Safari snorkel for 100 series L/C
Submitted: Saturday, Nov 04, 2006 at 16:36
Member - Howard P (WA)
Hi All
Just bought a TD 100 series L/C and was wondering if anyone had a safari
snorkel fitted and if so have you noticed any induction noise? Any comments would be appreciated.
Howard
Reply By: Bilbo - Saturday, Nov 04, 2006 at 16:56
Had one on my Turbo Diesel 100 series and never noticed any induction noise. If you are yet to have it fitted, don't look when they cut that great big hole in yer wing! It's 'orrible!!
Bilbo
203059
Reply By: blackmax11 - Saturday, Nov 04, 2006 at 18:09
I have one fitted and no induction noise noticed.
Blackmax
203072
Reply By: Richard W (NSW) - Saturday, Nov 04, 2006 at 18:22
Mine whistles but not as much since I got a 3" mandrel bent exhaust fitted.
203074
Reply By: luch - Saturday, Nov 04, 2006 at 21:49
Hi Howard
I fitted a Safari
Snorkel about 4 weeks ago, Have no induction noise
Took me about 1.5 hrs to fit it
Heart rate increased as i was drillind the 2 large 95mm diameter holes in the guard
Easy job if you are planning to do it your self, Just follow the instructions pretty straight forward
Luke
203105
Reply By: acdc - Saturday, Nov 04, 2006 at 23:15
Go for an airtec if you are going to fit it yourself, much easier to fit than safari ,you don't have to relocate your blinker and cheaper.
If you follow the rules, safari actually make your 100 series unroadworthy as the blinkers are no longer assymetrical.(in other words the same place on both sides or the car).
203114
Follow Up By: Trekkie (Member - WA) - Sunday, Nov 05, 2006 at 00:09
Well how about that - I had my Safari fitted 5 years ago and I never realised the blinker was relocated!!! Just went out to the garage to check. However I did not notice any noise after it was fitted - there again shmbo often says I am deaf (selective)
462684
Follow Up By: Off-track - Monday, Nov 06, 2006 at 00:26
Asymetrical actually means not symetrical, but I digress. Anyway not sure if the rules care if the side blinkers are not even but really who cares. Not sure about the 100 but I looked at the Airtec for the 80 and decided to go the Safari.
462861
Reply By: anoldbuddy - Sunday, Nov 05, 2006 at 07:23
Hi Howard,
The previous TD LC100 (may 2004) I had was fitted with a Safari
snorkel by ARB in
Brisbane for the dealer. I was initially very unhappy about the induction noise apparently coming from the body or head of the unit. I took it back to ARB and they agreed that the noise from 70kmph on was unacceptable in a car which was ordinarily so quiet. They had it for a few hours and tried all sorts of things before ringing me and saying it was fixed. The solution involved rotating the head inwards about maybe 5-10 degrees so that it was not parallel to the body or direction of travel. I wouldn't have believed the difference - the thing was quiet again. According to the manager it is something they often have to do but was forgotten about initially on
mine. Unless you look hard at the unit you could not detect the rotation.
Suggest you try this - it is very easy to do.
Anoldbuddy.
203133
Follow Up By: Richard W (NSW) - Sunday, Nov 05, 2006 at 08:05
Thnaks for the info I'll have to try that.
462708
Reply By: Member - Howard P (WA) - Monday, Nov 06, 2006 at 00:17
Hi All,
Thanks for all the good info you have passed on to me, very much appreciated.
Regards,
Howard.
203276
Reply By: Member - Willie , Epping .Syd. - Monday, Nov 06, 2006 at 06:54
Hi Howard ,
I have a Safari
snorkel on my 100 TD and I can sometimes here a bit of induction noise - but you have to really be waiting for it with the window open when you accelerate .
When I use the Donaldson pre-cleaner on it , I get a lot of noise , but after I while , I don't notice it .
Cheers ,
Willie .
203283
