Welded mesh - what's this pattern called?
Submitted: Tuesday, Dec 05, 2006 at 02:23
Member - Ozdyssey (QLD)
Does anyone recognise and can tell me the name or a rough description for this welded mesh pattern so I can track down some.
!MPG:30!
Reply By: Member - Ed. C. (QLD) - Tuesday, Dec 05, 2006 at 03:16
Looks to me like "Expanded Mesh".. (If that's what it is, it ain't welded!).....
| Confucius say.....
....Not necessarily mechanic!!"Member My Profile Send Message |
208643
Follow Up By: Old Nick - Tuesday, Dec 05, 2006 at 05:00
Dunno Ed- I think it called extruded mesh, but have been wrong before !! Regards Nick
468627
Reply By: Trevor W(Brisbane) - Tuesday, Dec 05, 2006 at 05:05
It is called "Expamet" and can be purche
ased through Webforge or if wanted in aluminium then you need to go to Alcan Centre .Go on the net a google for Expanded Metal. It comes in a number of differant patterns WM50080 is one size used in industrial walkways
208644
Reply By: Member - Ken J (QLD) - Tuesday, Dec 05, 2006 at 05:15
Hi Ozdyssey.
Product is available in
1/ Aluminium - expanded metal
2/ Galvanised steel - Stair tread mesh
Depending on how much you need & where u are I may be able to help.
E-mail me if u like .
alternatively go to a steel fabricator business & you may be able to obtain off cuts.
Metal merchants don`t usually cut sheets.
Good luck
Regards K J
208645
Reply By: Hairy - Tuesday, Dec 05, 2006 at 13:37
Yep
Expanded mesh or expanded metal or sometimes
grid mesh.
208719
Reply By: Wayne (NSW) - Tuesday, Dec 05, 2006 at 17:48
Ozdyssey,
This type of mesh was developed during WW2. Steel was hard to come by and they required steel for walk ways and surrounds.
The sheet steel was punched out and then stretched.
I my other job I am a Toolmaker and I make the blades that punch out the sheet steel that makes the mesh.
Wayne
208754
Reply By: Alloy c/t - Wednesday, Dec 06, 2006 at 09:42
Let me guess what you want /need it for ? 2x sections 300 wide by 1.5 long ? perfect tracks for self extrication on sand or mud ,quicker than shovels and or winching and in ally only half the weight of the plastic jobs now on sale for bulk $.
208885
Follow Up By: Member - Ozdyssey (QLD) - Wednesday, Dec 06, 2006 at 18:03
No but I do now! :)
468976
