E-mails
Submitted: Tuesday, Nov 14, 2006 at 19:05
Ray Bates
I keep getting e-mails from Oz readers on subjects I have not had an import in. Obviously someone else is not getting their e-mails
Reply By: Max - Sydney - Tuesday, Nov 14, 2006 at 19:38
Ray
Might pay to click on "abouit Us" above, then "Contact Us" to ask David or Michelle to check the problem out. Soiunds a site technical issue.
Max
204956
Follow Up By: Ray Bates - Tuesday, Nov 14, 2006 at 20:12
Done that. Thanks for the suggestion
464871
Reply By: Member - Jeff H (QLD) - Tuesday, Nov 14, 2006 at 23:31
Mate, don't post/no problem.
No, that was both rude and uncalled for: I enjoy similar problems. Although I kid myself that I fup less often now than earlier, a post will often appear way out of expected sequence. MAYBE if I could find the Manwell, then I would read it.
We live in hope. JH.
205017
Follow Up By: Ray Bates - Wednesday, Nov 15, 2006 at 10:12
What are you talking about or is this another mis-directed letter????
464988
Reply By: ExplorOz Team - David - Wednesday, Nov 15, 2006 at 11:52
Ray,
As per the email copies you have sent me - each of these were in fact posts that you have directly interacted with. The email flow is basically as follows:
You will be emailed for every reply to a new thread you start.
You will be emailed for every follow-up recorded against a reply you post.
If you submit a follow-up you will be sent a copy of all subsequent follow-ups to that reply.
If you do not want to receive these emails then use you can de-select
Forum Email from your Email Profile at www.exploroz.com/Users/MailProfile.asp
205079
Follow Up By: Mike Harding - Wednesday, Nov 15, 2006 at 12:16
Just a comment on the e-mail flow consistency: it doesn't really matter but if I "Reply" to a thread I have started I receive an e-mail copy of my own reply whereas if I "Follow-up" to any reply I don't receive an e-mail copy of my follow-up.
Mike Harding
465013
Follow Up By: ExplorOz Team - David - Wednesday, Nov 15, 2006 at 12:29
Mike,
This is correct and is as per my info above. In general you should not receive replies to your own however in the case of a Reply to your own thread this currently does happen. It will not when the next release of the
forum is completed in a couple of weeks.
465015
