fridges
Submitted: Tuesday, Nov 07, 2006 at 19:52
skipp
g'day, i have an engel fridge which i put in the boot of the commodore and run a lead to the cigi lighter. when im driving and want to stop the car i have been told i have to turn the fridge of first (get out of the car and open the boot to turn off fridge) and then the car, and same agian when i start car up ....is this true??p.s
made myself a beautiful camper trailer kitchen with no sink... thanks for all the advise..looks smic...will post pic soon
Reply By: Derek from Affordable Batteries & Radiators - Tuesday, Nov 07, 2006 at 20:16
Which model Engel ?
I have not heard of this...yet.
203589
Reply By: Bonz (Vic) - Tuesday, Nov 07, 2006 at 20:17
Cant see why you would have to do this a switch is a switch, I shall watch with interest
203590
Reply By: Member - Teabag (Queanbeyan) - Tuesday, Nov 07, 2006 at 20:26
Doesn't make sense to me as when you turn the car off the cigi lighter will be off as
well so the fridge won't run anyway as the cig lighter is tied to assessories....Seems real strange........
203593
Reply By: Member - Bill F (VIC) - Tuesday, Nov 07, 2006 at 20:40
Hi Skipp
The ignition switch is not designed to direct switch high amperage all the time and if the fridge is running you are switching high amperage and the ignition switch will arc, blacken and eventually burn out
Bill F
203595
Follow Up By: Member - Teabag (Queanbeyan) - Tuesday, Nov 07, 2006 at 20:53
Fair call, though I wouldn't consider 2.5 amps High, far from it. Your ingnition switch should be able to handle that without worry........
463198
Follow Up By: desray - Tuesday, Nov 07, 2006 at 20:53
High amperage ? The Engle fridge uses 4 amps max .
463199
Follow Up By: Member - Stephen L (SA) - Wednesday, Nov 08, 2006 at 09:00
Hi Desray,
Depending on what model Engel, that you have, the only ones that have a max of 4 amps are the 60 and 80 litre models.
The 40 litre has a max draw of 2.5 amps
463255
Reply By: Geoff (Newcastle, NSW) - Tuesday, Nov 07, 2006 at 21:04
Hi Skipp,
The only thing I can think of the person who told you this had in mind has already been covered, maybe they fear the ignition switch will eventually
cook from switching the fridge current. Switches in DC circuits such as your car are under the most electrical "strain" when going from on to off.
Wouldn't it be easier to pull the cigarette lighter plug before you switch off and plug it back in after start up? This'd work with my 20 odd year old Engel but maybe the newer ones use a different switching method? Do the Engel's still have the old mechanical filled capillary thermostat on/off combined?
Geoff.
| Geoff,
203604
Reply By: Member - Phil G (SA) - Tuesday, Nov 07, 2006 at 21:34
Skipp,
Your friend is correct.
I looked up he owners guide for both my current F-series Engel and my 1992 B-series engel, and they carry the same recommendation, that the control be in the "OFF" position when connecting power. They also say to use a dedicated power line from the battery - via a 20amp fuse in the B-series and 15amp fuse in the F-series.
I believe that sharp voltage changes can "cause transistor defects in the inverter".
I install a separate fused cable for the engels in both our vehicles. Then you also don't have to worry about the fridge switching off when you take out the keys.
203608
Reply By: MartyB - Tuesday, Nov 07, 2006 at 21:42
Skipp,
I would be ,more worried about circulation around the fridge.
When you say boot of the commodore do you mean a
sedan?
Marty.
203611
