help with AT35 hitch
Submitted: Sunday, Nov 26, 2006 at 18:16
ThreadID: 39791 Views:5002 Replies:9 FollowUps:5
Hi all,
Does anyone have any "secrets" they might care to share with regard to connecting an AT35 hitch. I tossed up when buying the CT between the AT35 and the Hyland but went with the AT35 based on strength, lack of warranty claims, security etc. I have since found the AT35 to be an absolute cow when it comes to reconnecting on anything but a flat smooth surface (it's deceptively easy hooking up in the shed, a nightmare everywhere else). I know the theory - get it close than push/pull it the last inch or two. Not so easy when the main tyres and the jockey tyre have buried themselves slightly in the turf or sand.
Am I better off swapping to a Hyland? Will the Hyland fit the same holes on the drawerbar as the AT35. I have heard that the Hyland is noisy due to the lack of poly bushes?
We are preparing for our first "big" trip in April 07 (red centre) with some semi0serious stuff thrown in (davenport ranges, ruby gap etc).
All help/advice greatly appreciated by myself and the wife who has to put up with the ranting and raving at the end of an otherwise great camping trip.
Reply By: Mobi Condo - Sunday, Nov 26, 2006 at 19:11
Howdy fatfrog,
We have an AT35 on 2440Kg tare van - have found it very easy to use after the initial time of realising that ANY forces from either van or TOJO will make it difficult. I can align it easily with use of the mirrors for centality of hitch to TOJO then with it the correct height a slight nudge in reverse LR means a little use of a ratchet jockey wheel and presto - less than 5 minutes from go to wo and I am hitched.
I keep it well lubricated as well!.
Cheers - Mobi
AnswerID: 206979
Follow Up By: Hopper51 - Monday, Nov 27, 2006 at 12:49
Hey Mobi
What's it like after you have backed into a big rock at Talia?
Hopper_51
FollowupID: 467057
Follow Up By: Mobi Condo - Monday, Nov 27, 2006 at 21:08
Phwat a cheeky Hopper_51 u r!
All the cheek - to mention private matters in a public forum :-)
It was, I found out later, TWO rocks and I pushed the exhaust in a bit which made it rattle agin the chassis a tad!
Oh - Well wots a scar or two on a 4By any way!
Cheers - Mobi
FollowupID: 467141
Reply By: SimonW - Sunday, Nov 26, 2006 at 19:37
Hi Fatfrog,
Don't know about the AT35 so cannot comment but we have a Hylander hitch on a Kanga camper, & I can assure you that they do not rattle or make any noise regardless of the surface being travelled on, if that did occur there is a simple adjustment on the hitch that can be set-up for the ball clearance. It is easy to couple to the vehicle as it will align itself on the ball as you lower the hitch.
Cheers Simon.
AnswerID: 206985
Reply By: GeoffMc - Sunday, Nov 26, 2006 at 19:52
Hi Fatfrog
I have an AT35 on our Odyssey CT and in the beginning had the same problems as you, but solved it by making up a 300 x 300 piece of ½ inch ply with a 20 mm lip all the way around it. Always let the jockey wheel down on it and it’s a cinch when it comes to hooking up. The lip’s important so that the jockey wheel doesn’t inadvertently roll off the ply. A simple solution, but has worked well for use over the last couple of years.
Cheers … Geoff
AnswerID: 206986
Follow Up By: fatfrog - Sunday, Nov 26, 2006 at 21:16
Hi Geoff,
thanks for that. I mentioned that idea to the wife today, and will try it out next w/end.
FollowupID: 466991
Reply By: Member - Willie , Epping .Syd. - Sunday, Nov 26, 2006 at 20:59
Mr Frog ,
Is an AT-35 a Treg ?
Willie
AnswerID: 207000
Follow Up By: fatfrog - Sunday, Nov 26, 2006 at 21:14
Hi Willie,
no, an AT35 isn't a treg. It is made by Vehicle Components in Brisvegas. www.vehiclecomponents.com.au
FollowupID: 466990
Reply By: Member - Crazy Dog (QLD) - Sunday, Nov 26, 2006 at 22:30
yep it is a bugger - BUT there is light at the end of the tunnel.
Do what my wife and I do - don't disconnect the hitch but pull the pin from the towing tongue and let the whole lot slide out. When re connecting just reverse the whole thing. Only the hitch pin to engage. We are both 60 yo so if we can do it you can. Don't get rid off the AT35 it is a good hitch..
Grrr!!!
AnswerID: 207016
Reply By: Motherhen - Monday, Nov 27, 2006 at 00:10
We have no trouble hitching up, but sometimes if the levels aren't right, it is almost impossible to remove the pin to unhitch. Winding the jack (or jockey wheel) up or down can improve the situation, and sometimes reversing the Patrol or leaving it in neutral is all that is needed. To hitch up, my husband can do it by himself (he says quicker and easier than with me giving him directions) by clearing a sight path through open rear doors (we have not used the camera for this).
When i am hitching, he backs, and even with the heavy caravan on a fixed jack, there is enough flexibility to nudge it with my knee if it needs and inch or two sideways movement. Leaving the Patrol in neutral if it is flattish and safe to do so makes it easy too.
We purchased a jockey wheel with ratchet to assist but have never needed it.
Crazy Dog's idea may be worth trying when unhitching is difficult, although i think the tension problem would still occur, but if it works for him, give it a go.
We chose the AT35 to give us the flexibility we needed over a ball hitch, as when we purchased the caravan, the set up had been modified so that i needed to hold the tongue whilst my husband backed exactly onto it, with me holding it with both hands unable to give hand signals, and him unable to hear me over the diesel motor, and i had to hold it steady. It also had to line up exactly to the pin - saying go forward 2 mms could result in the Patrol moving forward too far and the tongue dropping out again. Fine at home, but difficult if unable to back straight onto it, hence the change to what we find an easy option.
AnswerID: 207038
Reply By: Member - Ozdyssey (QLD) - Monday, Nov 27, 2006 at 08:35
fatfrog
It's a love/hate relationship with the AT35 - mainly hate ;-)
I went to Vehicle Components and got them to give me the run down.
First thing was don't use grease on the pin only in the grease nipples on the hitch etc. They suggested silicone spray instead. This has made a big difference. The hitch needs to be generally free of grit so it doesn't bind or jam up. It's easier to keep clean and keep any grit out using silicone spray and you don't get grease all over you and your clothes every time you hitch up.
The silicone spray also doesn't attract as much grime on the road. Only thing here is you need to give it a quick spray every week or so on the road. I have been using the silicone for 6mths with no problems.
If you don’t know already when unhitching you must have no tension on the pin. Wind the jockey wheel up until it starts to lift the vehicle then slowly back off, winding down, until you see the hitch drop around the pin. You need to watch carefully as it is only a very slight movement. It should then come out easily.
Also, where the spring on the pin ends at the top this end can sometimes catch on the locking lug when trying to release and turn the pin. Make sure this top end of the spring is turned around on the pin towards the rear or camper out of the way before locating the pin when hitching up.
VC mentioned they may be changing the design slightly to help the hitch locate better by widening the receiver instead of tapering it near the pin holes, if that makes sense.
We also use our jacking plate under the jockey wheel when in soft ground, makes life easier. Stick with it, it’s a very safe hitch and once it’s locked on it can’t come adrift and the articulation is ridiculously good.
Half the battle is lining it up in the first place, god knows how people do it with a caravan, a lot of Bushtrackers have this hitch but use power wheels.
We’ll be getting the Hyland when we get the van though. :-)
AnswerID: 207058
Reply By: Member - Norm C (QLD) - Monday, Nov 27, 2006 at 09:22
I think it has been pretty well covered. Hooking up is no problem, and I do that alone without any problems. Saves the arguments with the wife over which way she said, and how far!!! The reversing camera is great for this.
Only problem we have had is in disconnecting a couple of times and getting the pin out. Releasing pressure by adjusting the jockey wheel and occasionally moving the vehicle a touch overcomes this.
I also put my jockey wheel on a wooden jacking plate when on soft ground. The idea of putting a small lip on it to stop the wheel rolling off is a good one. I'll give it a try.
Overall though, The AT 35 is a great hitch.
AnswerID: 207065
Reply By: fatfrog - Monday, Nov 27, 2006 at 13:04
Thanks everyone for your tips and suggestions, I will try them out over the coming w/ends away. It sounds as if I might need something which I don't possess ... patience.
AnswerID: 207100
Follow Up By: Lango - Saturday, Dec 02, 2006 at 22:12
Yes it is a a bit of hassle but from all accounts they are the best!
I have the ply base but have oftened wondered about leaving the tongue assemby hooked up and only removing the towbar pin.
Also the sugestion to use silicon grase sounds good.
Happy camping.
FollowupID: 468173
