Dust Seals on Camper Trailers
Submitted: Monday, Dec 04, 2006 at 20:07
ThreadID: 40053 Views:5730 Replies:4 FollowUps:2
Hello People ,
Can anyone recommend the best 'aftermarket' dust seals for a standard camper trailer for the rear swing door ? My new camper trailer has no dust seals to the rear swing door so any advice would be appreciated .
Thank's ,
Kev .
Reply By: Kev M (NSW) - Monday, Dec 04, 2006 at 20:09
Use the rubber door seals that you can get from Clark Rubber, I have found that they work quite well. Use silicone spray on them to stop them sticking on very hot days also.
Cheers Kev
Russell Coight:
AnswerID: 208563
Reply By: Notso - Monday, Dec 04, 2006 at 20:17
Yep, get the best quality stuff you can get from Clarks or an automotive supplier.
Make sure you get it think enough to accomodate the gap around the door.
What I'm saying is rip off the old rubber and measure the gap with the door closed then get something that will compress at least 40% when the door is closed at the point of the largest gap
AnswerID: 208565
Reply By: Member - Oldplodder (QLD) - Monday, Dec 04, 2006 at 21:02
I just got our CT, and it has pretty basic seals.
They are going to leak in dust, especially bull dust.
From travelling on roads out west I have come to accept some leakage, so don't worry about it any more. I just make sure I have the important stuff inside good sealing boxes in the car or CT.
I will hose out the CT when I get home and add to the gravel, stones and dust I already have deposited on the lawn from washing the car after each trip.
Actually, I found an interesting stone chip the other day, bit of chipped opal, must have been from White Cliffs or Lightning Ridge from a trip or 3 ago.
AnswerID: 208575
Reply By: sandyngraham - Wednesday, Dec 06, 2006 at 07:50
When we originally had our CT built I had a wheel stud welded to the frame and a hole drilled through the swing out tailgate. When you close the tailgate, tighten the wheel nut so it compresses the seal to the max. No dust ... ever... got in through the tailgate.
Regards, Graham
AnswerID: 208872
Follow Up By: Member - Pedro the One (QLD) - Friday, Dec 08, 2006 at 12:27
Hi, Graham ...................
Brilliant idea and so simple ....... will be incorporating it into my trailer system.
Not a CT as such, just a trailer modified to carry my $150,000 worth of camping gear accumulated over the past xxx years!!!
Like some-ne else daid here ....... great place for learning, ay !!
FollowupID: 469259
Follow Up By: Member - Pedro the One (QLD) - Friday, Dec 08, 2006 at 12:29
try "like some-one else SAID here ..... etc"
FollowupID: 469261
