fuel problem
Submitted: Wednesday, Nov 22, 2006 at 23:17
taepro
hj75 2h.
after letting the truck sit for a while i start it up get about 300 m down the road and it stops. i have to get out and bleed then it runs fine till i let it sit again. it's getting air in somewhere.. any ideas
Reply By: 666toy - Thursday, Nov 23, 2006 at 00:10
g day ,
check all hoses for perished cracks, fuel filters ? , i think there is a gauze strainer in the banjo inlet to the fuel pump on the 2h. is there any crap in the fuel
tank ? have seen damage rubber hose acting like a
gate valve internally allso i think there is a one way valve in the fuel pump . check all banjo fittings & lift pump (yes the lift pump can let air into the system) allso check the pick up line to the
tank & the actual
tank pick up .(i have seen these fracture very rare but does happen) the valve under the lift pump as
well...hope this helps ...666toy
206479
Reply By: Muzzgit [WA] - Thursday, Nov 23, 2006 at 01:27
Old rubber fuel hose can have very fine cracks that will allow air too be sucked into the system.
206483
Reply By: Kiwi Ray - Thursday, Nov 23, 2006 at 07:49
Hi. Iwould look at the "O" ring in the bottom of the fuel filter. These can cause all sorts of problems at times.
It souns like your truck runs on the fuel in the filter then stops as it has not been able to suck up the fuel from tha
tank.
I would replave it and keep a spare in the truck
Hope that is of some help
Ray
206487
Reply By: taepro - Thursday, Nov 23, 2006 at 21:21
thanks guys for the info.. i started by bypassing the
water trap because i got told they can get a pin prick size hole in them. since then i have had no drama's. next thing i am about to do is reconnect it with new lines because the old one's look pretty shot. if that does not work
well hopefully i found the problem..
206589
Follow Up By: taepro - Tuesday, Nov 28, 2006 at 22:19
well it looks like it was the
water trap it's self.. is it safe to drive around with out it or should it be replaced
467350
Reply By: taepro - Wednesday, Nov 29, 2006 at 23:06
could i use a cav filter instead of replacing the banjo filter
207669
