Where to wire up Inverter
Submitted: Sunday, Dec 03, 2006 at 20:42
ThreadID: 40027 Views:4141 Replies:6 FollowUps:22
Hi all.
Just need an opinion on where to wire up a 600 watt inverter.
I have an 80 series GXL Landcruiser, diesel, and want to hard wire in a 600 watt inverter, mainly to charge up camera, phone, torch, jump start and computer batteries while on the move (but nopt all at once). I will get an auto electrician to do the work as I am a real "technical gelding" on matters electrical.
The car has two batteries installed - the main cranking battery for all the automotive stuff, and the second one is used solely to power the fridge (don't worry if it is an Engel or a Waeco). Battery management is provided by a Pirahna unit.
Should I have the inverter running off the main cranking battery, or the auxiliary (fridge) battery. My only concern is the drain may have some effect on the fridge.
Many thanks for your forthcoming collective pearls of wisdom.
Jack
Reply By: Member - Stephen L (SA) - Sunday, Dec 03, 2006 at 20:57
Hi Jack.
Why don't you save yourself some money and do the installation yourself. Run 2 wires from your auxiliary battery, a minimum of 6mm, one + and the other -. Wire them up to a Hella plug for a good positive connection and you are in business.
You should be able to find a spot through your firewall and run the cable out of site under the door sill kick plates.
Your main starting battery is designed to start your vehicle, without any extra heavy drain appliances running from it. From the list that you have listed, I would charge them while on the run, leaving your fridge to run all night without any problems.
That is what I would do.
AnswerID: 208394
Follow Up By: GaryInOz (Vic) - Sunday, Dec 03, 2006 at 21:33
****No way at all that the above post is ever going to be safe.****
A 600 watt inverter at ~85% efficiency at full power is going to need about 50-60 amps. For safety the wiring would have to be large enough to supply this (fire hazard if run under carpet etc) whether you think you may need it or not.
As a minimum about 8Ga for a very short run (<1 metre), or 4Ga (for up to 4 metres) using a decent sized Anderson plug if you want to remove the inverter.
If you are unsure, CONSULT AN AUTO-ELECTRICIAN. Big currents, hot wires and some high voltages involved pretty much demand this.
I would suggest trying to get by from charging as much as possible from the 12V as possible, as this has the least "conversion losses" (12v - 240v - 12v would waste 25-30% of the Aux batterys' charge, meaning longer to recharge).
Phone/camera/startpack could all be charged by the 12 (via an adapter if required). Laptop computer can be charged and operated by a dedicated car-laptop converter (12v to 15-18v) available from Tandy/DSE for <$100.
FollowupID: 468361
Follow Up By: GaryInOz (Vic) - Sunday, Dec 03, 2006 at 21:41
"...mainly to charge up camera, phone, torch, jump start and computer batteries while on the move..."
ALL of these do not require an inverter at all.
Be very clear. You are wasting money by putting in an inverter.
There is also the issue of having 240V around your vehicle in the event of an accident, with the possibility of causing injury to rescue personnel from electrocution, and the risk of sparks causing a fire following an accident.
I have really yet to hear of one valid reason to install a 240V inverter in a vehicle, and certainly none so far as to the safe use of such while the vehicle is in motion.
FollowupID: 468367
Follow Up By: Member - Jack - Sunday, Dec 03, 2006 at 21:47
Hi Gary.
You make some good points. Sadly, the batteries come with the special chargers (Sony Handicam, Olympus camera and Dell computer) that all seem to insist that you use their chargers. I have an adaptor to run the Dell from Kerio, and it powers the computer but will not charge the battery. Thanks, Dell ... wish we'd have known that before we bought it.
The jump pack (all 1400 watts of it) does not seem to like being recharged through the 12v system on the car. In fact, when I tried this, it seemed to discharge more, going by the power lights it had. The torch is one of those Kinchrome lead acid torches that is terrific, and it will recharge on 12v, but seems to do better on the 240v stuff.
At least the inverter has a small fan, and I have a few of those 12v computer fans laying around from some computers I have cannibalised at different times.
I still think I need an auto elec though. Thanks for the advice.
jack
FollowupID: 468368
Follow Up By: Ron George - Monday, Dec 04, 2006 at 08:08
G/day Jack, mate I`ve pretty much got the same set up you`ve got in mind, except my inverter is a 300 watt pure sine wave jobby, works a treat, even get to watch movies with the little flat screen LCD TV/dvd set up. My answer to your Q would be, figure out where YOU want the inverter installed, then get a qualified auto sparkie to do the installation… Generally speaking, any variable voltage electrical equipment will always operate more economically & efficiently on 240V so YOUR solution to YOUR requirements is good & sound… Disregard the dooms day merchants… Hot wires/under carpet/fires… And I`m also thinking that if a vehicle is smashed up so bad that it has exposed the internals of the 240V system to the risk of electrocution, the power source would be cactus, effectively nullifying that risk.And besides, if the system is correctly installed it will be properly fused to eliminate any risk of 240V electrocution... as safe as houses. So go ahead mate & enjoy your toys. Cheers Ron.
FollowupID: 468421
Follow Up By: Ron George - Monday, Dec 04, 2006 at 08:27
Jack, a PS to my last. Q. Is your inverter pure sine wave or, square wave, reason for asking, lappies don`t like square wave electricity if you are thinking of running it with 240V, the same goes for any like equipment, just be aware that what comes out the plug hole is not necessarily the same as household power. The price varies accordingly also, expect to pay a few more $$$s for the sine wave technology. Cheers.
FollowupID: 468425
Follow Up By: Member - Norm C (QLD) - Monday, Dec 04, 2006 at 11:39
I know that's the often stated rule Ron (Laptops need pure sine wave), but we have run 2 laptops (both Dell) on our modified sine wave inverter for over 12 months. No problem at all.
FollowupID: 468457
Follow Up By: GaryInOz (Vic) - Monday, Dec 04, 2006 at 12:08
Ron, most AGM cells will operate with the bottom of the case ripped open as the battery acid is held by the glass mat, and as such every AGM should be considered to be able to deliver more current than enough to cause a spark/fire, even when subjected to an impact. This is the basis for the caution about the inverters and electrocution risks too.
If you crack open a wet cell and drain only one of the cells then the battery is effectively inoperable.
It is not a "doomsday merchant" comment, simply a statement of fact.
"...if the system is correctly installed it will be properly fused to eliminate any risk of 240V electrocution... as safe as houses..."
Fuses are NOT there to save lives, but to save the wiring. You will be dead in the time it takes a fuse to blow. Earth on your 240v systems is what is there to save lives, but if there is nowhere for the current to properly earth itself (in a vehicles case due to being on rubber tyres and/or having poor contact with the earth), then you are it, buddy...(effectively standing in a puddle of water holding a wet hairdryer), all the way up to 600 watts before the inverter says "enough" (it only takes less than a watt to kill you....).
One other thing you touched on is the inverter waveform. Square wave and modifies sine wave CAN (note that I did not say WILL) cause problems with switchmode power supplies, often transmitting serious power spikes through to your equipment and damaging it. True sine inverters are the best to use with SMPS's, but are far more wasteful of power. Check the warranty on any equipment that you may connect to and inverter, you may fall under the "non-approved charging method" clauses that nullify your warranty.
What I would say is to contact the manufacturer of all your equipment and ask them if the have any 12v options for charging them. Just because it wasn't included in the original box and original price, and wasn't mentioned by the salesman doesn't mean it is not available (eg, all phones have a 12 ciggie lighter adapter available). You would have a better chance of making a warranty claim if it was connected to an "approved" 12v charging solution from the manufacturer than by some dodgy other means.
FollowupID: 468463
Follow Up By: GaryInOz (Vic) - Monday, Dec 04, 2006 at 12:11
"(it only takes less than a watt to kill you....).'
should be "(it only takes less than 10 watts to kill you....).
FollowupID: 468464
Follow Up By: Ron George - Monday, Dec 04, 2006 at 14:00
G/day Gary. Yeah mate point taken with the AGM battery, The thought of exposed wiring in the event of a ding be it 12/24V or 240V would be a bit of a worry for me... not from the electrocution point of view...But from fire!!!!
You commented it takes less than 10 watts to kill... reminded me (I’m not going to tell you how) I’ve been bitten a couple of times by that 240 jigger... It bloody well hurt... but I survived... what would you say to that??? I’m givin ya a free kick here so take it easy on me... Ok
No offence meant with the dooms day comment mate, One has to be constantly be on the toes when writing as it can be so easily be misinterpreted. Cheers Ron
FollowupID: 468483
Follow Up By: GaryInOz (Vic) - Monday, Dec 04, 2006 at 17:02
You've only got to cut in the wrong place with the Jaws Of Life to really make someone's day.......
Most people will get thrown by the shock, "disconnecting" themselves. In the instance where you Cannot move away from the source of power then yes, 10 watts (240V at 40 mA) is enough to do you in, and technically it could be as little as 16 mA (= 4 watts at 240V)
FollowupID: 468517
Follow Up By: Sand Man (SA) - Monday, Dec 04, 2006 at 19:32
Jack,
For your info mate, Dell provide a combination power adapter for about $90.00 which is all you need.
It comes with a 240 volt AC power cord when connecting to 240 volt, or a 12 volt DC power cord that connects to a car cigarette socket, or Aeroplane socket.
It's a pity they don't supply this combination power adapter up front hey.
Bill
FollowupID: 468543
Follow Up By: Member - Jack - Monday, Dec 04, 2006 at 20:13
Hi Sandman ...
I have the 240v one but was not aware of the 12v one. Grrr!!! shall check Dell out tomorrow. Many thanks for the tip.
I went direct to Kerio in Korea and got them to send me one which will power the Dell computer, but would not charge the battery. One lives and learns.
Thanks again.
Jack
FollowupID: 468554
Reply By: Wayne (NSW) - Sunday, Dec 03, 2006 at 21:05
Jack,
If you are going to only run the inverter while you are driving either battery will do.
Run the positive and negative 6mm wire from the battery to the inverter. The inverter can be mounted high on the cargo barrier.
It would be easy to get too, have plenty of air flow, and also keep an eye on it.
I would tend to connect the inverter to the second battery, just in case the inverter is left on over night.
Wayne
AnswerID: 208398
Reply By: Member - Norm C (QLD) - Sunday, Dec 03, 2006 at 21:19
I agree. Do it yourself. But put a good in line fuse on the +ve as near as possible to the battery.
I have my inverter permanently wired from the deep cycle battery. Find where other wires come through the fire wall. Get a piece of firm wire (a wire coat hanger is ideal) about 300 to 400 mm long. Push it through next to another wire (being careful not to damage the other wire). Overlap your electrical cable on this wire by about 100mm and tightly bind them together with insulation tape. Pull the wire through (you might need pliers to get a grip). Run your wires under the carpet and door sills (easily removed) to where you want it.
My inverter has screw on type terminals for input, so connection was easy.
From your described use, I doubt that you need a 600W inverter. We use a 300W inverter for pretty much what you have described and even it is somewhat over the odds. Apart from price, the main benefit is size.
Although you can happily run the inverter without running the engine, we try to remember to put it on to charge batteries while we are driving to reduce the need for this. Extends deep cycle battery life a bit.
AnswerID: 208402
Reply By: Derek from Affordable Batteries & Radiators - Sunday, Dec 03, 2006 at 21:23
Hi Jack
The 600W inverter will pull 50 to 75 amps so best to use 50 amp Andersen plugs.
I would use 8 B&S cable for the job and wire it off the aux battery.
Make sure to mount the inverter where it can get some air flow and if it has a fan fitted not suck up any dirt.
Derek.
AnswerID: 208404
Follow Up By: Member - Jack - Sunday, Dec 03, 2006 at 21:40
Hi Derek:
As I mentioned in my original post, I am a "technical gelding" on these matters. Can you tell me what 8 B&S cable is, please? I have taken on board the Anderson plug though though. That makes sense, even to me.
Jack
FollowupID: 468365
Follow Up By: Derek from Affordable Batteries & Radiators - Sunday, Dec 03, 2006 at 21:48
Hi Jack
8 B&S is 8mm2. This is around 5mm copper core diameter.
Have a look at my picture. 8 B&S cable
If you have the space and budget you may think of the 10mm2 tinned solar cable.
Derek.
FollowupID: 468370
Follow Up By: Member - Jack - Sunday, Dec 03, 2006 at 21:54
Whoa! Hold on Derek ... you are making my head spin here ... 10mm2 tinned solar cable??? Now I *know* I need an auto elec But I may even drop a few of these terms when I go over to see him, just to impress. :)
Thanks, you have just confirmed my "technical gelding" status.
Jack
FollowupID: 468373
Follow Up By: Derek from Affordable Batteries & Radiators - Monday, Dec 04, 2006 at 08:11
Hi Jack
It just sounds technical. It is just heavy two core.
Here is a link. 10mm2 Solar
It is the last picture on the page.
Derek.
FollowupID: 468422
Follow Up By: Ron George - Monday, Dec 04, 2006 at 08:40
Derek… mate for a moment I thought bugger… I`ve gone dyslexic…or sumpin… Your logo??? Have you had any comments from A.R.B.???? Cheers.
FollowupID: 468427
Follow Up By: Derek from Affordable Batteries & Radiators - Monday, Dec 04, 2006 at 09:07
Hi Ron,
Thank You for the interest. ABR is short for Affordable Batteries and Radiators. We do have arb's approval of our logo yes.
Derek.
FollowupID: 468430
Follow Up By: GaryInOz (Vic) - Monday, Dec 04, 2006 at 11:35
Derek,
I'm guessing that all you tinned wire would not be suitable for anything other than fixed installations, as tinning a wire can make the copper wires brittle.
FollowupID: 468456
Follow Up By: Derek from Affordable Batteries & Radiators - Monday, Dec 04, 2006 at 12:16
Hi Gary
Yes it is stiffer than the plain copper wire. Most wiring is of a permanent nature. The only point you may require some flex is the tow ball point or if you are making up some extension leads.
In the case of the inverter above you would assume it was to be fixed for a long period of time.
Derek.
FollowupID: 468466
Reply By: Member - Norm C (QLD) - Sunday, Dec 03, 2006 at 21:50
Derek's point about the potential power draw of a 600W inverter is one of the reasons to go for a smaller one unless you need the power.
My understandding is a phone charger will use about 10 to 15W. A laptop about 40 to 50W. A video camera charger about 20W. Even a pretty big TV uses only about 100W.
Unless you are taking your bread maker (500 to 600W) with you, 300W is heaps big enough for a simple inverter used mostly for battery charging. Even a 150W inverter will do the current job, but might let you do the next thing you haven't thought of yet.
As a rough rule of thumb, divide the maximum Watts (@240V) by 10 and that will give you the appromixate current draw from your 12V battery to run it. A fully loaded 600W inverter will draw about 60 Amps as suggested by Derek. A fully loaded 300W inverter will draw about 30 Amps.
For our 300W inverter, I used 8mm squared cable which can handle the maximum current draw, but used a 20 Amp fuse to give added protection in the knowledge that we will 'never' run it at full capacity.
Food for thought anyway.
AnswerID: 208413
Reply By: Member - Andrew W (SA) - Monday, Dec 04, 2006 at 21:16
I have pretty similar set up to what is being advocated by Derek (funny that - a lot of it came from him).
Aux battery - now an AGM by choice, as the risk of spark causing explosion of a wet cell appeared more of a problem to me than the potential issue with AGMs mentioned above.
I have a 600W Pure Sine Wave under the passenger seat (there is plenty of space there in my 100 series). It has big fans and never seems to get too hot. It has a 4-way power board mounted on it's reward facing side, so no need for additional 240V cables for what ever is running off it at the time. Yes, I have things running off it whilst driving (laptop often, battery chargers almost constantly). No, they are not usually that heavy a drain, so it may not really be fully utilised ever, except when I run a soldering iron on it or something like that, in the bush.
It is wired using real heavy cabling through the firewall driver's side, in the door sill conduit, and in the wiring track that runs across the floor - in this case to the passenger seat, and 175A Anderson Plug supplied by Derek, so that if I am fording, for instance, I can quickly disconnect the inverter - inside the vehicle as well as under the bonnet.
It rarely gets hot. I have checked it out after more than a year under there and pocket fluff was more prevalent than dust despite some real dusty miles.
There are lots of dangers in severe accidents ... this is one, but things underneath the passenger seat are pretty protected.
AnswerID: 208577
Follow Up By: Member - Jack - Monday, Dec 04, 2006 at 22:07
Hi Andrew.
Yes I am looking at under the seat in my 80 series sa a place to locate it, but it is a bit "squeezy" and I have some concern about getting a decent supply of cool air to it. I think it will probably end up on the cargo barrier. But the thing I have gleaned from the replies is that anderson plugs would appear to be the best and safest way to go as well as proper heavy wiring.
I must admit I have found all the replies very interesting, and it has given me plenty to consider. Thanks for your input as well. it is all appreciated.
Jack
FollowupID: 468579
Follow Up By: Member - Andrew W (SA) - Monday, Dec 04, 2006 at 22:15
Yep - mine would have been on the cargo barrier in a heartbeat - if I had one. It is the obvious place for it, and a mate of mine has his there. Works fine - he has set up a harness/conduit to make the cabling nice and protected.
I did grapple with all sorts of mounting in the rear, but there was nowhere that made a lot of sense and that felt as solid as bolted to the floor.
FollowupID: 468582
