Jaycar Isolator - any experience ?
Submitted: Saturday, Mar 22, 2003 at 11:05
ThreadID: 3990 Views:2644 Replies:7 FollowUps:1
Reply By: AK - Saturday, Mar 22, 2003 at 11:42
Phil I had a look at it and it comes as a kit you have to solder all the electronic components together on the PC board. You may be better off with a staight solenoid plus a diode for your $50 or I think redarc make a half smart isolator with low voltage cut for about $100.
AK
AnswerID: 15846
Reply By: joc45 - Saturday, Mar 22, 2003 at 12:06
Hi Phil,
Recall this is an Electronics Aust design, in which they 'fessed that there was a design limitation (an inbuilt protection diode in the FET may not take the reverse current). They explained this away saying that if both batteries were in good condition, this should not be a problem.
Get the commercial one - worth the extra $.
rgds
Gerry
AnswerID: 15848
Reply By: diamond - Saturday, Mar 22, 2003 at 20:24
ive noticed here that solonoids ect are a lot like nissan/toyota lots of different opinions i asked the question a while ago about solonoids and ended up going to repco and bying a starter motor solonoid for $30 bought an in line circut breaker $10 30 amp so if main batt goes flat it cant start from second bat im running 6mm wire x2 direct from alternator to second bat and have not had any troubles yet at all 2 batt fully charged couldnt see the point in being silly and spending #200+ on batt manegment bit silly to me if you still have to batts one for acc and one to run car but thats just me im a scott and hate spending money lol
AnswerID: 15881
Reply By: Phil P - Sunday, Mar 23, 2003 at 09:01
Thanks for your replies, I'll purchase the Redarc Isolator !
Any suggestions where I can purchase this from in Melbourne & the price ?
Phil P
AnswerID: 15898
Follow Up By: Wazza - Monday, Mar 24, 2003 at 08:56
Hello Phil,
I contacted them via the web submission for a month or two ago, here was the reply (asked for price as well, but never got an answer. Must be up to individual supplier/fitter!):
Thanks for your response. Please contact the following local Auto
Electrician who can quote supply and fitment:-
Auto Electrical Service
Contact:- Bob
81 Arden Street
North Melbourne Vic
Tel: 9329 9652
If you would like to discuss your application further please do not hesitate
to contact our Senior Technician, Lex Clarke on 08 8186 5633 and he will
endeavour to answer any of your questions.
Kind regards
Anthony Kittel
Managing Director
Redarc Electronics
21 Heath St
Lonsdale South Australia 5160
Ph: + 61 8 8186 5633
Fax: + 61 8 8186 5644
Wazza
FollowupID: 9747
Reply By: Member - Colin- Sunday, Mar 23, 2003 at 12:08
In regard to battery protection, I am using a PROJECTA brand, over discharge protector, which I purchased from Kmart for $20 ! I plug it in line before my frig (3 way Sadec) and it cuts out power at 11.2v (max load 10a). Compact size 8 x 5 x 3 cm. Very handy when leaving the car to go shopping etc. as I dont have dual batteries and the frig draws a constant 5a (approx).Colin - Subaru Forester
AnswerID: 15904
Reply By: Indy - Tuesday, Mar 25, 2003 at 14:13
Phil,
I built one of the Jaycar kits up. I was less than happy with it. It took forever to charge the auxillary battery up. I believe this was because the alternator regulator was just sensing the main battery and cut its charge rate back when it detected the main battery was topped up. This left only a few amps to charge the aux battery for the rest of the day.
The unit attempts to be a 'smart charger' ie. senses when the main battery is full then directs the charge to the auxillary. The weakness is when the alternator regulator has no way of knowing there is a second battery in the system and just adjust its charge rate to suit the main battery.
Just buy the Redarc or I have heard of a cheaper alternative from Electrosystems.
Regards,
Indy
AnswerID: 16066
Reply By: brownie - Friday, Apr 04, 2003 at 23:02
I tried the Jaycar kit in my hj75, it didn't work for me & finished up in the bin. I now have a solenoid, seems to work well & is simple to wire up.
AnswerID: 16904
