ok stupid question.for the day
Submitted: Sunday, Nov 12, 2006 at 12:32
Member - BUNDY BOY (WA)
ok i know this is a stupid question ..but im trying to fix dads blinkers ..ive tryed the fuse its ok now want to check the flasher can ...but i cant find it ...lwb Gq 91...please help .want to get it done before he gets home from work ....Brad
Reply By: Pezza (Bris) - Sunday, Nov 12, 2006 at 14:19
Hi Brad,
Can just see Dad coming home to the 4by with electrical wiring hanging out of the doors and over the bonnet etc. Hahahaha.
Good onya for having a go mate.
From memory, someone may correct me here and I could be wrong, it is a black square box (approx 2cm square) mounted to the firewall towards the top and to the left of the brake pedal. ( Between the top of the brake pedal and the steering column )
Bit more info might help to locate the problem, ie. is the green light flashing on the dash, is there any 'clicking' sound, or is there absolutely nothing when you turn them on ?
Avagoodn
Pezza
204413
Follow Up By: Member - BUNDY BOY (WA) - Sunday, Nov 12, 2006 at 14:25
thanks pezza ....no theres nothing at all no dash lights for them or clicking sound nothing....Brad
464186
Follow Up By: Pezza (Bris) - Sunday, Nov 12, 2006 at 15:09
Good chance it's the flasher unit, not sure how to check them other than check if there is power going in and then power coming out when you turn the indicators on, either that or slip down to superchit and grab a spare then see if it works, (problem with this is it gets expensive if that is not the problem) hopefully some knowledgable auto leccy will come on soon and give you more help.
Sorry I can't be of more help mate.
Pezza
464191
Reply By: DMH122 - Sunday, Nov 12, 2006 at 16:27
Check the
hazard swich is not pushed in & fuse isnt blown for them. the fuse for
hazard's is in fuse box under bonnet.
204437
