NEW 4.8 Patrol. no sub tank?????
Submitted: Tuesday, Nov 07, 2006 at 14:02
ThreadID: 39220 Views:6430 Replies:4 FollowUps:27
Had a look at a new 4.8 patrol on the weekend. They now do not come with a sub tank for some unknown reason, so now, if you want better range, not only do you have to replace the main tank with a long ranger you have to buy the sub tank as well.
Does any body know why they have stopped the subby in the petrols and has any body fitted both long rangers to the current model.
Any info would be appreciated.
Reply By: Member - Teabag (NSW) - Tuesday, Nov 07, 2006 at 14:23
I was under the impression that the 4.8 never had a sub tank though I could be wrong. I thought it was something to do with the exhaust system? I have replaced both tanks on my Patrol to give it a capacity of 215ltr......
AnswerID: 203543
Follow Up By: Member - Dunworkin (WA) - Tuesday, Nov 07, 2006 at 14:45
Don' t know about the 4.8 but like you Teabag we replaced our standard tanks for the larger ones giving us 215lts as well.
D&B
Simba, our much missed baby.
FollowupID: 463110
Follow Up By: Member - Teabag (Queanbeyan) - Tuesday, Nov 07, 2006 at 15:02
Yep, one of the best extras I have fitted as I hate carrying jerry cans and the touring benifits are excellent.......
FollowupID: 463112
Follow Up By: ingo57 - Tuesday, Nov 07, 2006 at 15:12
The earlier model GU 4.8 (02) definately came out with a subby, have a friend who bought one from new so just replacing the main with a long ranger, it roughly got it up to 190 litres with the sub tank.
Nissan couldnt tell me why they discontinued it with the petrol model only, but it doesnt make sense??
FollowupID: 463116
Follow Up By: ingo57 - Tuesday, Nov 07, 2006 at 15:30
Now Im confused, just rang ARB and long ranger and the guy says 145ltr replacement tank only, no sub tank regardless petrol or TD.
What after market tanks are you guy's running? And wher did yuo get them from?
FollowupID: 463118
Follow Up By: Member - Dunworkin (WA) - Tuesday, Nov 07, 2006 at 15:53
Hi ingo57, we replaced our original tanks on the 4.2TD at ARB in Welshpool. main tank holds 145lt and the sub holds 70Lt. Not sure where ARB got them from, one of our good decisions!!!!
D&B
FollowupID: 463120
Follow Up By: Member - Roachie (SA) - Tuesday, Nov 07, 2006 at 16:26
Ingo,
Is there anything under the floor of your GU (I mean under the driver's side passenger, where the sub tank is normally found)....like a muffler etc? If not, I would assume the captive nuts etc (that are used to hold the sub-tank on other models) would still be there and that a aftermarket subtank shouldn't be too hard to fit.
I've got the 145 litre Long Ranger main tank, but haven't shelled out the bikkies for the bigger sub. There is a mob that make an 81 litre replacement sub tank.
FollowupID: 463124
Follow Up By: Member - Teabag (Queanbeyan) - Tuesday, Nov 07, 2006 at 17:05
Mate, both are Longranger. 145ltr Main and 70Ltr Sub and it is in the ARB catalogue......
FollowupID: 463136
Follow Up By: ingo57 - Tuesday, Nov 07, 2006 at 17:08
I havent got the patrol yet, Its something that Im needing to be sure of before I buy, the 4.8 is pretty thirsty as every one knows so every bit counts.
Will have to go back to the dealer and have a good look under there. If it cant be done my next option is the Prado which Im not totally convinced on.
These big car companys dont seem to make sense....... The Nissan 3ltrs seem to have been blowing up left right and centre. The 4.2 seems to be the pick of the bunch, yet I would like a bit more power, and the 4.8 has now dropped the sub tank which uses more fuel than the lot of em?
The Prado is a smaller vehicle than the 100 series yet it has the better fornt suspension and diff, is more powerful than the 100 series V8, the prado has its spare on the rear door where the 100 series drags it along a heavilly rutted track?
" After sales service with toyota is better than Nissan" doesnt mean jack with a blown front diff in the middle of the desert!!!!
FollowupID: 463140
Follow Up By: ingo57 - Tuesday, Nov 07, 2006 at 17:09
Thanks for your imput anyway guys, much appreciated.
FollowupID: 463141
Follow Up By: Pezza (Bris) - Tuesday, Nov 07, 2006 at 18:01
Hi ingo
4.2 intercooled TD Nissan with a Mike Vine upgrade, $2000 plus dump pipe and exhaust ($900) = 155hp and 462 nm torque. The TD cruiser 150hp and 420nm torque.
Avagoodn
Pezza
FollowupID: 463154
Follow Up By: Member - Ivan (ACT) - Tuesday, Nov 07, 2006 at 18:09
What is your reservation on the Prado Ingo? - with 180 lt standard, wheel already on the back as you say, they're pretty decent (ie not much more to spend). There is a previous post (last day or two) where it shows the power of the new common rail - I remember it was a decent number ;-)
A little bit smaller around town too (and on the tighter tracks) which doesn't hurt - the only reason we went the 100 was for three growing boys in the back seat - otherwise we would have had the Prado as well
FollowupID: 463160
Follow Up By: Stu-k - Tuesday, Nov 07, 2006 at 18:45
I nearly brought a prado until I read things like this Site Link I know all manufacters have their problems but it does seem a little wide spead.
From everything else I hear there a good thing but once I drove a crd jeep(160kw 510nm) and the pardo seemed abit bland.
So I went the jeep. Test drive everything before you lay down the cash, glad I did.
FollowupID: 463168
Follow Up By: Member - Ivan (ACT) - Tuesday, Nov 07, 2006 at 19:21
Hi Stu - gotta agree there are a fair load of problems there - but I'm on a couple of Prado lists, and I think it would be fair to say that satisfaction is much more often positive than it is negative (as it should be!!) The only other comment is for the Grande - for anyone wanting to modify suspension, I understand these are nothing but problems because of their standard air bags..
For the Jeep, I don't have any experience, so can't comment
FollowupID: 463170
Follow Up By: ingo57 - Tuesday, Nov 07, 2006 at 19:49
Just finished reading the biography of that guys Prado, doesnt sound too convincing....to say the least
think I will take roachie's advice and will go and have another look at the GU tomorrow to see whether the bolt holes etc are still there to fit the sub tank, providing nothing else is restricting it.
Nothing against the diesals but petrol power is what I need so will see how I go tomorrow at the dealer.
FollowupID: 463176
Follow Up By: tomjones83 - Wednesday, Nov 08, 2006 at 11:52
Hi Guys,
I own an 02 4.8l. Yes, I imagine it is thirstier than the diesels however, it isnt too bad when you just take it easy on the right foot. We wanted the TI which only comes in the 4.8l semi-auto.
for example, we went to moreton a couple of months ago, did approx 160 klms and chewed 1/4 of a tank. obviously higher consumption as we were in 4high all weekend.
2 weekends ago, took it from Manly (Qld) to Crystal Creek (murwillumbah) which the trip was about 120k each way. out there, played around in the mud saturday and sunday doing mostly slippery hill climbs so needing some revs. we only chewed just over 1/2 a tank.
I think it is a preference thing. As far as i am concerned, i wanted the grunt and quietness of a petrol (and the need not to change oil ever 5000k). ours rides like a sedan but much quieter on the black stuff and still performs very well offroad. plus, if you are after petrol, get the TI (all the niceties for around town and the factory locker in the rear for offroad ;-)
to further add - it has a 95l tank and a 45l subby, factory fitted.
Tom
FollowupID: 463289
Follow Up By: Stu-k - Wednesday, Nov 08, 2006 at 17:55
You guys should drive one of the new breed diesels...
4.8 patrol 0-100 9.9 seconds
3.0 jeep Crd DEISEL 0-100 9 seconds plus half the fuel.
FollowupID: 463391
Follow Up By: Member - Teabag (Queanbeyan) - Wednesday, Nov 08, 2006 at 18:05
Yeah, but it's a Jeep......Serious 4wd's only.......VTIC
FollowupID: 463396
Follow Up By: Stu-k - Wednesday, Nov 08, 2006 at 18:29
Damn that counts the patrol out
FollowupID: 463401
Follow Up By: Member - Teabag (Queanbeyan) - Wednesday, Nov 08, 2006 at 21:40
Stu-k,
Mate, Jeeps only have one use.......Filling pot holes......hehehe....Mate, Just joking........
FollowupID: 463441
Reply By: Member - Andrew W (SA) - Tuesday, Nov 07, 2006 at 20:47
Hmm - even if the retaining nuts are there, you will need extra plumbing for a sub-tank I would think. A pump at least - although with a pootrol you probably don't need a return line and solenoid etc.
Andrew.
AnswerID: 203599
Follow Up By: tomjones83 - Wednesday, Nov 08, 2006 at 12:03
"pootrol" hmm...
on the flipside -
"Land Loser"
all in good humor ;-) I hope!
FollowupID: 463291
Reply By: Bobthe... - Wednesday, Nov 08, 2006 at 22:13
I was told by Brighton Nissan,due to the new emission laws,sub tanks are illegal. I didn't ask for a reason,I was gobbsmacked... I gave the salesman a puzzled look and left.
AnswerID: 203796
Follow Up By: ingo57 - Thursday, Nov 09, 2006 at 13:59
Well Totota still have the sub tanks on the 100s and prado.............. I guess they must be breaking the emmision laws then??????????????
FollowupID: 463590
Reply By: Robin - Thursday, Nov 09, 2006 at 14:45
Hi Ingo57
Also no manual and its down 5kw to 180kw .
There are issues with aftermarket sub-tank on the petrol , hence none from ARB and other suppliers have versions with a bit less capacity (Typ 70lt).
There still is no other serious 4wd that can match it though considering the aftermarket stuff like lockers, unichips etc that it can take.
If it keeps the price down , then you are probably better off without the sub-tank
and fitting a far simpler aftermarket system which just transfer dumps fuel to the main (did this to my GQ).
In my 4800 have 145lt main tank and the standard 36lt sub and with a long term average of 16.5lt/100km it has in excess of 1000km range and its life cycle cost
is no more than 4.2 anyway when you take all into account.
Go for it, you won't regret it.
Robin Miller
AnswerID: 203906
Follow Up By: ingo57 - Thursday, Nov 09, 2006 at 16:11
Hi Robin
Thanks for your imput mate.
Is your 4.8 manual or auto?
FollowupID: 463604
Follow Up By: Robin - Thursday, Nov 09, 2006 at 16:26
Manual here Ingo57 , has its pluses and minuses.
The current model has the Euro spec engine with extra Oxy senors downstream of the Cat , which previous ones don't. Don't know for sure but think current slightly lower consumption.
Some good prices on these lately I notice.
Gas is for those who worry about fuel cost , but in reality fuel is only 20% of cost of running a near new car , and diesels are only 1/3rd of that 20% better, so its not a real issue provided you have the range.
Robin Miller
FollowupID: 463606
Follow Up By: ingo57 - Thursday, Nov 09, 2006 at 16:57
The nissan salesman Im dealing with reckons you can still get manual but maybe he hasnt kept up with his homework, will have to double check.
Totally agree the manuals can have pluses and minuses, but if you had the choice again which way would you go?
Do you do a lot of touring in it?
FollowupID: 463615
Follow Up By: Robin - Friday, Nov 10, 2006 at 08:15
The salesman hasn't done his homework , manual 4800 is not listed on Nissan website anymore, maybe there is last years model at really good price though, be interesting to challenge him on this.
Yes do a lot of touring and 4wding here , most of the big trips to. Car gets around high 15lt/100km trips and 19lt in bush , doesn't change much. Auto does better on trips cause the engine revs are about 2100 at 100kmh whereas manual is 2600rpm.
I wanted a less complex car and manual has no auto transmission computer and also no abs sub system.
We also have an auto RAV4 and so I appreciate the ease of it around town.
Would buy manual again in this model because it large torque partly negates the auto's advantage in slow going , and while the auto will get to 100kmh slightly faster than manual due to fast gear change, the manual is a lot faster in overtaking
in say 80-110kmh where it stays in 3rd gear.
If I had to choose amongst the 3lt Patrols I would probably make a different choice
because of lack of engine torque.
Robin Miller
FollowupID: 463771
Follow Up By: Pavo - Friday, Nov 10, 2006 at 08:40
Robin, you say you've got the 145L main tank and the standard 36L sub. Is that main tank standard or aftermarket?
Nissan's website says 95L main tank - so have they dropped the sub tank (on the petrol only) and also reduced the size of the main?
FollowupID: 463774
Follow Up By: Robin - Friday, Nov 10, 2006 at 09:08
Mine is an aftermarket ARB 145lt main tank , the standard main tank remains always 95lt.
After a lot of research I choose a bigger (but not the biggest which is 159lt) main tank over a bigger sub-tank because of clearance reasons - had I been thinking of a gas conversion soon I would have gone for bigger sub-tank about 70lt in petrol but some 80lt for diesel.
My mission was to give the car a 1000km range.
Robin Miller
FollowupID: 463781
