Towing a van in the soft sand Help please ?
Submitted: Saturday, Nov 04, 2006 at 18:34
Member - BBB
Towing a van in the soft sand Help please?
We used to toe a camper trailer all over Morton and Fraser Island when it was fully loaded it would weigh between 11 and 1200kg and I toed it with The Landy and my GU.
It meant there was 5 to 600kg per wheel The Landy struggled at times but the GU pulled it any where.
I now have 20ft Traveller that when loaded weighs 2600kg which is about 600kg per wheel with 265 x 75 x 15 tyres.
Do you think I could toe it on the Soft sand?
At low tide there will be no problem traveling
the beach it is the cuttings and soft sand I am worried about.
Could I please get some feedback from some one that has toed a similar rig on
the beach and in soft sand or do you think I am dreaming.
BBB
Reply By: Member - Andrew W (SA) - Saturday, Nov 04, 2006 at 19:23
Probably.
Would I do it?
Probably not.
If I had a bad heart - definitely not.
There is nothing better to make the heart beat fast than racing the tide when you're up to the gunwhales.
Andrew.
203082
Follow Up By: Jimbo - Saturday, Nov 04, 2006 at 19:28
A solid insurance policy reduces the stress.
462629
Follow Up By: Member No 1- Saturday, Nov 04, 2006 at 21:10
only after the fact
462646
Follow Up By: Member - Andrew W (SA) - Sunday, Nov 05, 2006 at 08:34
Reminds me of a comment from an insurance assessing manager friend of
mine with a major company in relation to 4WDers:
"Our policies don't include a stupidity clause"
Andrew.
462713
Reply By: blackmax11 - Saturday, Nov 04, 2006 at 19:28
I doubt if you will be able to tow that weight when the sand is soft. Hard stuff no worries.
I think you will be asking for trouble when the going get tough.
KEN
203084
Reply By: wazzaaaa - Saturday, Nov 04, 2006 at 19:29
Hi BBB, I only have a 16' caravan but when full loaded I would guess it would be around 2000kg, I go to teewah beach, moreton and fraser and as yet not had any major problems (not saying I havn't been bogged but always got out)although at moreton this year I stayed on the west coast and the only problem was getting back on micat at hi tide, had to let the tyres down to 9 or 10pounds as I couldn't get a run off. When I did go to the other side in the past I made sure I had someone else with me just in case. Moreton's sand seems to be worse for some reasion but timing the tides seems to be the answer.
Wazzaaaaaaa
203085
Follow Up By: wazzaaaa - Saturday, Nov 04, 2006 at 19:36
Also there is soft sand and there is soft sand, if someone has just churned the soft sand up after being bogged it is a night mare but going on fresh tracks around that spot has more traction
462631
Reply By: _gmd_pps - Saturday, Nov 04, 2006 at 19:35
it is not just the weight per wheel .. the total weight and resistance in soft sand is much higher ... I would NOT go where the
water would get me .. when I tow my boat trailer through the sand (2.4t loaded) I always make sure I have an anchor point for the vehicle to winch out .. the boat is no problem it swims .. your caravan sinks ... if you want to go
places on
the beach I would stay out of the waterline (soft sand is there too) and would take sand ladders .. if it gets too soft lay sand ladders .. it's not meant for long distances but to reach
the spot for the next 2 weeks :)) ...
Even a stronger vehicle like my new one will not necessarily be better , it is heavier and stronger though, but when it gets stuck its even harder ... there is only so much you can do with a 20footer ... like Andrew said ... racing the tide is stressful .. :))
good luck
gmd
203086
Reply By: Member - Norm C (QLD) - Saturday, Nov 04, 2006 at 19:40
BBB, I haven't towed that sort of weight in soft sand, but I do tow a 1,500KG trailer with a 3 lt TD Hilux. Your trailer might be heavier, but your GU will have more torque as
well (if it's a 4.2 TD). It will still be tougher for you though with the extra weight.
In the cuttings and getting to the Fraser barge etc, you should be OK with tyre pressure and plenty of momentum. Just don't stop!!
But I'd avoid the long stretches of soft stuff, like high tide and probably
Indian Head and the like.
I'd suggest that for the first trip, you travel with someone else with a powerful vehicle who can help if you get into trouble. Choose the right tides so you have plenty of time if you do get stuck.
I've seen plenty of vans and big boats at Fraser, but don't know what they weigh.
203089
Reply By: age - Saturday, Nov 04, 2006 at 21:04
Hi BBB
I tow a boat weighing about 1.6t with a fully loaded truck through the soft cutting at
Indian Head regularly. Trailer has standard 13 inch light truck radials. Key to it all is tyre pressure. I let truck tyres down to 15psi for the cutting and keep trailer tyres at 25psi as they are bagged up heaps at that pressure - this is from trial and error for my setup. Pick a gear and stick to it and follow a good non churned track through. I reckon you will have no worries. Heaps of guys towing big boats and vans through there now. Only those who don't let tyres down enough generally have problems. As Norm mentions above pick the tide to give yourself heaps of time. I choose to stick to the
water line, but I know that beach
well and too many drop offs and idiot backpackers to sit up higher - especially if
the beach is wallowy or melon holed (knocks truck and boat around too much as
well). In 25 years I have never hit a soft patch close to the
water line on Fraser or Double Island
203096
Reply By: Member - BBB - Saturday, Nov 04, 2006 at 21:20
Thanks for the replies so far.
Are there any Bush Trackers or Phenices owners out there that have done beach work as above ?
BBB
203101
Reply By: Member - Jeff H (QLD) - Saturday, Nov 04, 2006 at 23:12
Gees BBBs,
I'd be inclined to check Jiarna's post titled 'Lost, one steel ball' . JH.
203113
Follow Up By: Member - BBB - Sunday, Nov 05, 2006 at 08:48
Jeff
Are you saying I have lost my marbles or that I should grow bigger BALLS either one is probably appropriate.
BBB
462717
