Cole-Hersee Dual Battery Isolator
Submitted: Friday, Nov 10, 2006 at 10:44
ThreadID: 39302 Views:6748 Replies:5 FollowUps:8
Hi All,
Has anyone used the abovementioned isolator and had any good/bad reports about it? Just looking at a setup on ebay of all places and it seems to be a good buy if that is a 'decent' component.
Tom
Reply By: Member - Davoe (Nullagine) - Friday, Nov 10, 2006 at 10:51
yep the original duel battery system works by isolating the negative from the batterys. Used them in quite a few vehicles including my current one. They allow easy checking of both batterys (start on one then the other) meaning you wont get stuck by a dead battery thieving charge from a good battery like happens with solonoid systems.
Nothing fancy- they just work and dont break down
AnswerID: 204080
Reply By: Derek from Affordable Batteries & Radiators - Friday, Nov 10, 2006 at 11:30
Hi Tom J
The simple solenoid isolator is still very popular.
We do 3 kits using the 100 amp continuous duty unit.
Very reliable and easy to DIY.
Regards Derek.
AnswerID: 204086
Follow Up By: tomjones83 - Friday, Nov 10, 2006 at 11:37
So they are still automatic? eg. Fridge runs of second battery when vehicle off the when on, can run off both whilst both batteries charge?
Thanks for the info ;-)
FollowupID: 463819
Follow Up By: Derek from Affordable Batteries & Radiators - Friday, Nov 10, 2006 at 11:42
Hi Tom,
Not all automatic. Solenoids are simple relays. You need to wire it so it is 'clever' or 'smart'.
Redarc and Sidewinder isoltors are automatic.
Regards Derek.
FollowupID: 463825
Follow Up By: tomjones83 - Friday, Nov 10, 2006 at 11:45
Thanks Derek, so by example, once it is wired up, the main start battery shouldn't ever go flat. Am I on the money or completely missinterperating this?
Thanks again,
Tom
FollowupID: 463828
Follow Up By: Derek from Affordable Batteries & Radiators - Friday, Nov 10, 2006 at 12:03
Yes, you have the general idea.
FollowupID: 463834
Follow Up By: Member - Davoe (Nullagine) - Friday, Nov 10, 2006 at 12:41
I have had several problems with this type of system in different vehicles where a battery has slowly died but been masked by the solonoid duel batt setup. The dead battery has then theived charge off of the good one and the first you knoew there is a problem despite your duel battery system you go no - where
FollowupID: 463840
Follow Up By: Derek from Affordable Batteries & Radiators - Friday, Nov 10, 2006 at 13:04
Hi Dave
Sounds interesting. Have you got an old one for me to look at.. (Strip down and inspect).
Isolators are Isolators, once the contacts are open they should isolate. Diode type could cause a problem as well as poorly wired accessories that can link the batteries via a globe or memory circuit.
Regards Derek.
FollowupID: 463844
Follow Up By: Member - Davoe (Nullagine) - Friday, Nov 10, 2006 at 13:23
No this was from a previos vehicle and work vehicles. The isolation wasnt the problem the problem was when a battery dies starting was still OK as the ignition kicks in the isolator so between the dieying battery and 2nd battery there is still plenty of kick to start. the dieying battery theives the charge while running from the good battery leaving you with one dead battery and one flat battery
FollowupID: 463846
Follow Up By: Derek from Affordable Batteries & Radiators - Friday, Nov 10, 2006 at 14:08
Yes this can happen if you don't wire the solenoid to a trigger that only has power once the car is running.
If in doubt you need to invest the a 'Smart' solenoid which will only engage once the cranking battery reaches 13.4 volts. Redarc or ABR units.
Regards Derek.
FollowupID: 463850
Reply By: troopyman - Friday, Nov 10, 2006 at 12:20
I just bought a brand new one from a local electrician for $80.
AnswerID: 204102
Reply By: Member - Norm C (QLD) - Friday, Nov 10, 2006 at 18:59
Yep, I've got a Cole Hersee in my Hilux. Very simple device, but very reliable. Never given an ounce of trouble, but I think next time I'll get a Redarc or similar. Still very simple, but just a touch smarter; ie voltage sensing.
Norm C
AnswerID: 204176
Reply By: Sam from Weipa Auto Electrics - Saturday, Nov 11, 2006 at 08:25
You cant go past the redarc though there even simplier than a cole hersey.
AnswerID: 204247
