Figures on Diesalgas
Submitted: Saturday, Dec 02, 2006 at 17:03
ThreadID: 39993 Views:3196 Replies:5 FollowUps:2
For those who have inquired in the past for our diesalgas figures, here they are finally.
We have had diesal/gas fitted to our 2003 LC, for some time now & are more than extremely happy with it.
When towing our 2.7 ton van, we get 17.2 litres diesal per 100, & 4.8 litres gas per 100.
On the highway & around town driving to speed limits, (not towing), 10.5 litres per 100 diesel & gas is about the same, as when we're towing, doesn't seem to decrease or increase.
When towing up hill, we do not have to change gears everytime we look at a hill, & our vehicle does not run hot.
Reply By: crewser - Saturday, Dec 02, 2006 at 20:24
Does the gas system have a regulator? I was thinking the system injected a set percentage of gas , does it inject a constant amount of gas regardless of diesel usage?
AnswerID: 208217
Follow Up By: Member - bill - Saturday, Dec 02, 2006 at 21:08
for all the tech answers go to www. dieselgas
FollowupID: 468155
Reply By: Twinkles - Sunday, Dec 03, 2006 at 00:14
How much fuel did you use before you dieselgas(sed) your vehicle?
AnswerID: 208259
Reply By: Member - bill - Sunday, Dec 03, 2006 at 08:45
i use to run tanks to fuel warning lights come on and get about 1050 km there was always diesel left in tanks with the diesel and gasi ran the car for 1002 km filled up it took 105.1 diesel and 48 litres of gas standard toyo tanks gas tank holds 37 litres
AnswerID: 208277
Reply By: Member - andrew B (Kununurra) - Sunday, Dec 03, 2006 at 22:09
All sounds good Bill - mine is in tomorrow, and booked for a dyno on the 18th so all will be revealed! I also have a fairly comprehensive spreadsheet on fuel useage, so I should be able to give some accurate figures on both economy and performance soon.
Now we just need bio up north!
Cheers Andrew
AnswerID: 208420
Reply By: Tim HJ61 (WA) - Monday, Dec 04, 2006 at 00:58
Hi Bill,
Sorry if I'm being a bit thick here, but I'm a bit of trouble following your figures.
It's a bit of a personal thing too for me that I believe in measuring the kms from fill to fill and then how many litres it takes to fill, not relying on warning lights as an indicator of fuel consumption.
So... as I read it your diesel use around town has not changed, but you now have the added cost of filling your gas tanks as well? I understand you get more power in the process and you may be happy to pay for the extra power you are getting.
Would that be the same for your towing figures? ie same diesel use before and after and now with the added cost of gas on top of your diesel use.
I was led to believe that the overall fuel cost would come down when running on Dieselgas, but if I'm reading your figures right, this doesn't seem to be the case.
Tim
AnswerID: 208439
Follow Up By: teddy - Saturday, Dec 23, 2006 at 17:32
Just had the gas fitted to my 1994 1HZ std diesel LC. (319,000kms, no turbo). First fill for 625 klms pulling 1 ton camper trailer, Penrith to Tamworth via the blue mountains, 69 ltrs diesel and 24 ltrs gas. combined average 14.9 ltrs/100kms. Pre gas figures of around 15 to 16 trs/100 kms, for the same hilly terrane. You get extra power and torque at around the same mileage, but the gas used is where you $ave. After little Johnny's $2000, I figure it will take around 50,000 kms to break even. I hav'nt tried the cruiser without trailer yet. cheers John
FollowupID: 471975
