Rip off or Genuine
Submitted: Tuesday, Dec 05, 2006 at 23:14
ThreadID: 40108 Views:3825 Replies:9 FollowUps:8
G'day all, I did some shopping for quotes the other day on the things I thought I would need to tow a caravan. The first thing I started with was the Dual battery system. I was quoted by a Darwin company that it would cost $750.00. They would also install a fridge plug for $165.00. 12 volt outlet on towbar, live wire and Anderson plug for $165.00. or 12 volt outlet bar with solinoid for $265.00 with anderson plug. Before I go to far with all the quotes, which is better, Live wire or what ever the alternative is called? UHF radio TX3400 with AE 4 or 8ki antenna for $820.00. Brake controller $330.00. 40lt Engel fridge with bag for $1250.00 and to finish the quote Suspension Kit for 100 series L/C for $1680.00. I thought these were the things that I would need after reading caravan forums. Am I close to the mark or are there things that I have missed. The quotes come to $4830 or $4930. Is this reasonable? Any help from genuine 4WD's not salesman or interested parties, would be appreciated.
Reply By: Willem - Tuesday, Dec 05, 2006 at 23:41
Spent 20 years in the Top End and know the prices....lol
A dual battery system should cost around $100 for a battery tray, $150 for a battery, $50 wiring, $50 for solenoid and inboard switch = $350 plus 20% for being in Darwin=$420 Do the work yourself. Its not that difficult
Dont know about brake controller.
UHF and antenna should not cost more than $400. Buy off Ebay and install yourself maybe even less expensive
Engel Fridge is about spot on
Suspension Kit should also be about the right price(My OME for the Nissan 2" lift cost $1220
AnswerID: 208845
Reply By: Truckster (Vic) - Tuesday, Dec 05, 2006 at 23:42
Seems a bit steep for $4 of wire and $5 plug...
Also the radio, Price: $429.00 (Including GST) and free shipping. from www.prestigecom.net.au/
I think they are trying to make the yearly budget one sale.
AnswerID: 208846
Follow Up By: Gramps (NSW) - Tuesday, Dec 05, 2006 at 23:52
The same mob will do a Value Bundle Pack (Tx3400, 6db aerial, cabling etc and shipping) for $449. Delivery is a couple of days. Not hard to install yourself.
FollowupID: 468814
Reply By: Member - Barry (NT) - Wednesday, Dec 06, 2006 at 00:03
Hi Pete
been through this over last year - shop around
dual battery + controller & winch isolator switch $450 ish
50l Waeco $1049 around town, now $949 at Mitchells (free cover bag)
anderson plug fitted, and wiring to towbar say $150 - 180 all up
brake controller - try auto elec on the side road (Parallel to Stuart Hway) opposite the old Wyuna coldstore near Kerry Holden
Cheers Barry
AnswerID: 208849
Reply By: Member - Peter H (NT) - Wednesday, Dec 06, 2006 at 09:03
Thanks to everyone that replied, we appreciate your time and knowledge.
Peter and Dawn
AnswerID: 208878
Reply By: Sand Man (SA) - Wednesday, Dec 06, 2006 at 09:29
Peter,
The quotes given to you do NOT necessarily sound like a rip off to me.
A top end electronic dual battery system (Piranha DB series) costs $800+ including the rear outlet, wet cell deep cycle battery and tray, including installation, from places like TJM in Adelaide.
(This is what I paid about 4 years ago which included relocation of a couple of engine components to enable the second battery to be fitted)
Yes, you can get most of the individual items a bit cheaper if you shop around in the bigger cities.
Yes, you can do a cheaper installation if selecting a lower spec'd isolator and other components.
Yes, you can save money if you do it yourself.
But, if you are unable to do it yourself and the installer who quoted you is using quality components, I don't think they are "ripping you off".
My guess is, you have a limited selection of installers in Darwin when comparing to the other big cities with more "competition", but unless you can travel to Adelaide, or Perth, or Melbourne, etc., you don't have must of a choice.
And, the cost of traveling to these places will negate whatever cheaper quotations you may get.
Be sure the Installer is quoting the options you want, or need and that you understand what each option (e.g. live wire) will give you.
All up mate, I think the quotes are reasonable.
Good luck with your choices Pete.
Bill
AnswerID: 208881
Follow Up By: Truckster (Vic) - Wednesday, Dec 06, 2006 at 14:29
not a rip off? somethings maybe, but "UHF radio TX3400 with AE 4 or 8ki antenna for $820.00"
FollowupID: 468916
Follow Up By: Sand Man (SA) - Wednesday, Dec 06, 2006 at 17:11
Gee, your a hard man Bruce.
The cost of a 3400 from Prestige Communications - $429
An antenna - about $100 thereabouts.
That means the Supplier installation cost for both the Radio and antenna is around the $290 mark.
I'm not in the installation business, but that sounds reasonable to me.
Bill
FollowupID: 468964
Follow Up By: GaryInOz (Vic) - Wednesday, Dec 06, 2006 at 18:54
Having done MANY radio installations (comms gear for news crews into vehicles etc) I can tell you $290 for 1/2 hrs work is a bit steep.... (2 power wires, 1 coax termination, mounting a antenna onto a baseplate to bullbar, and a mount for the radio and mike)
If you did it yourself it would take an hour or two, but these guys would have done soooooo many that they could do the 8/5 of p!ssed in the dark with blunt tools, in less time than it would take the average person to size up the problem.......
Sounds like a right royal reaming (if you get the drift)....
1 Hr tops at ~$60/hr.
FollowupID: 468989
Follow Up By: Truckster (Vic) - Wednesday, Dec 06, 2006 at 23:04
" Value Bundle Pack (Tx3400, 6db aerial, cabling etc and shipping) for $449"
$300 to fit ?? I'll quit IT and go into this game if thems the rates
FollowupID: 469076
Reply By: Member - Brian H (QLD) - Wednesday, Dec 06, 2006 at 09:42
Will be up your way for a couple of weeks from the 26th Dec. I purchased all my bits and went to a car radio place who fitted a new CD player/ radio and UHF etc they had to modify the dash to fit the UHF and it cost $160 in labour and they did a couple of other bits and pieces. I though that was reasonable, very neat job as well.
Not sure where you got the quotes from but I'd be looking at buying what you want first and checking out a car radio installer. I would at least on those figure be checking a few other places to get the work done.
The UHF is way over the top to say the least IMHO.
Brian
AnswerID: 208886
Reply By: Member - DOZER- Wednesday, Dec 06, 2006 at 09:42
Gday
Rays camping in Adelaide were selling the 40 litre engel for $799 last year (or was it the one b4) so it looks like there is an excellent mark up on these fridges....
AnswerID: 208887
Follow Up By: Leroy - Wednesday, Dec 06, 2006 at 09:56
but wasn't that a new store opening special?
Leroy
FollowupID: 468870
Follow Up By: Member - Phil G (SA) - Wednesday, Dec 06, 2006 at 10:05
Yep, it was 2 years ago, and it was Rays attempt to wipe out the competition, which I think they underestimated. Usually $990 when theres a price war in Adelaide.
FollowupID: 468872
Reply By: Member - Phil G (SA) - Wednesday, Dec 06, 2006 at 10:16
All sounds reasonable, provided you're getting quality stuff and a good installer. You'll pay the same prices in Adelaide unless you shop around a lot.
Doing it yourself may provide you with grief. I reckon the most common electrical issues I've seen out bush are crappily installed dual battery systems and wiring. Get it done properly first time. I do almost everything myself - but everything gets soldered and well secured and insulated - don't go for the $4 wire and the $5 plug.
AnswerID: 208895
Reply By: Member - Shane D (QLD) - Wednesday, Dec 06, 2006 at 18:40
how ya goin Peter,
some of these prices seem a bit steep(with out thoroughly checking my self) but I can say the price for suspension is dear
I got 4 HD springs/shocks from terrain taimer (lovells springs/rocab? shocks) for $800,fitted myself,60mm lift.
I had major steering issues because of the castor being altered and getting told that it would cost $400 to rectify,I got other opinion's and one that I went with was to "put up with it" until it settles and the second battery/winch goes on, to pull the front back down.
steers good now, I deliberately went out and found humps/dips where I could get a wheel or two swinging in the air too help springs settle thus correcting castor issues.
Its pointless getting castor corrected a week after springs go in because they take 3-4 weeks to settle and THEN decide if it needs it,mine didn't
Shane
AnswerID: 208999
Follow Up By: Johnny boy - Friday, Dec 08, 2006 at 08:26
Hi all
I have a 100 ser my duel batt set up cost $150 (FITTED) charger $190 Batt Half hour in my garage making a bracket to hold my batt down to existing FACTORY tray .
About 6 mtrs of 10 mm cable a HUGE gold plated fuse at the 2nd batt pos postfrom jaycar about $20 and an Anderson plug from aq truck supplier $9.90 run cable from batt down to chassis rail about 5-600 mm exposed then run the rest in the safty of rail to the back of the 4b.
I have been quoted on suspension and can pay between $800-$1500 with steering damp ..$ 200 to fit on average.
UHF $500-$600 should get you a set up that will do the job (You FIT )
With everything else well the other guys will be able to help :)
bit of Advice don't walk in for a serious quote without any Idea of what you really want as salespersons start to lick there lips as if we are fresh meat for for the killing and if you have a bit of knowledge they seem to step back a little and try to help a bit more ..WELL THATS MY VIEWS .
Good luck
Regards J,B.
FollowupID: 469225
