GPS and Palm
Submitted: Friday, Dec 08, 2006 at 12:14
ThreadID: 40166 Views:2209 Replies:2 FollowUps:1
Hi all
I am in the process of researching using my Palm Tungsten T3 with a Bluetooth GPS. I have come across the Garmin 10 Deluxe GPS 10 which seems to fit the requirements. It comes standard with the City Navigator Australia v7. I understand this will do point to point mapping, which would be nice. The Garmin website mentions that it has expanded coverage of outback roads – but how good is it away from the cities? Or will I also need Metroguide (and is this any better?). I primarily want coverage for WA.
If these are no good, does anyone know of good mapping software that will run on a Palm? Oziexplorer does not appear to. No real requirement for point to point mapping, but needs to have access to fairly detailed maps.
Thanks in advance
Tim
Reply By: Member Dublediff(VIC) - Friday, Dec 08, 2006 at 18:01
Tim, until recently I had Fugawi (as in where the ....... maybe lol). I found this to have similar characteristics to Oziexplorer in that it uses ECW maps and you can scan and calibrate your own maps for more detail. You can download a trial program to see how easy it is to use. I am now using oziexplorer having upgraded my PDA.
By the way do you have a car mount for your tungsten. I still have mine that I don't need, it has a window suction mount, 12 volt charger and speaker built in. It was for a Tungsten T, but I believe the ports are similar across the tungsten range...you may have to check up on this..if suitable you could get yourself a bargain. Cheers Eric.
AnswerID: 209349
Follow Up By: tim_s - Friday, Dec 08, 2006 at 18:25
Hi Dublediff
I am always after a bargin - how much do you want for your car mount? I need to check the compatability issues. Let me know at timsercombe"at"yahoo.com.au. Replace the "at" with @.
Tim
FollowupID: 469314
Reply By: Bonz (Vic) - Friday, Dec 08, 2006 at 19:09
CN 7 kills metroguide, in fact it includes all the MG roads and many others. LAst trip to the Vic HC there was only one road that wasnt on the Garmin
AnswerID: 209358
