Dual Battery Management systems
Submitted: Wednesday, Dec 06, 2006 at 11:53
ThreadID: 40114 Views:8847 Replies:5 FollowUps:4
Hi. I would like to thank everyone for your feedback regarding previous topics as to Portable Fridge Freezers and Battery power etc etc. From all the good advice I decided on the Waeco 60Ltr Fridge/Freezer and purchased same yesterday.
I am also getting a good quality Dual Battery Management system installed soon. Now I would like a bit of feedback as to the best one on the market.
TJM and Solar Express advertise systems which interest me.and their Companies are convenient in my area of Qld. Has anyone had their Systems installed and if so are they satisfied.
Also I think 6mm wiring will not do the job properly and would say my wiring will have to be at least 10mm. What do you reckon?
Once again thanks for all the feedback, from you guys who have been been there and done it. There is nothing better than experience and it makes obtaining the right equipment much more simple when you have all the facts for and against.
C yah
Reply By: Wizard1 - Wednesday, Dec 06, 2006 at 12:08
6mm wire is the industry standard. 10mm is larger than battery cable! Remember it is the size of the copper core only! I power my van through 6 mm cable via an Anderson plug. The largest most goto is 8mm. Speak to an Auto Electrician or Solar Express, experts usually know best.
AnswerID: 208908
Follow Up By: joc45 - Wednesday, Dec 06, 2006 at 12:42
Wizard,
I think some people on this forum loosely refer to 10 square mm as simply "10mm", subsequently interpreted by many as 10mm dia.
10 sq mm is about 3.6mm dia.
Gerry
FollowupID: 468891
Follow Up By: Alloy c/t - Wednesday, Dec 06, 2006 at 13:29
And 6mm sq tinned is the perfect fit for 50amp Anderson plugs.
FollowupID: 468902
Follow Up By: Wizard1 - Thursday, Dec 07, 2006 at 13:18
Thanks for clearing that up joc45, 10mm did seem a little large.
FollowupID: 469152
Reply By: pepper2 - Wednesday, Dec 06, 2006 at 14:47
Have you considered simply running both batteries in parallel and installing a three way isolating switchinstead of expensive managing system".
You can set your fridge to cut out at a level that still allows you to start the vehicle,it is possible to run the batteries flat if you leave anything that doesnt have a low voltage cutout switched on eg headlights,radio,etc.
But nothing to go wrong,no electronics,not stressing the auxillary battery by frequent dischargingup to double the run time as both batteries connected at all times ,potentially longer battery lifejust something to consider...happy camping
AnswerID: 208933
Follow Up By: Wizard1 - Thursday, Dec 07, 2006 at 13:22
I've had one of those "expensive" solanoid things now for 5 years. The car is still on its original starting battery! The system obviously and quite successfully manages the power needs of the car as well as those of the fridge and caravan via the second battery. The second battery can be called upon as the starting battery (yes I know CCA, etc) by an override switch on the dash.
I like the fact I don't have to pop the bonnet and turn a knob, etc to prevent the starting battery being drained. It is all a no brainer....
FollowupID: 469153
Reply By: Sand Man (SA) - Wednesday, Dec 06, 2006 at 18:14
Nomads,
TJM used to be authorised distributors for the Piranha Electronic Dual Battery management system.
Cannot see it on their Web site so they may have "dropped" it in favour of their "own" brand.
I can only recommend what I have experienced and the Piranha DBE150S or the higher featured DBE180S would still be my choice for a top line electronic Isolator.
TJM installed my system which included relocating the hydraulic reservoir and air conditioning pipes to fit the battery tray in.
One thing to look for. Do you want a standard "wet cell" deep cycle battery or an AGM style. You may have to source an AGM from another supplier if TJM don't have access to them, or you want a particular brand. Also, not many AGM style batteries will fit in the engine bay of some vehicles, they are just too big. Just keep this in mind.
Bill
AnswerID: 208990
Reply By: vcbb - Thursday, Dec 07, 2006 at 10:29
I have a Navara and dual battery system wont fit, so I have gone for the Opposite Lock CM Dual Battery box. It has the chargemaster isolator, dual monitors ( Input Voltage & storage capacity) , Multiple power sockets, circuit breaker
and also a 7 metre lead . It can be taken away from the car and can fit any battery.
Website is Site Link
AnswerID: 209118
Reply By: DustyM - Thursday, Dec 07, 2006 at 15:07
Hi Nomads,
I think that you have already had your questions answered by others, but I though that I would include my 2-cents worth.
The advice about wiring sizes was spot-on. Many people make the mistake of describing cable sizes in millimetres, whereas its the cross-sectional area of the conductors - expressed in square millimetres - which is relevant. 6 sq mm cable is also known as 8-guage cable. Elsewhere on this forum I have found references to the current-carrying capacity of different size cables, and from memory 8-guage cable is rated at about 70 amps. This would seem like plenty of capacity for the connecting cable of a dual battery system. As stated elsewhere, 8-guage cable when tinned fits snugly into a 50-amp Anderson Plug terminal.
With regard to an isolator, there are a number of good units on the market. I would recommend that you go with the TJM or Solar Express systems you have already identified for the sound reason that they are located close to you. I installed a dual battery system into my 80-series Landcruiser last year. I chose to use a solenoid-type isolator sourced from SuperCheap Auto. It cost $99 and came in an excellent kit complete with a generous length of 8-guage cable, an earth strap with crimped-on connectors at each end, 2 battery post connectors (for the new 2nd battery) and 4 solder-on cable end connectors. I thought that it was an excellent kit, and great value for money. 12 months later, the isolator continues to work really well.
Good luck with your installation.
AnswerID: 209154
