underbody lubricant
Submitted: Monday, Nov 20, 2006 at 13:06
ThreadID: 39615 Views:2472 Replies:3 FollowUps:2
after sand driving and a good wash i spray 'inox' over all fittings and conections as everything is dry. any better product suggestions besides sump oil. thanks for any tips from the experts.
Reply By: Robin - Monday, Nov 20, 2006 at 13:28
Can't afford Inox here Peter.
Just use can of $2 water disperent..
But I spray before trip to limit muck collection, and just wash and let mine dry after trip.
Used to use fish oil after , but didn't really see advantage so stopped.
Robin Miller
AnswerID: 205898
Reply By: DIO - Monday, Nov 20, 2006 at 16:35
G'day peter, I use LANOX a heavy duty anti-corrosion spray that contains Lanolin. It is far superior to the $2 de-watering sprays that dry out after a short time and don't offer any long term protection. Lanolin is a natural preservative and won't wash off in water. Available in pressure pack spray cans or bulk (use your own spray device). Not all that expensive either.
AnswerID: 205922
Follow Up By: Member No 1- Monday, Nov 20, 2006 at 16:55
inox has lanolin as well..but from memeory not in same strength/concentration
FollowupID: 465880
Follow Up By: Member - Oldplodder (QLD) - Monday, Nov 20, 2006 at 17:21
Just be careful spraying lanolin products around electrical connections.
It is a good insulator, and once on is very hard to remove.
You need the citrus acid based cleaner like Lanotec sell.
Friend found out the hard way, and kindly let me know.
FollowupID: 465886
Reply By: lindona - Monday, Nov 20, 2006 at 19:54
Innox is sprayed on seaplanes after. Would think it is ideal for 4WD however if corrosion protected, would need to find out if it effects the corrosion proofing applied.
AnswerID: 205958
