Diff Locks
Submitted: Tuesday, Dec 05, 2006 at 21:54
rev's
I am in the process of purchasing a new Toyota 4wd, I'm undecided which way to go regarding diff locks. Can anyone tell me the best options, am I better off getting the genuine Toyota electric Lockers or going for the after market air locker. What are the advantages and disadvantages with either locker.
Reply By: Member - Phil G (SA) - Tuesday, Dec 05, 2006 at 22:15
They both work.
Advantage of the factory locker on a new vehicle is that there are no warranty issues. So if you bust a front diff, they are most likely going to fix it under warranty. If you have any aftermarket diff lock you have no chance.
Factory lockers are also cheaper.
208829
Reply By: Member - Doug T (W.A) - Wednesday, Dec 06, 2006 at 00:07
rev's
Have a look around my 4x4 webpage about Lockers , you will find all the info you want there
members.westnet.com.au/dtilley/4X4.htm
208851
Reply By: Member - Shane D (QLD) - Wednesday, Dec 06, 2006 at 18:14
My mate is a toyota mechanic and has air lockers on his cruiser but say say's that the factory set-up is way better than air lockers and if he was in a position to choose he would not think twice about getting factory set-up
If you check past post's regarding oil discharge/o rings probs,doesn't happen on factory locks, only others
208991
