Help installing TV antenna
Submitted: Saturday, Nov 18, 2006 at 19:10
russellb
Ok need some feedback .. was going to install one of those wind up Winegard antennas
With no experience installing wiring in caravans .. can you run wiring through the walls and if so how on earth do you get access ??
thanks
Russell
Reply By: Wingwang - Sunday, Nov 19, 2006 at 11:07
May suggest you ask on the Caravan
Forum where they are talking about that type of thing all the time.
205723
Reply By: Mr Fawlty - Sunday, Nov 19, 2006 at 15:11
You have the installation manual??? If not download it here www.winegard.com/mobile/pdf/2452013.pdf
I have had a close look at the post manufacture installation on my Gin Palace. It has been cleverly positioned so that when it was installed they removed one of the skylights that gave access to the space between the roof so that the cable could be run via the roof cavity then into a cupboard then into the back of the amplifier assembly, all very neat & unseen unless you start looking...
Good Luck
205768
