IPF light thread size
Submitted: Tuesday, Nov 07, 2006 at 00:21
Scubaroo
Anyone know the thread size on IPF lights? Had a set fitted today apparently there's not enough clearance to use the special key spanner to fit the lock nuts without removing the bar, so I was thinking of putting a second set of nylocs or something on to slow down any potential thieving mongrels. ARB didn't know the threadsize offhand.
Reply By: Tim M - Tuesday, Nov 07, 2006 at 09:09
Hey there Scubaroo.
Just measured the length of the thread from the bottom of the swivel hub to the leend of the thread and it appears to be 30mm.
Bit hard to get at as the 80 series is parked in the garage and now I have spider webs all over my shirt...oh
Hope this helps
Tim
203493
Reply By: Scubaroo - Tuesday, Nov 07, 2006 at 11:05
Thanks, but I meant the thread pitch, e.g M6
203516
Reply By: SA_Patrol - Tuesday, Nov 07, 2006 at 23:09
Couldn't ARB open another box to see.
203628
Reply By: Michael_FNQ - Wednesday, Nov 08, 2006 at 00:30
If you have large IPF lights eg 800/900 series they use M12x1.75
The smaller IPF lights are M10 x 1.5 (I think the pitch is 1.5)
These are the only two sizes they have
203636
Follow Up By: Scubaroo - Wednesday, Nov 08, 2006 at 09:28
Thanks - they're IPF 900XS so most likely the M12 x 1.75 size. ARB knew that they were 12mm but didn't know the pitch.
463262
Reply By: Bilbo - Wednesday, Nov 08, 2006 at 00:32
Scubaroo,
Metric threads are categorised not only by bolt diameter but also by thread pitch.
Metric thread pitch is measured from
the tip of one thread to
the tip of the next thread. There are 3 metric thread pitches. These are 1.0, 1.25 and 1.5, measured in millimetres.
e.g M6 1.25, indicates that the bolt diamter is 10 mm and the thread pitch from thread crest to thread crest is 1.25mm
another e.g – M10 1.5 = a bolt diameter of 10mm and a thead pitch of 1.5 mm
another M16 1.0 = 16 mm diameter by 1.0mm thread pitch.
I would
hazard a guess that the bolts on your lights are M12 1.5
But that’s only a “guess unseen”
UNC, UNF, BSW and BSF threads are measured differently in “Thread per Inch” or “TPI”
Your best bet is to remove a light and take the bolt down to an engineering workshop or an engineering supplies
shop. They'll have a guage that can measure what thread it is.
Bilbo
203637
Follow Up By: Scubaroo - Wednesday, Nov 08, 2006 at 09:30
Thanks Bilbo.
About as simple as scuba
tank valve thread sizes - where the 3/4" valves are larger than 7/8" valves because of the standard used!
463263
