Fitting an ARB Airlocker
Submitted: Tuesday, Dec 05, 2006 at 20:02
ThreadID: 40091 Views:2302 Replies:1 FollowUps:4
I am looking at buying an ARB Air Locker for my 100 Series and fitting it myself. Has anyone had any experience with this? On my last vehicle (HJ45) I bought a second hand diff centre fitted with an Air Locker and fitted this, hooked it up to a blue-tongue compressor with all the switch gear. So that part is all good. I have also rebuilt an open diff successfully. The only unknown bit is fitting the actual locking mechanism into the diff centre. Are the ARB instructions complete and accurate? Are any special tools needed? Any useful advice would be appreciated.
Reply By: cowpat - Tuesday, Dec 05, 2006 at 22:58
Mike, all you need to do is remove the ring gear from the original diff centre and fit it to the locker, along with a set of new carrier bearings and install the bulkhead adaptor for the air line into the diff carrier. Too easy... The only tool you need beyond rebuilding an open diff is a 1/4 inch NPT tap (about $10). You'll also need the usual rebuilding tools - press and drifts, dial gauge, torque wrench etc.
If you know how to set up the backlash and the bearing preload you know enough to follow the instructions that come with the locker. Ideally you'll also know how to check the contact pattern and pinion bearings and maybe replace the seal while you're at it, but theoretically if the diff is in good condition these won't need to be touched. But...if you're unsure about any of the above and don't have a good deal of mechanical aptitude you'd be best off getting it fitted. Casper
AnswerID: 208839
Follow Up By: Mikee5 (QLD) - Wednesday, Dec 06, 2006 at 09:45
Casper,
Thanks for the reply. I will give it a go. I reckon I do have 'a good deal of mechanical aptitude'. If I get stuck I can always go to ARB with my tail between my legs and ask for help. (It wouldn't be the first time I have found the limits of my abilities!). I wonder though if they have qualified mechanics doing these jobs or not???
Mike.
FollowupID: 468869
Follow Up By: cowpat - Wednesday, Dec 06, 2006 at 16:33
Ok, some tips then:
- check the runout of the locker flange before you bolt on the ring gear. Runout ought to be within 0.05 mm or so. Check the ring gear too and try to locate the high spots so they cancel. Then when it's assembled check the runout on the back of the ring gear is within 0.05 mm. You might have to rotate the ring gear to another location...try to get the runout under 0.05.
- if the diff is at all old change the pinion bearings and put in a genuine Toyota pinion seal. You'll need to make up something to hold the pinion flange and a 1 m breaker bar. Be very careful when setting the pinion preload. Do it tiny little bit by tiny little bit once the slack is taken up.
- use new carrier bearings unless you've got proper carrier bearing removal tools (you wouldn't be asking if you did!).
- you can use a pin spanner from your angle grinder or make something up to crank down the big adjuster nuts. Forget what the manual says and crank up the preload. You don't want the diff centre shifting sideways under load and opening up the backlash setting. I did mine to the manual first time and when I tore it down later for inspection noticed that the bearings had not worn to the full width of the rollers on the non-load side.
- backlash should vary at most by about 0.05 mm at any point.
- check the contact pattern with gear marking compound or engineer's blue. If the diff is at all old the coast side will give the more reliable pattern. The drive side will probably be concentrated at the root of the ring/top of the pinion due to flex of the gears under load. The pinion height should be ok so if you've set the backlash to spec you're really only double-checking all is well.
- check there are no leaks before reinstallation!
- if a leak develops at the bulkhead fitting after installation coat the o-ring with ThreeBond and hope for the best
- check out the excellent advice on www.pirate4x4.com
Good luck, Casper
FollowupID: 468950
Follow Up By: Mikee5 (QLD) - Wednesday, Dec 06, 2006 at 19:32
Casper,
Thanks for the link, it looks pretty comprehensive, although a bit different to the L/C diff. One question, they say throw away the ring gear bolts - does this apply in my case, should I use new ones? My 'cruiser has done about 50,000kms but is not under warranty due to the three years running out.
Mike.
FollowupID: 469001
Follow Up By: cowpat - Wednesday, Dec 06, 2006 at 21:45
Mike, I reused my old ones on my LC105 as the manual I have did not say or imply that they should be replaced. They look pretty solid and the torque setting isn't that great so I don't think that they could be stretch bolts. And don't trust what anyone tells you by the way - me included, but especially those professional fellows at the diff shops! Have fun, I think rebuilding the diffs is one of the more exacting aspects of maintaining a 4wd. Casper
FollowupID: 469046
