Farmers Paddocks
Submitted: Tuesday, Dec 05, 2006 at 19:30
Member - Doug T (W.A)
Is there any grain farmers on here that can explain why they make the circles ,is the way the header has been driven in a continual circle or what , and NO to you others it.s not alien rings, see them at this Co-Ord in Google
S35 07 08.5 E140 55 08.6
Doug
Reply By: Member - John and Val W (ACT) - Tuesday, Dec 05, 2006 at 19:47
Im not a grain farmer but the circles are where centre pivot irrigators are used. These are a big wheeled frame that carries sprinklers on a long pipe that pivots around a central
water inlet point - hence "centre pivot". The diameter might be as much as half a kilometre. Also, sometimes they are cultivated or harvested in a circular pattern. However close inspection of some of the circles at your Google location have been worked in straight lines or blocks.
Val.
| J and V
- Albert Einstein
208774
Follow Up By: Member - Doug T (W.A) - Tuesday, Dec 05, 2006 at 19:58
Thanks Val
I have seen those sprinklers but don't they run in a straight line. anyhow these blokes in WA must have square sprinklers S28 50 15.1 E115 13 58.9.
I just measure one and it's 797 meters diameter this co-ord will drop right into the center S35 11 52.3 E140 59 26.7
468742
Follow Up By: Member - Doug T (W.A) - Tuesday, Dec 05, 2006 at 20:08
Val
If you move 2225 meters to the West is the 4X4
Border Track, that is if you have Google Earth , Ive always been wanting to do that run
468746
Follow Up By: Member - Doug T (W.A) - Tuesday, Dec 05, 2006 at 20:26
Val I think you are right , S35 02 30.4 E140 57 36.5 look at that one and you can see where the
wheels have been and how it's pivot from the center
468752
Follow Up By: Member - John and Val W (ACT) - Tuesday, Dec 05, 2006 at 21:55
Like your website Doug.
You are right, some of the travelling irrigators do go backwards and forwards not around in a circle. In the circle with the "pie slice" ( S35 11 52.3 E140 59 26.7) the darker segement was possibly all that was watered, maybe for an earlier crop. The square circles in WA are probably not irrigated, we are just seeing the tracks made by the tractors and harvesters. Incidentally most of these big tractors are now using GPS to guide them - hardly need a driver!. Some use a system called "controlled traffic" so the tractor follows the same wheeltracks at each pass over the ground. This minimises the amount of ground that gets compacted, and helps
water to penetrate better.
Val.
| J and V
- Albert Einstein
468785
Reply By: Notso44 - Tuesday, Dec 05, 2006 at 20:08
AH, that puts a stopper on all the other Alien replies!
208779
Follow Up By: Member - Doug T (W.A) - Tuesday, Dec 05, 2006 at 20:11
Don't be too hasty , they're watching
468747
Reply By: Member - Michael J (SA) - Tuesday, Dec 05, 2006 at 20:46
Doug,
You have faaaaaaaar too much time on your hands:)))))))))
Michael
208793
Follow Up By: Member - Doug T (W.A) - Tuesday, Dec 05, 2006 at 20:52
Yeh
well we all got to have a little play toy and a hobby, and it gives me something to do when I'm home, but on Thursday it will be back on the road again for a job right across the country to
Sydney so I will be gone a while,
while your about it have a little browse around in this , I'm sure you will find something in there to amuse yourself on
members.westnet.com.au/dtilley/
Doug
468760
Follow Up By: Member - Michael J (SA) - Tuesday, Dec 05, 2006 at 21:33
Hey Doug,
Great site, had a quick browse and am impressed.
Have a great trip and will catch up when you get back.
Michael
468776
Follow Up By: keepingitreal - Wednesday, Dec 06, 2006 at 16:38
Hey Doug,
Gr8 website. keep up the good work. Keep it real!! regards Kirsten
468954
Follow Up By: Member - Doug T (W.A) - Wednesday, Dec 06, 2006 at 19:02
Hi Michael
Will be going through your Home Town soon , If we don't get to stop going East then I will on the way back West if I come that way.
468993
Follow Up By: Member - Doug T (W.A) - Wednesday, Dec 06, 2006 at 19:04
keepingitreal
Everything on my website is very real or has been real and I fall into the latter
468994
Reply By: Turist (The Original One) - Wednesday, Dec 06, 2006 at 16:43
Want I want to see is a
sign on the fence that tells me what they are growing.
Wheat, oats etc easy to identify but some crops in the early stage have me stumped.
208962
