wiring
Submitted: Wednesday, Nov 29, 2006 at 18:46
Member - Ron O (VIC)
Howdy all before l have to many hooroo juices (home brew spririt) can you tell me what would be max length of cable from 80 watt solar panel to battery. Thanks all
Reply By: Eric Experience. - Wednesday, Nov 29, 2006 at 21:53
Ron
The wire can be as long as you like. there will be a small loss of power if you go to far with thin wire but say 10 metres of normal 4mm wire will be fine. to measure the loss just check the voltage at the panel and then at the battery when charging the difference will be the loss. Eric
207648
