Help Needed Urgently!!
Submitted: Wednesday, Dec 06, 2006 at 16:18
ThreadID: 40123 Views:2858 Replies:5 FollowUps:4
I have a '98 100 series , 1hz diesel (aftermarket Turbo), with R151F Gearbox. Gearbox needs major overhaul. I wanted to put in a heavier box H151F / H150F. Looking for advise and or other ppls experience in this process. Vehicle is used for work with up to 1/2 tonne in the back and also tow heavy trailers. wanting to maybe at a later date (when$$$$ avail) to a motor conversion. I have dont a fair few mods to vehicle and have it set up just how i want it ( nearly anyway!!!!). Keep it real. looking forward to your replies Regards Kirsten
Reply By: luch - Wednesday, Dec 06, 2006 at 17:35
Hi Kirsten
I dont know of any one that has done that conversion, but the H151F Has the same gear ratios as this is the gearbox used in the 78 &79 series
Should be more heavy duty as it is intended for heavy work being a comercial model Landcruiser
AnswerID: 208981
Reply By: nowimnumberone - Wednesday, Dec 06, 2006 at 18:41
probly easier to rebuild your box with heavy duty bearing kit.
were doing one at work at the moment ill let you know tommorow roughly how much its worth
AnswerID: 209000
Reply By: Member - Shane D (QLD) - Wednesday, Dec 06, 2006 at 19:40
I think they have a different input shaft as well as having beefed up internals,exterier are the same, dont know about your vintage ratios compared to 78/79 series but they are now different between std deisel and turbo
AnswerID: 209011
Reply By: Member - Tim - Stratford (VIC) - Wednesday, Dec 06, 2006 at 19:50
Kirsten,
Sign up for the 100s owners with Landcruiser Owners Online (LCOOL) - they are a wealth of knowledge when it comes to Cruisers (and Prados). Sign up for the 100s Australia and the state where you live.
If someone's thought of it - someone on this site has done it!!!
www.lcool.org/index.html
AnswerID: 209012
Follow Up By: keepingitreal - Friday, Dec 08, 2006 at 19:21
Thnx Tim, signed up, son i'll see where it all leads to. Nothing like a bit of fun and games, albeit always hard on thr hip pocket $$$$$$$$$. regards Kirsten
FollowupID: 469324
Follow Up By: Penguin (NSW) - Sunday, Dec 10, 2006 at 00:09
Hi Kirsten
You could also try outerlimits4x4.com
Mike
FollowupID: 469589
Follow Up By: keepingitreal - Sunday, Dec 10, 2006 at 21:06
Thnx Mike,
Had a look on outerlimits4x4.com . still waiting for the wrecker in Vic to get back to me regarding the bell housing. Many thnx for the advice.
FollowupID: 469693
Reply By: Member - Nick (Kununurra) - Thursday, Dec 07, 2006 at 18:49
Do a search on here, it was done a while ago.And yes I believe it can be done,believe you have to change the clutch and flywheel over and bolt it up.I looked into this and this is my plan if my gearbox ever goes.
How many kays has yours done??
AnswerID: 209180
Follow Up By: keepingitreal - Friday, Dec 08, 2006 at 16:48
Got a Hi5iF (heavy) box from Vic. Box is so much bigger. Looks like the bell housing is different and wrecker, who told me conversion can be done, is looking into it for me (thinks bell housing is from a petrol!!, however box is from a 4.2TD '03 100Ser). Looks like will have to alter drive shafts, not sure about Input shafts etc. My beaut wagon has almost done 240k. i love it! I did a search and ran out of time reading the results. Unfortunately could not find what i was looking for! Many thnx for the replies. ANY MORE NEWS KEEP ME POSTED! regards Kirsten
FollowupID: 469290
