Dp Chip for 3.2 Pajero ?
Submitted: Saturday, Nov 25, 2006 at 20:59
ThreadID: 39772 Views:4151 Replies:2 FollowUps:3
Hi can anyone who has fitted a Dp chip to a Pajero tell me if it works a good as they say.I had different brand fitted and after Dyno it only gave under half of what they said.
Thanks Mark
Reply By: marq - Sunday, Nov 26, 2006 at 09:36
Do you really need to chip the DiD?
AnswerID: 206927
Follow Up By: markcas - Sunday, Nov 26, 2006 at 17:01
I want more power down low when towing my 1.5 tonne van through soft sand.Have you got a better idea ???? if so let me know as i thought the chip was the way to go.
Mark
FollowupID: 466942
Follow Up By: Member - Andrew (QLD) - Sunday, Nov 26, 2006 at 17:58
Check out some information discussed about the Dtronic Chip and some ideas on how to increase performance down low....not sure if the information is correct, though it sounds good.
I'm happy with my DiD Pajero towing the heavy Kimberley Kamper through soft sand, especially with correct tire pressures (including tralier), appropriate gear selection etc. I figure the vehicle is designed for certain conditions.....go outside these conditions and one should change the vehicle.
FollowupID: 466959
Follow Up By: Member - Andrew (QLD) - Sunday, Nov 26, 2006 at 18:00
I'll try the link again....forgot to close the brackets properly and it just disappeared altogether :-(
link here ==> Site Link
FollowupID: 466960
Reply By: blackmax11 - Monday, Nov 27, 2006 at 16:27
I have a DP Chip fitted to a L/C 100 and it is great. Get 19L per 100 towing a 25 Jayco at whatever the speed limit is. Around town about 11 L per100. Certainly more grunt than without.
AnswerID: 207132
