TECH question. VHF v UHF
Submitted: Wednesday, Nov 22, 2006 at 02:27
ThreadID: 39680 Views:8091 Replies:8 FollowUps:14
Would I be correct in saying VHF signal travels further and suffers less interference from trees and buildings etc than UHF?
And if so, then why is UHF the more popular frequency for CB?
MUZZ
Reply By: Mike Harding - Wednesday, Nov 22, 2006 at 07:16
It sounds as if you are trying to compare the two types of CB available in Oz? If so AM CB does not use VHF, it uses HF at around 27MHz.
Your statement is, basically, correct although it's much more complex - as you might imagine. Quite why UHF has taken over and HF is virtually dead I'm not sure; certainly audio quality is better on UHF and it's much less susceptible to atmospheric interference etc but HF will have a greater range, although as the max power is 4W range tends to be limited without a serious antenna.
In the 4WD world CB is used, almost exclusively, for car to car comms; with distance rarely exceeding a few km so, given the better audio and smaller antenna, it's a good choice. Although in places like the High Country it's often all but useless - in the bottom of the valleys you'll frequently be lucky to get 2km from it.
Mike Harding
AnswerID: 206310
Reply By: Footloose - Wednesday, Nov 22, 2006 at 07:21
Yes and no. No doubt he who knows and comments on everything will expound at length so I'll give let that little crumpet, trumpet.
To answer the second question, the frequencies that are used for various services such as CB, are allocated by a Govt Dpt (ACMA).
There is no CB on VHF.
If you're referring to 27meg , thats HF and a different ballpark.
AnswerID: 206311
Reply By: handy - Wednesday, Nov 22, 2006 at 07:38
you will find that 27meg and vhf are mostly used in the marine enviroment. cheers
AnswerID: 206314
Follow Up By: Polaris - Wednesday, Nov 22, 2006 at 16:45
VHF is also used extensively in Aviation.
FollowupID: 466319
Reply By: Member - Arkay (SA) - Wednesday, Nov 22, 2006 at 07:47
The "effective range" of UHF CB, officially called CRS for Citizens Radio Service, is frequently extended in many metro and larger country towns, and also in some outback locations, by the installation of repeaters on high ground. Repeaters can have a range of up to 60km or so because of this high placement. This means that UHF users can still talk to each other up to 120km away, or if your friend is over the far side of a hill or other object that intefers with line-of-sight communication. Repeaters all work on channels 1 to 8(only). Channel 5 is officially reserved for emergency communications. A list or where these repeaters are located is readily available from internet sources or any shop that sells the UHF radios. So you can see which channel to use where you are going, or are.
To operate a repeater you switch or programme your radio to "duplex" mode. Then the radio sends a signal up to the repeater on one frequency and re-transmits the signal back down on another. For example if you have the radio on Channel 1 duplex, then the radio sends the signal on Channel 31 and re-transmits it back on Channel 1, so anyone tuned to receive Channel 1 hears you. Hint, try to avoid transmitting on Channels 31 to 38 if you are likely to be anywhere near a repeater as you will also be heard all over the place on Channels 1 to 8.
VK5KP
AnswerID: 206315
Follow Up By: Member No 1- Wednesday, Nov 22, 2006 at 08:31
60K..and the rest for some....
can hit Burra repeater from northern boundry of Sturtvale station 100klicks..havent tried any further...signal was strong so i expect a lot further...this may be an exception though
FollowupID: 466212
Follow Up By: Kiwi Kia - Wednesday, Nov 22, 2006 at 19:41
Also sometimes known as PRS = Public Radio Service.
These radios have the same freq. and can be used in New Zealand but not the same in the USA. Don't know about other countries.
FollowupID: 466355
Reply By: Member - Bruce and Anne - Wednesday, Nov 22, 2006 at 08:08
VHF is dedicated Marine in Australia, it is line of site unless going through a good repeater. Range normally 10 nautical mile, but VHF radios are 25 watts compared to UHF 5 watts.
So why can't they make UHFs 25 watts, it a bit like marine gps plotters 5,7,10 inch screens, why can't we have that size in gps for vehicles?
Cheers Bruce
AnswerID: 206318
Follow Up By: Member No 1- Wednesday, Nov 22, 2006 at 08:33
cb's dont need to be licenced
marine does
one can get 25w gear but you'll need to licenced..:))))
FollowupID: 466214
Follow Up By: Member - MrBitchi (QLD) - Wednesday, Nov 22, 2006 at 09:24
"VHF is dedicated Marine in Australia"
Not so, or else there's lots of pilots in the drink ;-) VHF is used extensively in Aviation and other industries. The actual frequencies are different and are regulated by the International Telecommunications Union.
Marine CB (27MHZ) needs no license. Frequencies are only marginally different than terrestrial CB. These units are roughly the same power as standard CB radios.
Marine VHF can be up to 25Watts and requires a licensed operator, as does HF.
FollowupID: 466229
Follow Up By: Michael Carey - Wednesday, Nov 22, 2006 at 19:57
You do have a choice with GPS screens. For instance the Garmin Streetpilot 7200 has a 7 inch touch screen (but lacks traditional GPS functions like easy to use waypoints and tracks).
Virtually all the Gamin marine range of "chart plotters" can be loaded with City Navigator or Tracks4Australia maps, then you can have HUGE screens, but with a huge price tag attached...
FollowupID: 466358
Follow Up By: Member No 1- Wednesday, Nov 22, 2006 at 21:05
Micheal....WAKE UP!...(SHAKE SHAKE SHAKE slap or two around the earhole)
we are not talking about GPS's or Navigators in this thread
FollowupID: 466374
Follow Up By: Michael Carey - Wednesday, Nov 22, 2006 at 21:47
Well, I wasn't the one to mention GPS in this thread first. I thought I could provide some information about GPS screen sizes that was mentioned in a previous post.
Quote, "it a bit like marine gps plotters 5,7,10 inch screens, why can't we have that size in gps for vehicles?".
Next time someone mentions/asks something that my 20 years of electronic/radio/computer/marine/cartography experience can help, I'll just shut up...
and before I shut up, another correction, marine radio equipment isn't licensed, the ship/boat is. And this only applies to marine HF. Marine VHF/27MHz is covered by a class license, but the operator of a VHF Marine radio needs to have a ROCP.
FollowupID: 466380
Follow Up By: Muzzgit [WA] - Thursday, Nov 23, 2006 at 01:12
So if I was to buy a commercial UHF @25 watts and had it re-programmed to the 40 channels for CB, would it need to be licensed because of the higher power output?
I currently have a really really old one which is @18 watts but I think it's near it's end.
I was just thinking aloud - re the question about VHF. I googled uhf and found same great reading, and the question popped into my head that VHF seemed to be better suited to what we all need.........better clarity than the old 27 meg and better distance than 477 meg.
Site for repeater stations http:// www.tropinet.com/uhf-repeaters/search.html State by state listings.
FollowupID: 466432
Follow Up By: Member No 1- Thursday, Nov 23, 2006 at 08:06
Muzzgit...UHF Cb is only allowed to transmit max 5w power.....so who told you that you can get commercial sets reprogrammed @ 25w..:))))) lol
FollowupID: 466456
Follow Up By: disco1942 - Thursday, Nov 23, 2006 at 10:57
Commercial UHF sets may be set up to work on the UHF CB channels. If a UHF set conforms to Australian standards it will be programmed to drop its output power to 5W when you select a CB channel.
The sets that produce more than 5W OP on CB have had their out put power circuitry modified/disabled. This results in the power OP not being controlled and they transmit more than 25W on every channel. This makes them illegal to use on all channels. It also can result in failures in hot weather as their cooling may be severely limited.
FollowupID: 466474
Follow Up By: Member No 1- Thursday, Nov 23, 2006 at 11:03
if I and my mates buy commercial uhf sets why would I get it programmed to drop power when transmitting....oh silly me... i must...to be legal
FollowupID: 466475
Reply By: Grungle - Wednesday, Nov 22, 2006 at 10:49
I deal with radio communications in the mines up here in Central Qld. We tend to see greater distances in the VHF Mid band (70 MHz) and VHF High band (160 MHz) than the UHF bands (400 - 520 MHz). Thats using 25W mobiles and 50W repeaters. The differences in distances are not all that great but can be up to an extra 20 kms in the 70 MHz band. You don't find too many mines that still operate at that frequency as most have shifted to the 160 MHz and 480 MHz bands but a lot of the Emergency Services and Councils still operate on 70 MHz.
The lower the frequency (typically 2-30 MHz or 'HF' band) the more ability one has to skip the signal for greater transmission distances. Depnds on frequency and time of day / night though.
As for interference I would say AM suffers more than FM therefore you will get interference on the old 27 MHz and HF sets moreso than the 477 MHz UHF sets (HF users, correct me if I am wrong).
UHF is more popular as when it comes to the unliscenced CB bands, you have the choice of 27 MHz AM or 477 MHz FM and 477 is much clearer and interference free but is also supported by a great repeater network.
David
AnswerID: 206349
Reply By: John R (SA) - Wednesday, Nov 22, 2006 at 17:07
Simply put, UHF is cheap, easy, standard and free (once you've got the radio).
With UHF, buy a radio for anything up to $500 and you're away. No licencing required, and they're standard so your mates, or anyone else with a UHF radio, can be easily contacted (assuming you're in range and on the same channel).
VHF requires licencing and you get assigned a frequency (I presume?), so although it's private and the range is generally better, you have to basically create your own network - make sure whoever you want to talk to has a radio programmed to your frequency. And that tends to require a more expensive radio (but not always), however it has to be programmed in most cases by a dealer.
For instance, yesterday we went over to victoria to fight some fires. Vic CFA has their own vhf frequencies, CFS shares them but uses different channels on the fireground, and there were independent outfits there; blue gum fire units, farm units, and a Cat challenger cutting a trail.
All the vic trucks, the farm units, Challenger, & the forestry guys had uhf as well as their own vhf, so to work together they just went to uhf ch 10. SA doesn't have uhf in their trucks as a rule (or at least we don't), so when we were trailing the cat & trying to contact a bloke 10m away, we had to call our command car on vhf, and they'd relay on uhf.
Next time, I'll take a uhf handheld, and I'll be able to contact the challenger, farm units, blue gum units, SAPOL (if they've got theirs turned on).
Much easier!
AnswerID: 206406
Follow Up By: Member - Arkay (SA) - Thursday, Nov 23, 2006 at 08:51
And that's not saying anything about the wonderfully expensive new SOuth Australian Government Radio Network (GRN) system which was supposed to solve all those different system/frequency problems, but so far has proved to be very clumsy for use in "live" fireground situations, where simplex communications between close-by crews seems to be the preferred method. Thus every fire-fighting vehicle if properly equipped has a wonderful array of different radios for different purposes. Just hope you grab the right one if it ever gets urgent.
FollowupID: 466461
Follow Up By: John R (SA) - Thursday, Nov 23, 2006 at 11:58
What a wonderful thing the GRN is. When it works. And an absolute balls up when things get busy.
It's certainly evolved to be the command-only radio, and vhf for fireground comms and that works well. Mostly.
However on tuesday the regional talkgroup seemed to bleep itself - HQ in Naracoorte wasn't receiving traffic from much south of there, though they were receiving transmissions from the north. It was as if there were two pockets independently using the same talkgroup without hearing each other, all within a couple of hundred km.
FollowupID: 466480
Reply By: Ianw - Wednesday, Nov 22, 2006 at 21:17
The lower the frequency the more the signal is able to bend and follow the earths curvature. Thats why HF has more range than VHF and UHF. UHF and above are virtually line-of-sight. In some circumstances UHF signal can bounce off the ionosphere and get better distance with a dead spot in the middle. Some old military nav systems used freqs as low as 13hz and had a range of halfway around the world.
AnswerID: 206448
