snapped lower control arm
Submitted: Saturday, Nov 25, 2006 at 16:11
98nav
g'day all
i was just driving to local shops when i heard a crrunch and the front drivers side dropped to the ground , wheel pushed back into gaurd and ground to a halt , i was doing about 50 kph . scared the hell out of the family, it seems the lower control arm has snapped in half. bugger . has this sort of thing happened to anyone else ? is it just a navara thing ? what would be the cause of this ? i'v owned the car for 1 yr and never hit anything .
any advise help or opinions would be most welcome. 98nav
Reply By: guzzi - Saturday, Nov 25, 2006 at 17:26
Glad to hear no-one was injured.
1998?
No its not a navara thing, IFS 100 series toyos maybe.
Where exactly did it snap?
Possible causes are many,
Modified lifted
suspension?
If unmodified nissan may have a problem but its 8 yrs old, if second hand possible damage from previous owner or someone has possibly modified it or welded it.
Or most likely its copped a thump at some time and corrosion and fatigue has done the rest.
This isnt a common event, thank god.
It would be nice to get the remains checked by an automotive engineer or metalurgist but that costs money, thats up to you and whether you want too or can take the matter further.
Good luck
206861
Reply By: 98nav - Saturday, Nov 25, 2006 at 18:03
thanks for feedback guzzi
no it has no modifications to
suspension , from what i can tell it snapped right through the area where the ball joint sits in the control arm . what you say makes sense about previos owner possibly hitting somthing . thanks mate
206865
Reply By: Oldsquizzy (Kununurra) - Saturday, Nov 25, 2006 at 19:20
Check the other side as
well. Usually caused by a big bounce, washout floodway hit way to fast, Arm hits bottom stop and wheel keeps trying to go up, Bends the end of arm and weakens it.
206871
Reply By: 98nav - Saturday, Nov 25, 2006 at 19:32
great explanation squizzy
that allso makes a lot of sense , i can picture exactly what you mean, i'v just about pulled the control arm off and noticed another crack 50mm/2inch long at the base where the bottom of the shock bolts to the lower control arm. so it looks like i will be checking the other side very closely and then getting the local mechanic to double check for me.
thanks mate
206872
Reply By: Member - Phil G (SA) - Saturday, Nov 25, 2006 at 20:07
The 90series Prados were doing something similar, but the problem was that the lower ball joints were defective and coming apart. Makes a huge mess of the front end. Toyota did a recall. Haven't heard of this with the Navara.
206875
Follow Up By: 98nav - Saturday, Nov 25, 2006 at 21:42
thanks phil
each bit of info makes me feel a bit better, by the way love your cruiserif only i could get one in duel cab, maybe 5yrs from now.
466861
Follow Up By: Member - Phil G (SA) - Saturday, Nov 25, 2006 at 22:40
Yep, we like the setup - its a good way to travel once the kids are grown up - nothing to unpack - just pull up at
camp, open the sides and you're set for the night. It will be interesting to see what the new troopie will be like.
466878
Reply By: Eric Experience. - Saturday, Nov 25, 2006 at 21:29
98 nav.
Talking to a mate in Erica in Vic. about 2 years ago, he mentioned that some navaras were being tested in the bush there and 2 of them broke the bottom wishbone on the same test . Nissan will know about it. Eric.
206886
Follow Up By: 98nav - Saturday, Nov 25, 2006 at 21:45
thanks eric
i will follow that up , dont know how much luck i will have but its worth a try.
466863
Follow Up By: Flash - Sunday, Nov 26, 2006 at 22:31
That's why I love a live axle.
Hope your troubles don't cost too much.
Good luck!
467004
Reply By: Member -Signman - Monday, Nov 27, 2006 at 13:18
G'day
Are the lower control arms the U shape channel pressed steel- or are they a cast type steel ???
207103
