Fittment of Lightforce 240's
Submitted: Saturday, Mar 22, 2003 at 23:27
SteveA
Has anybody out there fitted the new Lightforce 240's to an ECB Big Tube Bar for an 80 series. Did a little bit of measuring and it may be a tight squeeze. ECB wont tell me as they only sell the Oscars.
Reply By: Brian - Sunday, Mar 23, 2003 at 20:27
Fitted 2 240's into a Nissan genuine steel winch bar. Made 2 brackets that lifted and moved the lights back. They look great! Work even better.
Hope this helps Brian
15934
Follow Up By: Grungle - Tuesday, Mar 25, 2003 at 08:35
Hi Brian,
You wouldn't happen to have a couple of photos of the brackets would you? I have a set of 240's in the garage that need to be fitted to a Nissan bar but I need brackets to bring the lens behind the front of the bar and to also lift them up.
David
9805
Follow Up By: Brian - Wednesday, Mar 26, 2003 at 18:09
No, but may be able to do it ????
The brackets raise the light 35mm and move them back 40mm.
I used flatbar bent in an "S" shape . but If I had to do it again it would be flatbar for the base and angle for the up right and 5mm thick (no movement) send you email address and I will try to get photos to you!
Brian
9917
Follow Up By: Brian - Wednesday, Mar 26, 2003 at 19:50
Grungle Send your email and I will pass them on.
Brian
9925
Follow Up By: Grungle - Wednesday, Mar 26, 2003 at 21:32
Thanks for that Brian. My email is grungle229@optusnet.com.au
9928
Reply By: Truckster - Sunday, Mar 23, 2003 at 20:35
Lots of people are having problems fittin 240s to lots of bars.
it may be a tight squeeze in the end, but remember they have a big effect on air flow to the motor too, so cooling can be a problem.
YMMV.
15935
Follow Up By: SteveA - Sunday, Mar 23, 2003 at 21:53
Truckster, I asked the guy at TJM whether or not it would effect the temp and he said that he has got them fitted to a 100 series turbo and it doesn't effect the temp, so I'm hoping that it wont effect
mine (91 80 series turbo
9729
