The Cobb question returns
Submitted: Saturday, Nov 11, 2006 at 19:05
ThreadID: 39341 Views:2471 Replies:8 FollowUps:5
A few threads back the question was raised, how long to heat the beads up.
Mine just took 40mins. When others light them. do you light em in the basket and leave the lid off. or put it on. Others were saying 20mins to go white.so my 40mins seems a long time. The leg a Lamb has been on about 40mins now can smell it from here. Had tears when I put the Corona in the moat.
cheers brian
Reply By: Ozrover - Saturday, Nov 11, 2006 at 19:57
Brian, I don't yet have a Cobb but intend to get one soon. After using a Webber for years, leaving the lid off when lighting the heat beads & waiting around 40 mins seems about right!
You have a Goldstream camper in your photos, what model is it & how do you like it?
I'm in the market for a off road camper at the moment & would value your feedback.
Jeff.
AnswerID: 204305
Follow Up By: Member - Brian (WA) - Saturday, Nov 11, 2006 at 22:03
Hi Jeff. The lamb turned out good despite the weight for the beads to go white.
Cooked it for two hrs and it was yummie.
I have a Soverign camper, only done two trips with it.Both trips entailed dirt rd
so we got a bit of dust in. Got some foam cut 2x2 and packed in at the back which
stopped the prob there.2nd trip. Just seems the vents on the door now to look at. tows well
Done 400km dirt rd and nothing falling off yet.So yes after two trips we like it.
We changed from a tent camper. Have not tried a over night stop but don't
think it would be to hard to set up and pull down.
Hope this helps. cheers Brian
FollowupID: 464104
Follow Up By: Harry - Saturday, Nov 11, 2006 at 22:23
I can get my heat beads up and running in about 10mins, simply by using a pair of pliers, stick the whole basket of beads in the camp fire and hurries them up real quick.
As for the camper , I've just purchased a Cub Camper, model Supermatic Regal Offroad and we are very happy. The day we looked at it , we were on our way over to finalize a Kimberley camper and called into Cub, this 1 cost us $8000 less with the same if not better options than if we had bought the Kimberley and my main concern with any of the campers was weight. 700kg unladen and tows like it wasn't there.
This 1 only has a 100mm drawbar not 150mm which is an overkill and extra weight not necessary. All Australian canvas.
No great big boxes loaded onto the drawbar, fridge ( already have Engel anyway )and cupboard inside, annexe that doesn't go around drawbar, jerrycan holders, compatible wheels, reversing camera fitted, and hard floor to boot.
Loads of different options you need to consider, like where the door opening is, what does the outside kitchen do, how much water in the tank, do you really need an electric pump and so on.
FollowupID: 464110
Reply By: Member - Cruiser (NSW) - Saturday, Nov 11, 2006 at 19:59
I put the lid on and always seem to get them to go white after 20 minutes.
AnswerID: 204306
Reply By: handy - Saturday, Nov 11, 2006 at 20:35
stick to the destructions and you cant go wrong. most times ??
AnswerID: 204310
Reply By: Member - Michael J (SA) - Saturday, Nov 11, 2006 at 20:47
Evening Brian,
Trial and error, trial and error.
I had 2 magnificent errors, but using brand name 'Heat Beads' found that with the lid off about 15 - 20 mins and the beads had turned the required colour.
Stuck the lid on (with all required duties fulfilled, i.e. fill the moat/have a drink/put in herbs etc/have a drink.....and 2 hours later yumm.
Oh was turned after about 1hr.
Enjoy........have loaded a picture, I hope, in my profile.....pity no smellavision;))
Michael
AnswerID: 204314
Follow Up By: Member - Brian (WA) - Saturday, Nov 11, 2006 at 22:09
that looks good
FollowupID: 464105
Reply By: Richard & Leonie - Saturday, Nov 11, 2006 at 20:49
One thing we found with the Cobb is the outside temperature makes a hell of a difference to the cooking time. We have used it at home at times to do the roast. We put it out on the rear verandah. On a cold night (minus degrees) you have to double the heat beads and almost double the cooking time. Does anyone have success in crisping roast potatoes. Ours always turn out soft skinned.
Richard
AnswerID: 204316
Follow Up By: Member - Robyn J (QLD) - Saturday, Nov 11, 2006 at 20:59
You can get a crispier vegetable by spraying with oil before putting in the Cobb. I just put a light spray of Olive Oil over the vegies although most times I cook the vegies with the skin on so will never get a realy crispy vegetable like when cooking in oil. Most of the time now with potatoes I get the small washed ones and cook in a dry moat for the same length of time as for the meat and put the other vegies around the meat.
FollowupID: 464082
Follow Up By: titl4 - Saturday, Nov 11, 2006 at 22:42
I just lightly coat with oil like Robyn but for really crispy spuds whether in the Cobb or other oven - first roll the peeled potatoes in flour containing a pinch or two of ginger (no idea why the ginger helps, it just does).
Cheers ......... Alan
FollowupID: 464115
Reply By: Jayk At - Saturday, Nov 11, 2006 at 23:38
Brian,
The instruction book that came with our Cobb made it clear in several places that you should NOT put the lid on to help heat it up. In fact, they guarantee that if you do you will damage the unit.
Once you out your roast, or whatever, on, it's OK to then put the lid on, but never put the lid on an empty Cobb to help it heat up. You will damage it.
Jayk
Why? ... Why not?
AnswerID: 204343
Reply By: Noldi - Sunday, Nov 12, 2006 at 19:53
Just bought one on friday at the Perth show, went to Dongra for the blessing of the fleet festival (great time) fired it up (pun intended) on Saturday 7 self starting heat beads (took around 25 min to go white) 1.05kg lamb, spuds and carrots turned all after 45min and added pumkin and sweet potatoe.
pulled it all out after another 45 min. Results
Meat was Yum Yum (could habe had another 10 ~ 15 min)
Potatoes needed to be cut smaller but were edible
Carrots Yum Yum
Pumkin Yum Yum
Sweet potatoe, like a rock, should have gone on with the potatoes and carrots.
the heat beads lasted aroung 4 hours (time for a cake, then under the seat to warm the extremities
AnswerID: 204476
Reply By: Pajman Pete (SA) - Monday, Nov 13, 2006 at 13:32
We always drop the fire basket full of heat beads on the Coleman stove to get them fired up. Then use pliers to transfer the basket to the Cobb. It takes about 5 minutes to get them ready for cooking.
Pete
AnswerID: 204646
