Tray Topper
Submitted: Wednesday, Nov 15, 2006 at 12:15
ThreadID: 39467 Views:7143 Replies:5 FollowUps:3
Hi All,
I saw this at the Melbourne 4x4 Show & have been waiting for web info to be available - www.outbackcampers.com.au/tray_topper.htm
No association, but I like the direction the design is heading & would be interested in others thoughts.
To start the ball rolling - some thoughts that lead me down this path...
Two people per vehicle seems to be about right for longer trips - more people means more luggage, food etc leading to an overloaded vehicle potentially.
Having settled on two-up, no need for the extra seats - so a ute with a dust & waterproof canopy for food & gear seems logical & easier to get to said gear & food than via wagon doors.
Off-ground camping as per CT, but no towing avoids reducing 4WD capability of the rig. (Although drum brakes & leaf springs may compare poorly with wagon spec)
"Quick set-up, camp anywhere" is a desirable goal & the most common criticism that I have seen of roof-top tents is that once camp is set up, the vehicle is effectively immobilised. Hard-top flip-up 'tent' on this thing, shouldn't need to be set up until bed-time, so vehicle is mobile until then (unless you in the middle of cooking!) & set-up time would be measured in seconds, it seems - bedding stays in place all the time, release two catches & struts do the rest.
I probably wouldn't bother with the awning shown.
One of the features they should be making more noise about is that you can stand up in it! It's a bit hard to tell from the picture, but the ladder leads to tray level & some of the area (behind where they have the stove) has been boxed in to create a 'foot well' standing area - great for getting (un)dressed & leaving your boots overnight. Also means getting out of bed is a ‘swing your legs over the side’ exercise (into the foot well) - I must be getting soft!
They have incorporated a water tank into the thing, but I suspect this would be better under the tray (keeping weight low) along with the long-range fuel tanks!
Putting two spare wheels on the back would clash with the rear entry, so I wonder about the practicality of mounting two spares behind the cab (which would require a shorter canopy of-course. Would these two spares, between the back of the cab & the front of the canopy be painful to load/unload? I’ve seen a couple of these set-ups but not had a chance to have a good look at them.
Kids are 9 & 11, so it will be a while before I can justify my ultimate 4WD camper – very long term planning!
All comments appreciated!
Thanks & Regards
PGK
Reply By: SunWizard - Wednesday, Nov 15, 2006 at 13:57
Is essential to have a screened covered in area for cooking sitting and eating.
Mosquitoes sand flies blow flies normal flies moths bugs make an outside non protected kitchen area a no go. You would find you would be carting around a screen house cartons of rid and all sorts of extra to overcome the design deficiencies for the Australian bush. The other issue is how long would your wife and kids put up with mosquitoes and flies.
AnswerID: 205110
Reply By: Muddy doe (SA) - Wednesday, Nov 15, 2006 at 15:45
Hi PGK
Looks like a cross between Trayon, Candy Canvas and a Heaslip.?
My advice is research your CT, take the time to decide and get the one that is going to suit your budget and more importantly - your needs.
Cya
M.O.H.
AnswerID: 205129
Reply By: Member - Craig D (SA) - Wednesday, Nov 15, 2006 at 16:06
Hi PGK, have a look at my Rig and Profile to what I ended up with :)
AnswerID: 205132
Reply By: Member - Duncs - Wednesday, Nov 15, 2006 at 22:35
Had a look at that exact unit on a 75 at Innamincka about a month ago.
It seemed to suit the couple using it very well. I thought it would be a little cramped but they were happy.
I am not sure how it had been done, maybe a longer tray or just slid hte camper back on the tray, but this guy had a slide out locker in front of the camper. He had the spare(s) on a small roof rack over the cab and had built a winch to get them on and off. He was a retired engineer or something like that, he had lots of time on his hands and more skill in that area than me.
I have seen a better set up. It was a modified Heaslip on a cut down GQ wagon with airbags in the rear end. It was smick, very quick to get the camper on and off the tray and had the comfort of the wagon.
Duncs
AnswerID: 205214
Follow Up By: PGK - Thursday, Nov 16, 2006 at 09:21
Thanks Duncs,
Cutting down a wagon seems like a lot of work!
PGK
FollowupID: 465239
Reply By: Member - Barry (NT) - Thursday, Nov 16, 2006 at 00:52
PGK
We looked at options too. See pics in profile - I dropped a JPEG plan I designed for a pod on the back for off road desert type trip we are planning into profile. It is being built now and it contains built in stainless water tanks and 2 tyres on rear. It retains the canopy shown and the "pod" slides in under.
Spend many hours of research and quotes to build interstate but best deal locally - hope to have construction pics soon.
If you give me your email I will send the JPEG full size if interested, just disregard the "framing" shown in the plans as modern techniques eliminate some of this.
Barry
AnswerID: 205247
Follow Up By: PGK - Thursday, Nov 16, 2006 at 09:33
Thanks Barry,
Very interested to see a full size JPEG - and the finished product when it's ready!
Thanks & Regards
PGK
Peter.King@gsjbw.com
FollowupID: 465242
Follow Up By: Member - Barry (NT) - Sunday, Nov 19, 2006 at 00:38
Hi Pete emailed the full size JPEG been off line lately Cheers Barry
FollowupID: 465647
