7.3 Deisel.
I was born Free. 'That's as good as it's got.'
Reply 1 of 6
FollowupID: 462337   Submitted: Friday, Nov 03, 2006 at 08:56
Cammo posted:
Thanks for your response. I haven;t bought an inverter yet. I don't want to spend much (surprise surprise) so I guess I was wondering if i got a 500w (surge to 1000w) modified sine wave inverter from jaycar, would that power the toaster ? I am happy to live without the kettle.
I am dummy when it comes to electrics. So given that the specs of the taosetr say 1200 watts, if an inverter can only supply 1000watts will it still work but just take longer ? Or will stuff start to blow up and catch fire ?
Cameron
FollowUp 1 of 2
FollowupID: 462377   Submitted: Friday, Nov 03, 2006 at 11:39
GaryInOz (Vic) posted:
Cammo, the normal rated output of the inverter HAS TO BE higher than the items you are plugging into it, no "if's", "but's" or "maybe's". Normal 2 slice cheapie toaster needs about 1000 watts (Just loooked at mine), normal electric jug 1500 watts.
Stick with a small $25 portable stove, a $2 gas bottle to suit, and a $2 wire mesh toaster rack. All available from Kmart. and it will still boil your $5 kettle too.
Those wire mesh toasters work a treat, quicker than an electric toaster any day, albeit one slice at a time.
It really sounds like you are trying to use sledgehammers to crack peanuts.
An inverter suitable to do the job is going to be upwards of $500, probably more like $7-800, then the extra battery to go with it and double battery management system, extra cabling, etc, etc, etc. All for a piece of toast in the morning?????!!!
FollowUp 2 of 2
AnswerID: 202771   Submitted: Friday, Nov 03, 2006 at 08:56
Mike Harding replied:
I would not entertain using such appliances from a camping inverter type setup. The toaster (1000W) will draw around 85 amps from your battery.
A gas kettle and a $5 toast holder for the gas stove will do the job.
Mike Harding
Reply 2 of 6
FollowupID: 462338   Submitted: Friday, Nov 03, 2006 at 08:57
Cammo posted:
Thanks Mike
I suspected as much.
FollowUp 1 of 8
FollowupID: 462342   Submitted: Friday, Nov 03, 2006 at 09:14
Batboy posted:
1000w toaster will only draw 85amp/hrs off the battery plus loss through inverter usually around 10% if you run it for an hour and as a toaster is only on for a few minutes this should be no problem. 5 mins would equal approx 7amp/hrs plus inverter losses
Cammo you will need at least a 2000 watt inverter. I believe the surge rating is only for very short times to account for start up currents of small motors etc
Personally The jugs not worth it but the toaster maybe. All the toaster contraptions I have tried failed miserably except for the one you hold above the fire :)
Cheers Jim
FollowUp 2 of 8
FollowupID: 462345   Submitted: Friday, Nov 03, 2006 at 09:21
Mike Harding posted:
That's why I said 85A and not 85Ah.
Yes it can be done - in situations that rely on inverter power it often is but it will require heavy cable and lugs etc on the DC side not to mention a battery which is capable of sustaining 85A for 10 minutes in addition to 1500Wish inverter. All this for a bit of toast which you could do more quickly over the gas!?
Mike Harding
FollowUp 3 of 8
FollowupID: 462346   Submitted: Friday, Nov 03, 2006 at 09:22
Ron173 posted:
I'm with Mike,
Both are a bit heavy for an inverter, and even if you had a big enough inverter, the current draw on battery would be shocking, not to mention heat in cables.
Stay well clear, go gas, you can actually buy some pretty good toasting devices specifically designed to sit on a gas ring.
Saw one recently was ceramic bottom with a gauze section for the toast to go in, $15.
Ron
FollowUp 4 of 8
FollowupID: 462348   Submitted: Friday, Nov 03, 2006 at 09:25
Cammo posted:
Thansk Mike, Ron and Batboy for your responses. I think you are right when you say it is all a bit much for a bit of toast.
FollowUp 5 of 8
FollowupID: 462350   Submitted: Friday, Nov 03, 2006 at 09:39
Batboy posted:
Just being clear Mikey
Plus I am a qualified smartass so had to put my $50.00 in
Jim
FollowUp 6 of 8
FollowupID: 462351   Submitted: Friday, Nov 03, 2006 at 09:40
I like it :)
FollowUp 7 of 8
FollowupID: 462374   Submitted: Friday, Nov 03, 2006 at 11:16
wazzaaaa posted:
Well I'm told I'm a smart ass but I'm also told I've got no brains so I guess that just leaves "ass" and I'm broke so I can only put my 2c worth in.
My kids insist on taking the toaster camping and my wife insists on taking the electric jug so every morning I have to fuel, check the oil start the generator just for breakfast in the time it would take to use gas. When I go with mates toast tastes the same over a gas flame to me and I don't mind waiting for the gas kettle to boil but to keep everyone happy that is the way I do it.
wazzaaaa
FollowUp 8 of 8
AnswerID: 202791   Submitted: Friday, Nov 03, 2006 at 10:42
TerraFirma replied:
Your best bet is to shop around for a kettle that is around the 1200watt mark, I think there may still be some around. You can buy a 2000 watt Kipor gennie for around $800-900 but make sure the kettle is not a 2400watt job. If you can't find a 1200 watt kettle look for a 1800 watt job. As for the toasting, same deal, buy on the wattage first.
Reply 3 of 6
FollowupID: 462365   Submitted: Friday, Nov 03, 2006 at 10:53
Ron173 posted:
This is becoming exy toast!! LOL
AnswerID: 202795   Submitted: Friday, Nov 03, 2006 at 10:58
Member - Andrew (QLD) replied:
Check if the bushcamp allows fires in firepits etc.......nothing like the smell of toast and the taste of billy tea cooked over a campfire (together with the smell of your clothes afterwards) :-)
The kids will probably love cooking it themselves as well....Bring back the good old days ;-)
It may be that my sole purpose in life is to
serve as a warning to others!
Reply 4 of 6
Activities Index
Flight- 40 minute Sky Blazer Flight- 40 minute Sky Blazer
Hunter Valley - NSW
40 minute flight in a Pitts Special beginning with a cruise over the Lower Hunter Valley followed by
Aphrodite Body Indulgence (2.25 hours) Aphrodite Body Indulgence (2.25 hours)
Townsville Region - QLD
Relax while our nurturing beauty therapist pampers you from top to toe with a full Body Massage,a fu
Undoolya Discovery Quad Bike Adventure 3.5 hours Undoolya Discovery Quad Bike Adventure 3.
Alice Springs and Central Australia - NT
Quad bike the outback; travelling varied terrain and viewing abundant wildlife.
Shooting Star - Night Tandem Skydive Shooting Star - Night Tandem Skydive
Sunshine Coast - QLD
Something truly spectacular!
Book Now - Things To Do
AnswerID: 202823   Submitted: Friday, Nov 03, 2006 at 13:09
Cammo replied:
Thanks all for your responses. It has been very much appreicated and I have learnt something along the way.
Cammo
Reply 5 of 6
FollowupID: 462802   Submitted: Sunday, Nov 05, 2006 at 19:14
Member - John W (ACT) posted:
Cammo
It's all been said by others - heating appliances are far too power demanding to be sensibly run from batteries, and in any case a big enough inverter (or generator) will make the toast prohibitively expensive! What hasn't been refered to is the question of sine wave v's modified sine wave - There are very few applications where you need an expensive pure sine wave inverter (maybe for TV, radio or a quality sound system which might pick up some interference from an "impure" source). For anything else (eg power tools, or heating stuff) the far cheaper modified sine wave (switching) inverters are ok, though again, don't be too demanding on your batteries. Deep cycle batteries don't like fast discharge (I'd regard 20 amps as a sensible top limit, which amounts to only about 250 watts - half enough to run a 1/2" electric drill). The cranking battery used to start the engine will stand up to ten times that for brief periods, long enough to get the engine started so it can generate all your electricity requirements. Either way, they won't run high power gear like jugs and toasters for long !!!
HTH
John W
Indian Ocean sunset Middle Lagoon
J and V
- Albert Einstein
AnswerID: 203357   Submitted: Monday, Nov 06, 2006 at 16:18
Mainey (WA) replied:
Cammo,
try Camping and Outdoors for a (about $39) coffee maker, runs direct off the 12v battery.
Makes tea or coffee in 4 mins in "as bought" condition however can be improved to work in <3 mins with some modifications.
(Can be bought in Broome for $9.95)
Reply 6 of 6
