Magellan GPS
Submitted: Sunday, Nov 05, 2006 at 20:13
ThreadID: 39180 Views:3457 Replies:5 FollowUps:9
Has anyone got a Magellan Explorist XL GPS What are your views on them for general outback touring?
Reply By: Wayne (NSW) - Sunday, Nov 05, 2006 at 21:23
The Yeti,
I have one and it works well in the out back.
I got the package deal which has the GPS, power lead, usb lead, and the card with all the detail maps of Australia.
I also got a external aerial but I don't think it is necessary.
It showed the Canning Stock Route as well as the tracks across the Simpson Desert. It will also show streets in all the towns. You can use the go to function to show you where a street is even if you are not in that town. It is not voice activated. I find the big colour screen easy to see and the buttons are also easy to use.
I did read a report on this GPS and a Garmin and the Garmin came out in front. I will not change the GPS because it does what I want.
The bracket that came with the kit is alright for the black top but does not hold the GPS on the rough stuff. I have since got the proper bracket on E Bay for the GPS.
Have a look at all the GPS units on the market before you buy, but I would replace the XL with another XL if I had to.
Wayne
AnswerID: 203248
Follow Up By: Bonz (Vic) - Sunday, Nov 05, 2006 at 21:45
Wayne, why di the Garmin come out in front would u remember?
FollowupID: 462838
Follow Up By: Wayne (NSW) - Sunday, Nov 05, 2006 at 22:12
Bonz,
I can't remember but it was in a 4WD mag. I was surprised because I thought the Magellan was very good.
It was only one report that I have read. It is a pity that the 4WD magazines don't do more comparisons on GPS and UHF radios.
Wayne
FollowupID: 462846
Follow Up By: Member - Doug T (W.A) - Monday, Nov 06, 2006 at 02:45
Wayne
here is a comparison site
gpsinformation.net/
FollowupID: 462866
Follow Up By: Bonz (Vic) - Monday, Nov 06, 2006 at 06:49
One thing that comparison sites dont tell you is the way the unit works, I found teh Garmin to be more intuitive than the Magellan, howevere, once you start using it you get used to it. Nevertheless as a GPS dummy I could pick up a Garmin and actually get it to do something, the Magellan didnt click as well.
Have used one since and it still seems quite complicated to get something to happen.
FollowupID: 462867
Reply By: The Yeti - Sunday, Nov 05, 2006 at 22:47
Thanks Wayne, I appreciate your input
AnswerID: 203263
Reply By: Martyn (WA) - Monday, Nov 06, 2006 at 00:32
The Yeti,
I replaced my Magellan Meridian with an Explorist XL, Screen size is great plus but you loose some of the functionality of the Meridian. Has all the same basic fuctions, track back etc etc. Keyboard is easier to see, bigger screen you see. I find that the XL is much more suseptible to loosing signal when the CD player is on if the unit is close to the CD player, I spoke to Magellan they couldn't help much that's just the way it is. The XL won't plug into your laptop or desktop and work with Discover Oz software which for me is a pain in the butt, this to me is the biggest downfall. The Meridian was great this way. The screen is a big plus the maps are accurate and up to date. The holder on the dash is not the best when subjected to a few corragations, the Meridian was a clip in rather than a clamped grip of the XL.
I like it despite the few negatives, did I mention the screen size was much bigger.....................
Keep the shiny side up
AnswerID: 203278
Follow Up By: Sarg - Monday, Nov 06, 2006 at 00:43
"The XL won't plug into your laptop or desktop and work with Discover Oz software which for me is a pain in the butt,"
Works perfectly for me. Used it on the laptop for "moving maps" with NATMAP & Ozi Ex before the introduction of MApsend Lite V2
FollowupID: 462864
Follow Up By: Martyn (WA) - Monday, Nov 06, 2006 at 11:58
Sarg,
Fair comment, the XL won't plug into a laptop or desktop with the software provided which is what maybe I should of said. I had the Mapsend original software but I haven't got the Lite V2.
Me I thought that if the XL came with software and a USB connection that the software supplied with the unit would work on another computer that's all.
FollowupID: 462898
Follow Up By: The Explorer - Monday, Nov 06, 2006 at 12:50
Hello - they were a bit slow in getting out Mapsend Lite V2 after introduction of usb explorists (DAST was for serial magellans) - while I dont use MLV2 much it appears to have some good functions - (some that you would expect such as ability to connect to your GPS!!). May not have been available when you first picked up your XL?? Anyway Its is free to download ....so there is no reason to suffer...
www.gpsoz.com.au/magellan_mapsendlite.htm
OziExplorer is better anyway (even if you have to pay)..........
FollowupID: 462908
Follow Up By: Martyn (WA) - Monday, Nov 06, 2006 at 12:57
Cheers Greg, thanks for that I'll be right onto that one.
FollowupID: 462911
Reply By: Sarg - Monday, Nov 06, 2006 at 00:37
Great unit. Nice large clear screen, easy to use menu, heaps of memory storage & functions. Can be used with Mapsend Lite & computer now which makes trip planning easier. The few things that could be improved on is: a way to recharge the batteries(like a moblie phone) while using external power, the detail from 350m to 700m is a bit vague & the lowest backlight setting is still a bit too bright at night.
I mainly use 350m & above for general road info, then zoom down to 160 or 80m for the hard going.
With the DAST SD card, you won't need much more than a basic paper map to find your way around, especially if you have access to a laptop as well, or pre plan on a desktop before you go & download the waypoints into the XL. I use Natmap Premium with Ozi Ex plorer as well to get the general layout of the area, but find it isn't much use in the more built up areas.
Go for the Travel Pack if you decide to buy one.
AnswerID: 203280
Reply By: Member - Alastair D (NSW) - Monday, Nov 06, 2006 at 08:56
Yeti,
I have one and like it a lot - except for the holder as mentioned. A minor annoyance is that the batteries do not charge in the unit when it is plugged in, you have to take them out. It is pretty hungry on batteries when used separately but you can't have everything and the big screen is what I wanted.
Works fine with all the s/w I have tried including the ones mentioned. Download V2 of the Magellan s/w from their website.
The Discover Aus maps are quite good and even showed our driveway which used to be a bush track before the house was built.
Would buy it again so I guess that says something.
alastair
AnswerID: 203298
Follow Up By: The Yeti - Monday, Nov 06, 2006 at 21:32
Thanks everyone for your comments, I think I will give it a go, As you all say the mount supplied is no good which is the best one to get?
FollowupID: 463001
