AnswerID: 208198 Submitted: Saturday, Dec 02, 2006 at 17:48
Bilbo
replied:
Dirty,
I haven't done any diff work for years and I've never set up a Toyota diff. But generally speaking check the following:
The diff should be stiff to turn. When you turn the pinion, there should be a fair resistance in the crown wheel. That's the effect of pre-load on the bearings.
Inspect each tooth on the crown wheel for any signs of the case hardening breaking down on the metal surface. This can be seen as pitting or flaking of the metal.
Look for polish marks on the surface of the crown wheel teeth. These are normal but they must be in the correct place on each tooth. This is an indiaction of correct meshing of the teeth between the pinion and the crown wheel. The correct position for this "polish mark" is the centre of the tooth. And the "polish" mark shouldn't extend to the extreme edges of the teeth. The mark should be in the centre.
If possible, wash the gears of any oil and use Engineers Marking Blue Paste on the crown wheel teeth. Rotate the pinion and you should see exactky where the teeth are meshing. This is best done with a screwdriver or tyre lever UNDER the crown wheel whilst applying downward pressure, as if you were trying to liff the crown wheel.
These are just general rules and not Toyota specific.
Bilbo
| Remember - "Tomorrow is todays best labour saving device!" |
Reply 1 of 5
