Patrol 4.2TD Top end adjustment
Submitted: Tuesday, Nov 07, 2006 at 22:58
ThreadID: 39237 Views:2361 Replies:5 FollowUps:2
G'day all, Just had the tappets adjusted on the ute, and I was wondering how they go about doing it... Can someone let me know the process so I can save myself $135... next time and do it myself....???
BB.
Reply By: Bilbo - Wednesday, Nov 08, 2006 at 00:42
Bag Boy,
Setting tappets can be a drama if you're not familiar with it. What is a pretty easy, but long winded job to a mechanic can be an excercise in frustration for someone that isn't familiar with the "traps for young players". Particularly on a diesel. Get it wrong and you could burn out a valve or maybe damage a piston if ya get it really wrong!
I know - I did exactly that as a young man and was in rush to get an 11 litre AEC diesel engine ina big crane ready for a job. Ended up damaging 2 brand new cylinder heads! The boss was NOT impressed!
If you want me to give you a blow by blow description, I will, but be prepared to tear your hair out if ya get it wrong.
Lemme know,
Bilbo
AnswerID: 203638
Follow Up By: PK Eildon (VIC) - Wednesday, Nov 08, 2006 at 08:52
Bit like the bloke that went into the smash repairs with a small dent in the guard. The repairer said it would cost $125.00. He then got a hammer, looked at the job for a while and struck the guard with the hammer. The dent popped straight out and was perfect. The bloke complained $125.00 was a bit expensive for just a hit with a hammer. The repairer said, "$5.00 for the use of the hammer, and $120.00 for knowing where to hit."
FollowupID: 463252
Reply By: joc45 - Wednesday, Nov 08, 2006 at 01:11
Bag Boy,
As Bilbo says, it's time-consuming. The hardest part is finding that timing marker down by the front crankshaft pulley. The picture in the workshop manual is not all that it would seem. A worklight and a mirror helps a lot.
I rotate the engine over by putting the wagon in 5th gear, jacking up one rear wheel and slowly rotating the wheel by hand to get the piston to TDC mark - not easy, but it works. After doing 6 valves, you rotate the engine 360deg to do the other 6 valves. Just make sure you rotate the engine over in the direction it normally rotates.
Gerry
AnswerID: 203641
Reply By: donks1 - Wednesday, Nov 08, 2006 at 07:27
$135.00 isn't bad considering the r/c gasket is $50.00 on its own
thats only roughly an hour labour which is about right
if you don't know what you are doing, it will take you a lot longer to do it
it's money well spent
AnswerID: 203650
Follow Up By: joc45 - Wednesday, Nov 08, 2006 at 14:28
Ah, but do they really change the gasket?
I got one for my GQ (Mav) years ago and never used it, as the original was a good neoprene seal which I was able to re-use every time with no oil leaks.
Mind you, they probably charged for it without actually replacing it....
Gerry
FollowupID: 463325
Reply By: donks1 - Wednesday, Nov 08, 2006 at 14:49
geez some of you blokes must have dodgy dealers.. either that or you go in there with the wrong attitude
AnswerID: 203708
Reply By: Member - Ric K (WA) - Wednesday, Nov 08, 2006 at 15:22
just ask for the old rocker cover gasket back .... then u might get someone elses
AnswerID: 203711
