how much oil
Submitted: Tuesday, Nov 21, 2006 at 18:03
ThreadID: 39667 Views:2018 Replies:5 FollowUps:3
I have a GU td 4.2 just used the CEM oil flush on it, bugger all crap came out
So far so good... the manual I have tells me it holds 9.5 litres of oil including filters
My question is I have re filled with oil, just under 10 litres but the dip stick
Only just shows oil….just how much oil do they hold
I can be to sure but….the last service I’m sure I put in some where around 13 litres
Any ideas…it’s a Dec 2003 Build
Reply By: Black Beard - Tuesday, Nov 21, 2006 at 18:08
Yeah, mine seems to take about 11 litres all up. Just enought to make you have to buy 3 bottles!!
AnswerID: 206163
Reply By: honestjohn - Tuesday, Nov 21, 2006 at 18:21
i have TD42 GQ it holds about 10.3 litres of oil thats after changing both filters unless they changed the sump capacity from GQ toGU
AnswerID: 206166
Reply By: Pratty - Tuesday, Nov 21, 2006 at 19:36
Had the manual out for something else and just had a look. It quotes 10.5 litre with oil filters.
06 build if any help
AnswerID: 206189
Follow Up By: madcow - Wednesday, Nov 22, 2006 at 07:38
Mine's an 03 and used to own a 2000 and 10.5 litres would be correct. Given the size of the donk a bit over would not matter. You would probably find the same result for the GQ's as well for this motor.
FollowupID: 466204
Follow Up By: SA_Patrol - Wednesday, Nov 22, 2006 at 07:53
I have a July 2003 4.2td and it takes about 13 L with new oil filters
FollowupID: 466206
Reply By: Bobblcum1ce (SEQ) - Tuesday, Nov 21, 2006 at 22:12
When you put the oil in did you let it idle for about 1min. to let the oil through to the filter/s then let it sit for 5mins then check again.
Rob.
AnswerID: 206258
Reply By: Gmouse - Wednesday, Nov 22, 2006 at 08:25
Thanks for the info will get another 5 ltrs this morning
and yes i let it idle for a few mins to fill the filters and checked
again
AnswerID: 206322
Follow Up By: Gmouse - Wednesday, Nov 22, 2006 at 12:49
seems 11.5 litre's it is
FollowupID: 466270
