80 Series Detailed Specs
Submitted: Tuesday, Dec 05, 2006 at 23:00
Member - Alex K (NSW)
Hi All,
Quick questions. I see on the Toyota website they publish a detailed specification of the 100 series but I can't find anywhere detailed specs of the 80 series. In particular i'm interested to know the max weight limit on the roof. I don't think it's as much as the 200KG stated for the 100 series.
http://lc100.toyota.com.au/TWR/content/static/15546.pdf
Any ideas would be great.
Alex
Reply By: disco1942 - Tuesday, Dec 05, 2006 at 23:25
You won't find specs for the 80 series - they only publish the info on the models they currently sell
208842
Reply By: Bware (Tweed Valley) - Wednesday, Dec 06, 2006 at 02:20
Try this site Site Link for loads of info on your 80series
208867
Follow Up By: Alloy c/t - Wednesday, Dec 06, 2006 at 09:21
Bware ,Lcool has only 1 reference to the roof weight for the 80 ,and that has a very wide variable ,150kg to 300 kg , have just gone thru the same process , my boat 3.66m comes in at 82kg with false floor in place ,rack itself even though all alloy weighs 45/50kg ,throw the motor [ 10hp mariner ] uptop ,fuel 25 kg and all the other bits for boat we would come very close to 270/300 kg allup ,good thing is that the 80 has a legal GVM of 2960 and a GCM of 5460kg.
468867
Reply By: Member - DOZER- Wednesday, Dec 06, 2006 at 09:47
My gut feeling is 200-250kg max....im sure ive heard that before.
However....it all depends on where you want to take the load....i wouldnt put 50kg on the roof if i were going to the cape....suggest you weld a mount for the outboard on a rear swingout carrier....and keep most of the weight low.
208889
Reply By: BenSpoon - Wednesday, Dec 06, 2006 at 16:39
I am told the roof of an 80 can be loaded heavier than a 100 because the 80 uses gutters and the 100 is gutterless and relies on internal supports which are not as robust.
208961
