Speedo Corrector
Submitted: Wednesday, Nov 29, 2006 at 18:01
Groove
Hi All
This issue has come up from time to time so thought this may be of use.
Decembers Silicon Chip Magazine has plans in it for an Speedo Corrector. This is an electronic device that can be used to allow your speedo give accurate readings even if using different size tyres to the original or diff, gearbox ratios etc.
Requires a bit of electronics knowledge to assemble but not to difficult.
Reply By: Truckster (Vic) - Wednesday, Nov 29, 2006 at 19:21
Marks adapters have them over the counter, have had for 12+ mths
also available on Ebay.
207603
Reply By: Groove - Thursday, Nov 30, 2006 at 11:45
The same mag also has plans for a dual battery controller. Kit available for $19 rated at 80 amps .
207752
Reply By: Gerhardp1 - Friday, Dec 01, 2006 at 11:34
You can get the kit at Jaycar.
207944
Follow Up By: Gerhardp1 - Friday, Dec 01, 2006 at 11:35
Forgot to add, I use the Scanguage, it has the speedo corrector built in and does heaps more stuff as
467836
